Need help installing new dvd re-writer
Postby chinny » Wed Jan 10, 07 3:55 pm
ok guys ive connected the ribbon cable and power to the dvd rewriter, but no joy. i went to bios and set it up for auto detect (everything) still no joy.
im thinking now it has something to do with the master/ slave (whatever that is) jumper settings, however i aint got a clue about that stuff. :cry:
all i know is my normal dvd drive has 3 lots of 2 pins with the jumper on the left, like below :P
And my new dvd re-writer drive has 5 lots of 2 pins and the jumper is set to the far right, thus;
Please any help will; be much apprecieated, thanks for reading. :wink:
[url=http:///dxfactory.freeforums.org]Image[/url]
chinny
Postby ~D[A]rren~ » Wed Jan 10, 07 5:16 pm
Set it to master if the cable goes direct to the mainboard, set it to slave if the ribbon passes through another drive first, eg, slave.
Postby chinny » Wed Jan 10, 07 6:01 pm
the ribbon passes through another drive first but i don't know which position the jumper should be in to make it in Slave mode.
chinny
Postby ~D[A]rren~ » Wed Jan 10, 07 7:52 pm
It will tell you on a sticker, normally on the top of the drive, or in the manual.
Postby chinny » Thu Jan 11, 07 4:08 pm
ok thanks for the help, my older brother helped me out so it's sorted, cheers.
chinny
Postby clyzm » Fri Jan 12, 07 1:36 am
I wish I had an older brother who helps.
