I are need help. =(
I are need help. =(
Postby Siva » Sun Dec 17, 06 10:51 pm
Server won't appear in server list BLAH BLAH BLAH no-one else can see it.
How do I portforward this shiz properly?
http://www.portforward.com/english/rout ... ues_Ex.htm
I don't know what to put in internal IP =/
Edit:
Postby Kaiden » Sun Dec 17, 06 11:00 pm
Heh, you have a similar router to mine I expect, I have Voyager 205.
Anyway, I advise you to go to:
http://www.deusexnetwork.com/?page=tutorials&tutorial=2
Tutorial by [A]lex, he helped me with mine so it should work with you! :D
Is the static IP one of the address's in the cmd box?
Run>Cmd>IpConfig. I think its ones of thoughs, Default Gateway maybe? I think thats the address that sends you to your router anyway, if you put it as a url..
Postby Siva » Sun Dec 17, 06 11:57 pm
I don't know what to put in the internal IP box. =/
Postby Kaiden » Mon Dec 18, 06 12:52 am
Your default gateway I belive:
StartMenu:Run>Cmd>IpConfig
Heres some advise [A]lex gave me, if my router is anything like yours it should help:
IP: 192.168.1.3
You need to open these ports:
7790
7791
7792
8777
27900
And then, in that window:
Rule Flavor: Virtual Server
Rule ID: A number higher than 54, if it says the number is already used, use another
Protocol: Choose TCP
LAN IP Address: 192.168.1.3
Destination Port: 7790 (Or one of the others I gave you, you must do all of them!)
Local Port: 7790 (Or one of the others I gave you, you must do all of them!)
Mine looks like this somewhat:
So I would need to open 10 ports, two of each. One on TCP and one on UDP.
I think the "Ip Adress" Field is always 192.168.1.3(Or whatever your default gateway is!)
Postby Siva » Mon Dec 18, 06 10:40 am
Tried all three.
No luck. =(
And with windows firewall down. Still no luck.
Postby Dae » Mon Dec 18, 06 11:42 am
Does it appear at least as an IP address in the list? Usually such servers appear in 20 seconds later after the whole list loaded and they have 0/0 players and 9999 ping.
Postby Gishank » Mon Dec 18, 06 12:59 pm
DeusEx3?
Kinda offtopic, but wtf?
Postby Alex » Mon Dec 18, 06 1:05 pm
I have 7 Deus Ex's installed on my comp, so I am not really suprised.
Postby Siva » Mon Dec 18, 06 1:31 pm
Green Giant wrote:DeusEx3?
Each one is a different IP asshat
@Dae, nope.
Postby Siva » Tue Dec 19, 06 1:23 am
Bump due to Avenger making THREE topics. /sigh
Postby Avenger » Tue Dec 19, 06 10:07 am
prodagy sh'up
I will withdraw; but this intrusion shall
Now seeming sweet, convert to bitt'rest gall
|<~~Avenger~~>|
Avenger
Postby Siva » Tue Dec 19, 06 10:36 am
Avenger wrote:prodagy sh'up
Thanks for spelling my name wrong.
And you did make 3 threads, which you proceeded to double, AND triple post in.
Now if you want to discuss this with me further, PM me
Not on my thread.
Thanks.
Postby Avenger » Tue Dec 19, 06 10:38 am
my dx has alot of problems..files missing and so one so seeing as u came to my thread nd started off ill do it 2 urs ok ?
|<~~Avenger~~>|
Avenger
Postby Siva » Tue Dec 19, 06 2:13 pm
Avenger wrote:my dx has alot of problems..files missing and so one so seeing as u came to my thread nd started off ill do it 2 urs ok ?
Ah, because that is obviously the smart thing to do.
Anyone got a solution to my problem? =/
Postby Siva » Tue Dec 19, 06 9:20 pm
Bump - Servermode 1 or 2? My memory is lose.
Postby Siva » Sun Jan 28, 07 12:04 am
Bump for relevance.
Postby MainMan » Sun Jan 28, 07 12:08 am
Postby Siva » Sun Jan 28, 07 12:10 am
~MainMan~ wrote:Image
My Posting Date wrote:Tue Dec 19, 2006 8:20 pm
My Posting Date Two wrote:Sat Jan 27, 2007 11:04 pm
So shut up.
Postby Spiderbot01 » Sun Jan 28, 07 11:38 am
Mainman has sexy hands.
Postby MainMan » Sun Jan 28, 07 11:52 am
Lol they're not my hands - my hands are much nicer. That's an image I found on the internet.
Postby Kaiden » Sun Jan 28, 07 11:05 pm
Sorry, posted all my knowledge really! :( Try going over the things I posted again!
