MOTD FIX
MOTD FIX
Postby Imperial » Wed Aug 16, 06 10:02 pm
V 100 doesn't seem to work, won't appear.
Anyone have a fix?
Postby Dae » Wed Aug 16, 06 10:05 pm
How did you install it?
Postby Imperial » Wed Aug 16, 06 10:20 pm
Through ini, entered in files to system, then edited the ini
Postby Dae » Thu Aug 17, 06 7:27 am
How did you edit it?
Postby Imperial » Thu Aug 17, 06 1:25 pm
<.ini file contents erased by admin in order to shorten scrolling>
Postby Dae » Thu Aug 17, 06 1:42 pm
Add
ServerPackages=DXMOTD100
ServerActors=DXMOTD100.MOTDServerActor
to
[DeusEx.DeusExGameEngine]
section of your DeusEx.ini.
If your server crashes make sure the mutator is disabled in DXMTL mutator list (the one which you can access from "host server" screen).
P.S. Erase "D:" in "CDPath="
Postby Imperial » Thu Aug 17, 06 6:22 pm
Er which mutator?
Log: Server Package: DXMTL152b1
Log: Server Package: DXMOTD100
Warning: Failed to load 'DXMOTD100 ': Can't find file 'DXMOTD100 '
Critical: appError called:
Critical: Failed to load 'DXMOTD100 ': Can't find file 'DXMOTD100 '
Critical: Windows GetLastError: There are no more files. (18)
<.log file contents partially erased by admin in order to shorten scrolling>
Postby Dae » Thu Aug 17, 06 6:26 pm
Have you put DXMOTD100.u to System/ folder :roll:
Postby Imperial » Thu Aug 17, 06 6:31 pm
Yep, unless it just goes out of the folder as soon as I put it in.
Postby Imperial » Thu Aug 17, 06 6:35 pm
Ahg! O.k, its in the folder and in the ini and its saying its not there??
My server will no longer stay up andis crashing:
<partially erased by admin in order to shorten scrolling>
Postby Dae » Thu Aug 17, 06 6:35 pm
Aahhh, I recollect this error!! Go to DeusEx.ini, find
and remove space after "...100".
Postby Imperial » Thu Aug 17, 06 6:37 pm
and remove space after "...100".[/quote]
There is no space there!:
CacheSizeMegs=4
UseSound=True
ServerActors=IpDrv.UdpBeacon
ServerActors=IpServer.UdpServerQuery
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master0.gamespy.com MasterServerPort=27900
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master.epicgames.com MasterServerPort=27900
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master.fragaholic.com MasterServerPort=27900
ServerPackages=DXMTL152b1
Postby DarkKnight » Thu Aug 17, 06 6:54 pm
CacheSizeMegs=4
UseSound=True
ServerPackages=DXMOTD100 <-----------
Yes there is.
Postby Dae » Thu Aug 17, 06 7:00 pm
Thanks Stevie!! :) I haven't managed to guess this way.
Postby Imperial » Thu Aug 17, 06 7:03 pm
Fixed it! Its hosting now, but, the motd is still not there!
Ty Darknight btw :)
And Dae of course :D
But any way i can get motd up?
<.ini contents erased by admin in order to shorten scrolling>
Postby Dae » Thu Aug 17, 06 7:04 pm
Oh and yeah, try removing space after this line too:
Postby Imperial » Thu Aug 17, 06 7:06 pm
Did, there definently isnt any space there.
CacheSizeMegs=4
UseSound=True
Postby DarkKnight » Thu Aug 17, 06 7:16 pm
ThunderBird wrote:Did, there definently isnt any space there.
CacheSizeMegs=4
UseSound=True
Make sure you surround your ini with code tags;
[code]Your ini stuff here[/code]
PHPBB automatically puts a space after each line other wise.
Postby Imperial » Thu Aug 17, 06 7:17 pm
Each Sub section or from start to finish?
Postby Gishank » Thu Aug 17, 06 7:19 pm
I had this problem, it was because my MOTD was too long.
Postby Dae » Thu Aug 17, 06 7:24 pm
Thunderbird
could you just attach this file using "Add an attachment" fieldset in your "post a reply" window?
Postby Imperial » Thu Aug 17, 06 7:34 pm
Teh Klop was right. He gets the medal! Sorry Guys.
But, as "The forum word cat "once said: You get a rotten Tomato.
Only joking, thanks for all the help! It was greatly appreciated.
Ty to DarkNigt, Dae and Klop.
Much appreciated.
I will now proceed to deleting all the long posts in the hope that I have not offended your eyes too much and that you will not need glasses anytime soon :)
Postby Dae » Thu Aug 17, 06 7:43 pm
I have already shortened the topic. :)
