DX dedicated
DX dedicated
Postby Max » Sat Jun 09, 07 4:00 am
wen l try run a deus ex dedicated server l am getting a first person veiw and admintellynet cannot find the game help plz!!
Making a custom Game Type
creating an RPG Game
Max
Postby {17}agentsmith » Sat Jun 09, 07 9:16 am
hmm you have a firewall?
{17}agentsmith
Postby Max » Sat Jun 09, 07 9:17 am
yer y
Max
Postby Magus » Sat Jun 09, 07 9:17 am
Firewall or not, Dedicated servers do not load a local client.
Magus
Postby {17}agentsmith » Sat Jun 09, 07 9:18 am
is your telnet admin set to the right address?
{17}agentsmith
Postby Max » Sat Jun 09, 07 9:23 am
well it works wen it is not dedicated but wen l try dedicated with the visual it dousent find it
:shock:
Max
Postby {17}agentsmith » Sat Jun 09, 07 9:29 am
thats weird :roll:
can you upload your .ini and log files dude?
{17}agentsmith
Postby Max » Sat Jun 09, 07 9:33 am
here is the log
DeusEx.log
(8 KiB) Downloaded 441 times
Max
Postby Max » Sat Jun 09, 07 9:34 am
here i
DeusEx.ini
(14.61 KiB) Downloaded 414 times
Max
Postby {17}agentsmith » Sat Jun 09, 07 9:44 am
right i don't know much bout logfiles so i looked mainly at the .ini
it looks fine to me except in your server actors/packages section you have this:
GameRenderDevice=None
AudioDevice=Class'Galaxy.GalaxyAudioSubsystem'
Console=Class'Engine.Console'
NetworkDevice=Class'IpDrv.TcpNetDriver'
Language=None
none of that needs to be in there
dunno if that helps
if that fails then i will look at other things
good luck!
{17}agentsmith
Postby Max » Sat Jun 09, 07 9:55 am
no it doesn't work but thanks any way
Max
Postby {17}agentsmith » Sat Jun 09, 07 10:04 am
no probs
i'll have a closer look at the log file
{17}agentsmith
Postby Max » Sat Jun 09, 07 8:16 pm
{DXCt}agentsmith wrote:no probs
done it yet?
Max
Postby Dae » Sat Jun 09, 07 8:27 pm
To be honest, I don't understand your problem
Please, explain more. How do you connect to Telnet, what program do you use, etc.
Postby Max » Sat Jun 09, 07 8:31 pm
l use puttytel.exe l put the ip in and port and pressen than if l have the game up un un dedicated
it works like a charm if it is in dedicated mode then it exits puttytel.exe
but l think the problem is that l get a visual on dedicated mode
Max
Postby Dae » Sat Jun 09, 07 8:39 pm
I can understand "probblen" as "problem", but what's "visul on"?!
What happens when it exists? Anything displays?
Postby Max » Sat Jun 09, 07 9:21 pm
it gives the erra sound
visual is on deus ex
Max
Postby Magus » Sat Jun 09, 07 11:02 pm
My English may not be perfect, but I think he's trying to say that, rather than DX shutting down to a systray icon then running a dedicated server, it opens a local client (as in non-dedicated mode).
Magus
Postby Max » Sun Jun 10, 07 2:53 am
Magus wrote:... I think he's trying to say that, rather than DX shutting down to a systray icon then running a dedicated server, it opens a local client (as in non-dedicated mode).
Yes. That is exactly what l see.
Max
Postby Dae » Sun Jun 10, 07 11:18 am
Magus wrote:My English may not be perfect, but I think he's trying to say that, rather than DX shutting down to a systray icon then running a dedicated server, it opens a local client (as in non-dedicated mode).
Thanks, but what's with Telnet then?
This problem appeared because you either didn't install the game properly (just moved files) or you have more than one Deus Ex game installed. Anyway, you can try starting the server via a small batch program (download below). Extract it to DeusEx/System and launch from there.
server.zip
server.bat
(199 Bytes) Downloaded 282 times
Postby Max » Sun Jun 10, 07 12:34 pm
wen l click on server.bat it starts a visual server like before
Max
Postby Max » Sun Jun 10, 07 12:42 pm
l looked at the server.lod and this is the only thing l think is wrong
Log: D3D Driver: Supports FOURCC DXT4
Log: D3D Driver: Supports FOURCC DXT5
Init: D3D Detected: ATI video card
Init: D3D Driver: Supports trilinear
Init: D3D Driver: Supports specular gouraud
Init: D3D Driver: Supports BLENDDIFFUSEALPHA
Init: D3D Driver: Supports LOD biasing
Init: D3D Driver: Supports Z biasing
Init: D3D Driver: Supports D3DTOP_ADDSIGNED2X
Init: D3D Driver: Supports D3DTOP_BUMPENVMAP
Init: D3D Driver: Supports D3DTOP_DOTPRODUCT3
Init: D3D Driver: Supports D3DTOP_MODULATEALPHA_ADDCOLOR
Init: D3D Driver: Supports D3DTOP_MODULATECOLOR_ADDALPHA
Init: D3D Driver: Textures (1x1)-(2048x2048), Max aspect 2048
Log: Bound to Galaxy.dll
Init: Galaxy is using DirectSound
Init: EAX 1.x sound hardware found!
Init: Galaxy initialized
DevAudio: Galaxy SetViewport: WindowsViewport0
Init: Game engine initialized
Log: Startup time: 4.224795 seconds
DevMusic: Load music: Music NYCStreets_Music.NYCStreets_Music
LSPDT: 0.016673
Log: Loading: Package DXFonts
Log: Assigning Last Button Window to MenuUIMenuButtonWindow DXMP_Smuggler.MTLUNATCO0.DeusExRootWindow0.MTLMenuMain0.MenuUIClientWindow0.MenuUIMenuButtonWindow9
Log: Assigning Last Button Window to MenuUIActionButtonWindow DXMP_Smuggler.MTLUNATCO0.DeusExRootWindow0.MenuUIMessageBoxWindow0.MenuUIActionButtonBarWindow0.MenuUIActionButtonWindow1
Log: Tried to remove lastbuttonwindow descendant. MenuUIActionButtonWindow DXMP_Smuggler.MTLUNATCO0.DeusExRootWindow0.MenuUIMessageBoxWindow0.MenuUIActionButtonBarWindow0.MenuUIActionButtonWindow1
Log: appRequestExit(0)
Exit: Preparing to exit.
Log: Purging garbage
Log: Unbound to Engine.dll
Log: Unbound to Core.dll
Log: Unbound to Window.dll
Log: Unbound to DeusEx.dll
Log: Unbound to Extension.dll
Log: Unbound to ConSys.dll
Log: Unloading: Package DeusEx
Log: Unloading: Package Core
Log: Unloading: Package Engine
Log: Unloading: Package Extension
Log: Unloading: Package DeusExCharacters
Log: Unloading: Package DeusExUI
Log: Unloading: Package DeusExItems
l think that is were it goes wrong ?
Max
