FPS Problems..
FPS Problems..
Postby Kaiden » Tue Feb 13, 07 11:07 pm
Ok, over the past 1-2 months my FPS has been really low, like 13. I have no clue why this is. People say the average is anything from 13-100+. I find it increasingly difficult to kill people, as I am simply lagging all over the map.
Is there anyway to raise the FPS? Rather than buying a new graphics card which I need to do anyway.
My FPS never used to be that low ( I think ) or atleast I used to be able to kill people easier. It was about the time I joined [A] that it started getting really bad. At this time I also added OpenGL video card to my Deus Ex, perhaps that was the problem..
I'll try experimenting with them to see if they affect it. What are peoples average FPS stats here?
Postby MainMan » Tue Feb 13, 07 11:11 pm
Wow, my FPS is on average about 70. Some places in my map make it drop to about 6 LOL.
Anyway, yes different renders will have an effect. Try getting the new OpenGL render from here and then set DX up to use it.
Postby Survive. » Tue Feb 13, 07 11:13 pm
How do you check your FPS anyways please? It's been a long time since I was last on Deus Ex,
Thanks - Dan aka Survive :D
Survive.
Postby Kaiden » Tue Feb 13, 07 11:18 pm
Type stat fps (In game so you know what it in when running around etc)
Is that not the one I have in my screenshot MainMan? The one that gives me 13 fps! :x
Postby MainMan » Tue Feb 13, 07 11:21 pm
I don't think that's the improved version.
Postby Survive. » Tue Feb 13, 07 11:22 pm
thanks very much :)
Survive.
Postby Kaiden » Tue Feb 13, 07 11:34 pm
Ok, I'll try it. I was just playing around with them, and one updates it to 43 FPS, and I just won a game with it hehe.
Postby Survive. » Tue Feb 13, 07 11:56 pm
Ouch, I get 30 - 31 FPS :S
Survive.
Postby Zantinzuken » Wed Feb 14, 07 12:19 am
If it's always 30 fps without change it's ok, but if it changes drastically every time you get into a fight then it's poor.
Type "preferences" in and mess around with the settings of OpenGL/D3D, that works for me. You can do it in the DeusEx.ini too...
Postby clyzm » Wed Feb 14, 07 2:09 am
Clix made me do some FPS stuffs, with making the weapons all blurry to improve FPS.
My max FPS is usually 60 without change, but into fights it turns 30 or 25
Postby DarKnightKilla13 » Wed Feb 14, 07 2:18 am
60 FPS constant for me. Never drops, never higher. Probably due to limitations of the engine that it only shows 60 but I could be wrong.
PC:
Dual Core 3.2 GHz Intel
2 GB's RAM
ATi Radeon X700 Pro AGP 8x
30 mbits download and 5 mbits upload internet...
I figure thats why it's usually always 60.
DarKnightKilla13
Postby clyzm » Wed Feb 14, 07 2:23 am
Ok, I just realized when I played in a server just now, its 30 fps CONSTANTLY, I'm lucky if it turns 60, but when I fight it goes as low as 19 or 20.
Postby DarKnightKilla13 » Wed Feb 14, 07 2:26 am
The human eye sees at approximately 29.96 Frames per second so 30 isn't that bad... Although 60 is more fluid and pretty much guarantees not too many tie ups, 30 isn't that bad... but if it hits 20 that's pretty bad...
DarKnightKilla13
Postby Zora » Wed Feb 14, 07 8:31 am
There's a nice explanation about tickrate and all its related stuff, written by TSNe (clan viking, UT). The original location is lost, but I found a mirror here: http://www.utzone.de/include.php?path=content/articles.php&contentid=5668
This should explain all, also it shows its effects with nice screenshots.
Zora
Zora
Nephthys developer
Postby Gishank » Wed Feb 14, 07 9:02 am
On avarage i get around 5-7 fps. This is because my graphics card is old =/ So maybe your is too old?
Postby Professor Layton » Wed Feb 14, 07 3:22 pm
If you're still having issues with your fps kaiden, I could try to help you out with the renderers once. As clyzm mentioned somewhere in this topic, there are several ways to increase your fps, but in return you'll get reduced quality. Apart from that, the newer D3D and OpenGL renderers seem to handle the game much better than the previous ones, so you'd end up with better fps, by only changing the renderer and not experiencing decreased quality.
Postby Skinny Puppy » Wed Feb 14, 07 3:45 pm
Where can i get hold of these latest D3D and OpenGL? Mine stays on 40 fps on low :( used to be 75+ on high. (graphics in settings)
Skinny Puppy
Postby MainMan » Wed Feb 14, 07 4:07 pm
I've already posted the link in this thread.
Postby Skinny Puppy » Wed Feb 14, 07 4:27 pm
After installing those to things i'm still getting 40 and it isn't budging.
Skinny Puppy
Postby MainMan » Wed Feb 14, 07 4:35 pm
Did you configure Deus Ex to use them? (sorry for asking the obvious)
Postby Skinny Puppy » Wed Feb 14, 07 4:41 pm
All i did was put them in my /system folder? am i meant to edit something in the DeusEx.ini perhaps? Or which ever one? if so how?
oh and loaded up that box which Kaiden first posted and slicked them and started DeusEx.
Skinny Puppy
Postby MainMan » Wed Feb 14, 07 4:52 pm
Lol good thing I asked then.
Go to the video settings in the DeusEx menu and select something like change graphics device, and then select the one you want to use (OpenGL, or D3D8)
Postby Professor Layton » Wed Feb 14, 07 4:57 pm
he did mention he loaded up that box, mainman :P
Postby MainMan » Wed Feb 14, 07 5:03 pm
He edited that comment in afterwards.
Postby Skinny Puppy » Wed Feb 14, 07 5:17 pm
Yer like afew minutes after :P if only i could get mt 200 odd fps like on my menu in game :(
Skinny Puppy
Postby Professor Layton » Wed Feb 14, 07 5:27 pm
Weirdly enough I dont see the edited message on bottom, unlike at your post xD, guess I shouldn't trust the forums so much then.
Anyways, enough of that, if your fps just dropped to a lower amount and was higher at start you should check your comp for virusses and spyware, as it shouldnt just decrease like that.
Postby Skinny Puppy » Wed Feb 14, 07 5:58 pm
Oh i've done a defragment afew times, disk clean up, scanned for viruses spy ware, scanned.
Skinny Puppy
Postby Professor Layton » Wed Feb 14, 07 7:05 pm
What spyware scanner(s) do you have?
Postby ~ô¿ô~Nobody~ » Wed Feb 14, 07 7:17 pm
Hmm odd.. in MP in small rooms, I'm lagging in another way.
The client wants to be faster than the server.. possibly due to the 600fps :?
Postby Skinny Puppy » Wed Feb 14, 07 7:56 pm
Clix­ wrote:What spyware scanner(s) do you have?
Well all i no of is Ad-aware and AVG.
Skinny Puppy
