Little bit more friendly Unreal ED
Postby ~ô¿ô~Nobody~ » Tue May 02, 06 8:26 pm
ok guys, i dunno if you still work with the unrealED1
but i still do it (because UED2 is even more unreliable) and it always pissed me off, that it just offers to save the maps as *.unr
yesterday i was finally tired of it and modified the editor's executeable in this way that its default save/load map ending is *.dx and not *.unr
if s'one cares i'll try to do the same with the unrealEd 2 hax for DX
Cheers, ~[A]Nobody~
DeusExEd.zip
UnrealED AKA DeusExED
(231.62 KiB) Downloaded 829 times
Postby Bob » Tue May 02, 06 11:00 pm
A good idea actually. I don't use the editor much anymore, but a UED2 version would be appreciated.
Postby Gishank » Fri May 05, 06 2:49 pm
Great tool!!!
But, it just seems the same as normall UED.
Postby ~ô¿ô~Nobody~ » Fri May 05, 06 6:10 pm
KLOP! #-o
it IS the normal UED
but i fixed the issue where the editor just offers to load/save maps with the unr extension (beside the *.* one) instead of a dx extension :!:
so now you can load/save maps easily with the dx extension how it should have been since its release
PS: i'm kinda disappointed that here exists such a lack of interest :cry:
Postby Allan » Fri May 05, 06 6:27 pm
Well, i'm sure glad that someone finally made the Unreal Editor properly support saving of DeusEx Files. Good Job Nobody :D
Postby DarkKnight » Fri May 05, 06 6:44 pm
~[A]Nobody~ wrote:KLOP! #-o
People don't usually get excited about small things like this untill they are subjected to having to do it a few hundred times. :/
Doesn't mean this is any less cool though. :gj:
Postby ~ô¿ô~Nobody~ » Fri May 05, 06 7:09 pm
ty :D
Postby MrBlackDX » Fri May 05, 06 7:18 pm
Maybe if some other things could be redone, like simply converting the mover class into the DeusExMover class, so you dont have to select DeusExMover
But yeah, its good you have done it mate
Postby Cozmo » Fri May 05, 06 7:22 pm
Noo!
I LIKE THE BUGGY MOVER CLASS! :D
Postby MainMan » Fri May 05, 06 9:23 pm
MrBlack wrote:Maybe if some other things could be redone, like simply converting the mover class into the DeusExMover class, so you dont have to select DeusExMover
NO. I use all types of mover. (Mover, DeusExMover, BreakableGlass/Wall, and custom movers of my own). It is fine the way it is.
Postby Magus » Mon May 08, 06 1:55 pm
No, that'd be good. He's not suggesting make the Mover class obsolete (Given that DeusExMover is a subclass of Mover, it'd be impossible to remove without completely recoding Deus Ex), he instead says that the 'Create Mover' button defaults to the 'DeusExMover' class as opposed to the 'Mover' class it descends from.
Magus
Postby MrBlackDX » Mon May 08, 06 3:22 pm
Magus wrote:No, that'd be good. He's not suggesting make the Mover class obsolete (Given that DeusExMover is a subclass of Mover, it'd be impossible to remove without completely recoding Deus Ex), he instead says that the 'Create Mover' button defaults to the 'DeusExMover' class as opposed to the 'Mover' class it descends from.
yeah...
i kindof meant MainMans tbh, but thats much better duder, im not exactly the worlds most knowledgable mapper, i didnt realise 'Mover' was still used for DX
Postby Andrievskaya Veronika » Sun Mar 11, 07 6:32 am
I've modified unrealEd.exe from UED2 for DeusEx, so now instead Direct3D it uses OpenGL.
For what? This will allow previewing huge textures in UED2 correctly (they blurred if larger then 512x512)
Note: you should have new OpenGL renderer for UT, put OPenGLDRV.Dll to your UED2 folder.
Also, UED2 switches to OpenGL faster then to Direct3D.
OpenGL/Software rendering mode can be switched using context menu of viewport :)
you can take modified UnrealEd.exe here:
http://veronika.ucoz.com/UnrealEd.zip
just put it to your UED2 folder.
Postby Karkian » Wed Mar 28, 07 2:15 am
i made i first map ever with unrealED 1 its called RTKM_Smuggler_AdvanceFuture you can get it at the RTK Forums:
z6.invisionfree.com/rtkclan
:D
Karkian
Postby Kaiden » Wed Mar 28, 07 6:22 pm
Quit advertising your clan/maps, especially in a section that doesn't involve it!
Postby Gishank » Wed Mar 28, 07 7:07 pm
~[A]Kaiden~ wrote:Quit advertising your clan/maps, especially in a section that doesn't involve it!
What about reviving near enough a year old topics?
Postby Karkian » Thu Mar 29, 07 2:39 am
fine then :D
Karkian
Postby ~¤Hit[+]Män¤~ » Thu Mar 29, 07 4:38 am
i always use unreal ed 1
Asus Blitz Formula
q6600 G0 revision
2gb of kingston hyper x ram pc 6400 800mhz
hd 2600 xt 512mg x2 crossfire
silverstone psu
Dell Ultrasharp 30"
~¤Hit[+]Män¤~
Postby Kaiden » Thu Mar 29, 07 4:40 pm
Wannabe mod! :wink:
Also, I didn't revive it, as this topic was revived on...Sun Mar 11, 2007 5:32pm, by an update, then Garman posted. :roll:
Postby Karkian » Fri Mar 30, 07 2:49 am
What's this about? im sorry i advertised okay :D
Karkian
