MMCity Problem
MMCity Problem
Postby ~M3GG4~ » Sun Jun 03, 07 6:55 pm
Hey.
I have an MMCity problem,and was looking for some help.
I have downloaded the setup file and ran it. But when i click play MMCity it says
[b]Missing Shortcut[/b]
      Windows is trying to locate the file  deusex.exe.Locate it yourself?
thanks for any help.
<center> Image </center>
<center>Deus Ex Soldiers
~M3GG4~
Postby Dae » Sun Jun 03, 07 7:09 pm
had the same problem
locate your DeusEx.exe - find DeusEx/ folder, usually C:/DeusEx or C:/Program files/Deus Ex and open /System/ in it
Postby ~M3GG4~ » Sun Jun 03, 07 7:12 pm
Thanks, but when i do that and start up MMCity, it just starts up Deus Ex.
~M3GG4~
Postby Gishank » Sun Jun 03, 07 7:15 pm
Right, simple way.
1. Right click the icon.
2. Open properties
3. In the "Target" field, delete and paste
C:\DeusEx\System\DeusEx.exe MMCity.dx -hax0r
4. Click Apply.
5. Click ok.
Postby Magus » Sun Jun 03, 07 7:17 pm
Chances are you'll need to re-run the installer, and direct it to your DeusEx directory manually, since it looks like you have a non-default setup
Magus
Postby Dae » Sun Jun 03, 07 7:38 pm
-[DXS]-Destroyer wrote:Thanks, but when i do that and start up MMCity, it just starts up Deus Ex.
it's a glitch
after it started, hit 'T', erase 'Say' and type 'open mmcity'
Postby MainMan » Tue Jun 05, 07 6:57 pm
Yeah i'll make a new installer soon.
Postby Ayleth » Thu Jun 07, 07 7:19 pm
hmm you wouldnt be using slimline by any chance?
A frient has slimline, and gets the same thing.
¨‘°ºMåsåmµñ£º°‘¨
˙•●●ĊђασsΪηcǻяйαѓε●●•˙
jason.unger@gmail.com
Ayleth
Postby ~M3GG4~ » Sun Jun 10, 07 1:12 pm
Every works fine now >_> thanks for the helps, and yeah i use slimline.
~M3GG4~
Postby ~M3GG4~ » Fri Jun 15, 07 6:13 pm
Damn, Same problem again with the new installer, but this timewhat I done before dosent work.
Any help appreciated.
Thanks ~Destroyer~
~M3GG4~
Postby ~M3GG4~ » Sun Jun 17, 07 9:13 pm
Umm.. I still can't get it working, I've been at it for a while, yet it dosent seem to work.
I just need a little bit of help installing it.
~M3GG4~
Postby MainMan » Sun Jun 17, 07 9:20 pm
Try using the manual .zip archive, and extract it to C:/DeusEx/ (or wherever your DX is installed)
Postby ~M3GG4~ » Sun Jun 17, 07 9:40 pm
Ah, ty but now when i enter it says connection failed. twice.
~M3GG4~
