Two problems
Two problems
Postby Tonnochi » Tue May 29, 07 11:17 pm
When I try to join any server, it says Package BatteryPark.utx version mismatch and on startup unable t locate component "glide2x.dll" so it runs in a window only, probably because I'm using a shitty vid card right now.
Anyways, I think DXMMAI screwed up my BatteryPark.utx texture package, so can someone give me a good one please?
Postby Aidan » Wed May 30, 07 12:03 am
Yes, as you can see in the Technical Issues, I am also having problems with Moop's MMAI.
This is what I did:
Step #1 Re-Install DX (And Overwrite over all your files it asks for.)
Step #2 Thats it
Re-Installing DX should also fix your graphics card problems :D
I wouldn't suggest touching the MMAI after that. (No Offense Moop)
Postby Tonnochi » Wed May 30, 07 1:52 am
Yes that's what I did. I did use MMAI to immortalize my cache and use the great no-CD patch, but I can (learn to) de-cache anything I need.
Postby Aidan » Wed May 30, 07 4:18 am
Hmm.
I got it.
Uninstall Dx, then click on the Main Deus Ex folder in your Hard Drive, Delete it, then Install Dx again. I'm sorry, but I can't help you in this that much unless you give me some more detail. What Operating System (OS) are you using anyways?
Postby Magus » Wed May 30, 07 6:45 am
Technically, you don't even have a problem mate.
That's Mapvote working with default settings.
Once you get it configured it's fine.
As for Tonnoichi: Try this.
BatteryPark.utx
(2.84 MiB) Downloaded 250 times
Magus
Postby MJ12 » Wed May 30, 07 11:32 am
)P(sHyCo)(K!//3R wrote:Yes, as you can see in the Technical Issues, I am also having problems with Moop's MMAI.
This is what I did:
Step #2 Thats it
Lol its a big help
MJ12
Postby Dae » Wed May 30, 07 2:10 pm
Tonnochi wrote:When I try to join any server, it says Package BatteryPark.utx version mismatch and on startup unable t locate component "glide2x.dll" so it runs in a window only, probably because I'm using a shitty vid card right now.
Gimme your DeusEx.ini and i'll fix it without reinstalling.
Postby Tonnochi » Wed May 30, 07 6:40 pm
I fixed it, I uninstalled and deleted C:/DeusEx, and re-installed MMAI without the maps. Thanks everyone.
