alrighty game problem
Postby [DXCT]Ðëstruction » Sat Mar 31, 07 9:54 pm
hey, i need some help concerning AlrightyGameV3
I have downloaded alrighty game V3 from http://www.freewebs.com/dxalrighty/
and i have followed instructions on the readme , yet when i start DX , the Problem Message screen comes up and says
Cant find file package for "AlrightyGameV3"
History:Uobject::Safeloaderror<-Staticloadclass<-InitGameInfo<-UGameEngine::LoadMap<-UgameEngine::Init<-XGameEngineExt::Init<-DDeusExGameEngine::Init<-InitEngine
Does anybody know what i could do ?
Thanks alot aand sorry for trouble.
thanks.[/u]
It's not about how hard you can hit, its about how hard you can get it and still get up and move forward.
Ðę§ŧřŭčŤįðń
[DXCT]Ðëstruction
Postby Dae » Sat Mar 31, 07 10:20 pm
Your DeusEx.ini, please.
Postby [DXCT]Ðëstruction » Sat Mar 31, 07 10:37 pm
here it is
thanks alot
deusex.ini
DX.ini
(14.67 KiB) Downloaded 256 times
Ðę§ŧřŭčŤįðń
[DXCT]Ðëstruction
Postby Allan » Sat Mar 31, 07 11:06 pm
I'd recommend you edit out your admin PW, unless it's a fake one... ;)
Postby [DXCT]Ðëstruction » Sat Mar 31, 07 11:39 pm
yea, its fake..* changes password, slaps himself for being an idiot.*
Ðę§ŧřŭčŤįðń
[DXCT]Ðëstruction
Postby Crusader » Sun Apr 01, 07 4:46 am
It may have something to do with the server query, i thought the alrightygame was instead of Npt. :? i could be wrong, but its possible that it could be the problem.
Crusader
Postby MJ12 » Sun Apr 01, 07 7:26 am
Me too had that problem but i make it correct theese a correct files use it
This achive has bad filenames use theese files ;)
oh and i found on your DeusEx.ini a problem with Alrightygame here a correct
Alrightygamev3.zip
Alrightygamev3 (correct)
(112.28 KiB) Downloaded 250 times
deusex.ini
Alrightygame work with that
(14.8 KiB) Downloaded 249 times
MJ12
Postby [DXCT]Ðëstruction » Sun Apr 01, 07 8:14 am
I dont think that i need alrighty game nor the ini as it wouldnt work with my DX
Should i change the nephty's lines?
Ðę§ŧřŭčŤįðń
[DXCT]Ðëstruction
Postby Professor Layton » Sun Apr 01, 07 8:30 am
[DXCT]Ðëstruction wrote:yea, its fake..* changes password, slaps himself for being an idiot.*
While you're on it, you might as well change your telnet password. -_-
Postby [DXCT]Ðëstruction » Sun Apr 01, 07 8:32 am
yea..i suppose i should :/
should i use MJ12's alrightygameV3 and his .ini? or is there any need
thanks
Ðę§ŧřŭčŤįðń
[DXCT]Ðëstruction
Postby Kaiden » Sun Apr 01, 07 10:05 am
Change to CRD instead! Less/no lag, AND it prevents cheating. Everyone wins. :D I suppose it doesn't have the admin menu, but the lagginess on your server it causes isn't a good enough reason to use it..
Postby Alex » Sun Apr 01, 07 11:51 am
Doesn't that mean it simply cannot find the file? Place AlrightyGameV3.u into your System folder. Voila!
Postby Dae » Sun Apr 01, 07 12:00 pm
I hoped that theres a space somewhere after the package name, assuming that he already checked that the package exists in /System/.
Postby [DXCT]Ðëstruction » Sun Apr 01, 07 12:14 pm
i have put in the alrightygamev3.u and the .int files into the system and when installing alrighty game i made sure everything into the dx.ini had no spaces
Ðę§ŧřŭčŤįðń
[DXCT]Ðëstruction
Postby Dae » Sun Apr 01, 07 12:24 pm
Try this (just extract .u and .int to System, no need to change .ini's).
Postby [DXCT]Ðëstruction » Sun Apr 01, 07 12:29 pm
it work 0. .0
U
great! [Retorical question] thanks alot..now why couldnt i do that? [/retorical questiojn]
Ðę§ŧřŭčŤįðń
[DXCT]Ðëstruction
Postby Dae » Sun Apr 01, 07 12:47 pm
These are two versions of one file; the second one was fixed by VodunLoas (I'm not mistaken). It's not your fault really, but author's.
Postby [DXCT]Ðëstruction » Sun Apr 01, 07 1:02 pm
:/ small problem now :C
i am not able to become a server owner , lets say in the ini i have the server owner password as sky
yet whem i login, it say wrong password entered :/
what should i do?
thanks alot!
Ðę§ŧřŭčŤįðń
[DXCT]Ðëstruction
Postby MJ12 » Sun Apr 01, 07 2:21 pm
[DXCT]Ðëstruction wrote::/ small problem now :C
what should i do?
thanks alot!
type sownerlogin (password)
MJ12
Postby [DXCT]Ðëstruction » Sun Apr 01, 07 5:10 pm
yes i have set my password in the ini and when i type sownerlogin jet(not password) it says that i have entered the wrong password ! :c
i dont know what to do
Ðę§ŧřŭčŤįðń
[DXCT]Ðëstruction
Postby MJ12 » Sun Apr 01, 07 5:27 pm
[DXCT]Ðëstruction wrote:yes i have set my password in the ini and when i type sownerlogin jet(not password) it says that i have entered the wrong password ! :c
WRONG ASSWORD???Thats Your problem try again look what ur password :)
MJ12
Postby [DXCT]Ðëstruction » Sun Apr 01, 07 5:28 pm
lol i have set my password to an easy spelt rememberal word..." sky" for instance, yet when i type it in it says wrong password when it is the right passwrod
Ðę§ŧřŭčŤįðń
[DXCT]Ðëstruction
Postby MJ12 » Sun Apr 01, 07 5:31 pm
try again set a password to g for a testing and try log in after u can change back
MJ12
Postby Dae » Sun Apr 01, 07 5:47 pm
You sure there are no spaces after the password?
Where did you set it?
