Basic DeusEx script explanations.
Postby Alex » Mon Jun 19, 06 11:51 am
In this topic, I will post random scripts, basic deus ex scripts, and explain what things do, and what some variables mean.
Postby Alex » Mon Jun 19, 06 12:06 pm
The first script, that can be seen below, is one of my favourites :)
// Sodacan.
class Sodacan extends DeusExPickup;
state Activated
function Activate()
// can't turn it off
function BeginState()
local DeusExPlayer player;
Super.BeginState();
The owner is the one who has this in his inventory. You must place DeusExPlayer() around it, to tell the script, that the owner must be a DeusExPlayer. Otherwise it will not find the function HealPlayer(), which is called further on in this script.
player = DeusExPlayer(Owner);
if (player != None)
player.HealPlayer(2, False);
It checks if the player exists, and if it does, it calls the function HealPlayer inside the player class. It has as variables 2 and False, the 2 is how much the player gets healed, and the False means that it wont give a medkit hiss, or recalculate the healing rate, when you activate it.
PlaySound(sound'MaleBurp');
This plays the oh so fun burping sound. No explanation needed?
UseOnce();
Whe you call this, the item gets deleted.
Begin:
maxCopies=10
bCanHaveMultipleCopies=True
bActivatable=True
ItemName="Soda"
ItemArticle="some"
PlayerViewOffset=(X=30.000000,Z=-12.000000)
PlayerViewMesh=LodMesh'DeusExItems.Sodacan'
PickupViewMesh=LodMesh'DeusExItems.Sodacan'
ThirdPersonMesh=LodMesh'DeusExItems.Sodacan'
LandSound=Sound'DeusExSounds.Generic.MetalHit1'
Icon=Texture'DeusExUI.Icons.BeltIconSodaCan'
largeIcon=Texture'DeusExUI.Icons.LargeIconSodaCan'
largeIconWidth=24
largeIconHeight=45
Description="The can is blank except for the phrase 'PRODUCT PLACEMENT HERE.' It is unclear whether this is a name or an invitation."
beltDescription="SODA"
CollisionRadius=3.000000
CollisionHeight=4.500000
Mass=5.000000
Buoyancy=3.000000
Now we involve the functions that get called in this script.
HealPlayer();
This can be found in DeusEx.DeusExPlayer.
// HealPlayer()
function int HealPlayer(int baseHealPoints, optional Bool bUseMedicineSkill)
As you can see, it has 2 variables in this function. The second one is optional, so you don't have to include this variable, so you can call this function on 2 ways:
HealPlayer(2);
HealPlayer(2,False/True);
local float mult;
local int adjustedHealAmount, aha2, tempaha;
local int origHealAmount;
local float dividedHealAmount;
These are variables that will be used in this function. You cannot call these variables outside the function, since it will not recognize them as declared variables. Take a good look at the word 'local'.
If you have bUseMedicineSkill = True in the function, it will recalculate the healing amount, since, if you have a high/low medkit skill, your medkit heals more/less.
if (bUseMedicineSkill)
adjustedHealAmount = CalculateSkillHealAmount(baseHealPoints);
else
adjustedHealAmount = baseHealPoints;
origHealAmount = adjustedHealAmount;
if (adjustedHealAmount > 0)
And if you use a medkit --> UseMedicineSkill, it will give the sound :)
PlaySound(sound'MedicalHiss', SLOT_None,,, 256);
// Heal by 3 regions via multiplayer game
if (( Level.NetMode == NM_DedicatedServer ) || ( Level.NetMode == NM_ListenServer ))
// DEUS_EX AMSD If legs broken, heal them a little bit first
if (HealthLegLeft == 0)
aha2 = adjustedHealAmount;
if (aha2 >= 5)
aha2 = 5;
tempaha = aha2;
adjustedHealAmount = adjustedHealAmount - aha2;
HealPart(HealthLegLeft, aha2);
HealPart(HealthLegRight,tempaha);
mpMsgServerFlags = mpMsgServerFlags & (~MPSERVERFLAG_LostLegs);
HealPart(HealthHead, adjustedHealAmount);
if ( adjustedHealAmount > 0 )
HealPart(HealthTorso, aha2);
HealPart(HealthArmRight,aha2);
HealPart(HealthArmLeft, adjustedHealAmount);
HealPart(HealthLegRight, aha2);
HealPart(HealthLegLeft, adjustedHealAmount);
else
HealPart(HealthTorso, adjustedHealAmount);
HealPart(HealthLegRight, adjustedHealAmount);
HealPart(HealthArmRight, adjustedHealAmount);
GenerateTotalHealth();
adjustedHealAmount = origHealAmount - adjustedHealAmount;
if (origHealAmount == baseHealPoints)
if (adjustedHealAmount == 1)
ClientMessage(Sprintf(HealedPointLabel, adjustedHealAmount));
else
ClientMessage(Sprintf(HealedPointsLabel, adjustedHealAmount));
else
return adjustedHealAmount;
I didn't explain this entire function, only parts. Otherwise this post will become too big.
The PlaySound() function, is declared in the Engine.Actor class.
native(264) final function int PlaySound
sound Sound,
optional ESoundSlot Slot,
optional float Volume,
optional bool bNoOverride,
optional float Radius,
optional float Pitch
Unfortunately, this is a native function. So that means that it is coded in Engine.dll.
You can see all variables here. It is not really important at the moment.
Now the function UseOnce();
This can be found in DeusEx.DeusExPickUp.
// UseOnce()
// Subtract a use, then destroy if out of uses
function UseOnce()
NumCopies--;
Reduce the number of copies you have
if (!IsA('SkilledTool'))
GotoState('DeActivated');
if (NumCopies <= 0)
Do you have 0 copies of the item? Or even less? Then destroy it. Also said, it will be deleted, and the item you will have in your hand, will be nothing.
if (player.inHand == Self)
player.PutInHand(None);
Destroy();
else
If you do have 1 or more copies of the item, update your belt, so you can see you used a sodacan.
UpdateBeltText();
Well, this is it kinda. I am not experienced with tutorials or whatsoever, so if something, even ANYTHING, is unclear, just ask! I will answer it :)
Postby MainMan » Mon Jun 19, 06 7:19 pm
Just a note of preference, but I think that it's easier to read when code is set out like this:
Function A()
   if(a != 0)
      if(a <= 5)
         Owned();
rather than
Function A()
if(a != 0)
if(a <= 5)
Owned();
Postby Alex » Mon Jun 19, 06 7:27 pm
I copy pasted the script straight from the file. And it doesn't show tabs in the forum :)
Postby DarkKnight » Mon Jun 19, 06 7:53 pm
~[A]lex~ wrote:I copy pasted the script straight from the file. And it doesn't show tabs in the forum :)
str_replace('\t', " ", $post);
You know it must be done.
Postby Allan » Mon Jun 19, 06 9:15 pm
But... using the Tab key switches from the text box, to the Preview box. So the only way to use Tab properly is to Copy/Paste it over and over.
Postby Imperial » Mon Jun 19, 06 9:24 pm
Could you explain the meanings of { and }, and what they represent?
Postby AgentSmyth » Mon Jun 19, 06 10:13 pm
Oh I know this one...
They are simply things that keep the code seperate from each other i.e.
Say you want to have 2 different functions...one to...I dunno set up a timer and the other to display the time you don't want the codes running into each other, so you put these at the beggining and end of each function to declare where each function starts and ends...it also works the same with the conditionals else, if, switch.
For example
function starttime()
Insert Code here
function show time()
if (insert condition here)
   insert events here
else
   insert events here
Hope that helped :lol:
AgentSmyth
Postby Mr. Tastix » Tue Jun 20, 06 5:43 am
Interesting... Very interesting... Is it allowed if we take notes of this?
Postby Alex » Tue Jun 20, 06 7:20 am
Quite logical eh :)
Postby Mr. Tastix » Tue Jun 20, 06 7:39 am
~[A]lex~ wrote:Quite logical eh :)
Yes, but that doesn't really answer my question, lol.
Postby Alex » Tue Jun 20, 06 7:40 am
Yes it's allowed... and that should be logical :)
Postby Dae » Tue Jun 20, 06 8:46 am
AgentSmyth wrote:Oh I know this one...
For example
Insert Code here
   insert events here
else
   insert events here
I use UltraEdit 32 with Unreal script highlighting. I highly recommend everyone to get this program - it's perfect!
Postby Alex » Tue Jun 20, 06 8:47 am
I use Notepad, without any thing extra :lol:
Postby DarkKnight » Tue Jun 20, 06 9:30 am
~[A]lex~ wrote:I use Notepad, without any thing extra :lol:
Syntax highlighting is the greatest thing since sliced bread.
Postby Allan » Tue Jun 20, 06 9:33 am
No, Deus Ex is the greatest thing since sliced bread, and syntax highlighting is the greatest thing since Deus Ex =)
But still, I'd say this is a program worth looking at =)
(Oh, and I use UnrealEd's compiler. It's just faster to pick up on my mistakes(And nowadays, I make a lot of them ;) ) )
Postby AgentSmyth » Tue Jun 20, 06 12:04 pm
my problem is i just don't know where to begin...or end...or write code...o god :shock:
-exports all the classes and looks through frantically-
Nope still nothing :P
AgentSmyth
Postby DarkKnight » Tue Jun 20, 06 2:40 pm
AgentSmyth wrote:my problem is i just don't know where to begin...or end...or write code...o god :shock:
The first thing anyone wanting to learn how to script or code should know is where to start.
In the case of DX, the first step you need to do is get DX to load it. From there, the rest is utility functions.
Also, Alex, could you PM me the smuggler code? I'm interested to see the UI code. :)
Postby MainMan » Tue Jun 20, 06 4:40 pm
Notepad all the way. Easy, loads in 2 seconds, and no fancy colours.
Postby Alex » Tue Jun 20, 06 4:57 pm
Yup, same. I don't care if my uccmake gives 569385 errors. I need to fix em anyways, so 1. Use uccmake to find em 2. Have more lag using a special uber 1337 notepad or w/e.
Postby AgentSmyth » Tue Jun 20, 06 5:05 pm
what do you's do for inspiration...and what would be the best and quickest way to learn scripting? :?
AgentSmyth
Postby Alex » Tue Jun 20, 06 5:25 pm
AgentSmyth wrote:what do you's do for inspiration...and what would be the best and quickest way to learn scripting? :?
I look at other games, or ideas just pop up.
And I looked at scripts, I read them. First I need to know what something does (Example, a switch), then I read the script. And understand every bit of it.
Postby Alistair » Sat Sep 16, 06 1:29 pm
Its good to understand Object Orientated Programming, or algebra to be simple
Postby Ayleth » Fri Nov 17, 06 6:46 am
WOTgreal all the way!!!111two. seriously, it supports running dx with special switches, syntax highlighting, reverse lookup (ctrl-click on a word will try to bring you to its first mention) find in active document, find in all files, dude theres just too much to say about it. Anyone who wants to get hooked up, go to www.wotgreal.com. i also have a goody for those who really like the program. >=+D
¨‘°ºMåsåmµñ£º°‘¨
˙•●●ĊђασsΪηcǻяйαѓε●●•˙
jason.unger@gmail.com
Ayleth
Postby Jon » Wed Mar 07, 07 11:47 pm
How about a gas grenade? I'd like to see how the damage and vision impairment codes are made.
Postby Alex » Fri May 25, 07 5:21 pm
Sorry Jon, for the late response. Here it is, I think. I might post it unfinished, and post the rest later on.
// GasGrenade.
class GasGrenade extends ThrownProjectile;
var float   mpBlastRadius;
var float   mpProxRadius;
var float   mpGasDamage;
var float   mpFuselength;
simulated function PreBeginPlay()
   Super.PreBeginPlay();
   if ( Level.NetMode != NM_Standalone )
      blastRadius=mpBlastRadius;
      proxRadius=mpProxRadius;
      Damage=mpGasDamage;
      fuseLength=mpFuseLength;
      bIgnoresNanoDefense=True;
    mpBlastRadius=512.00
    mpProxRadius=128.00
    mpGasDamage=20.00
    mpFuselength=1.50
    fuseLength=3.00
    proxRadius=128.00
    AISoundLevel=0.00
    bBlood=False
    bDebris=False
    DamageType=TearGas
    spawnWeaponClass=Class'WeaponGasGrenade'
    ItemName="Gas Grenade"
    speed=1000.00
    MaxSpeed=1000.00
    Damage=10.00
    MomentumTransfer=50000
    ImpactSound=Sound'DeusExSounds.Weapons.GasGrenadeExplode'
    LifeSpan=0.00
    Mesh=LodMesh'DeusExItems.GasGrenadePickup'
    CollisionRadius=4.30
    CollisionHeight=1.40
    Mass=5.00
    Buoyancy=2.00
As you can see, there is nothing special in this projectile class.
Only the "DamageType=TearGas" defines something that has to do with gas.
Then we look in the Parent Class (ThrownProjectile) for matches with "DamageType" and "TearGas". We vind a good match in the state "Flying". You can override functions in this state. With states you can actually define one function multiple times, giving it different coding. We look at the function Explode() in the state Flying. In there, there is this bit:
      if ((damageType=='TearGas') && (Role==ROLE_Authority))
         SpawnTearGas();
So if the damageType is TearGas, we call the function SpawnTearGas:
function SpawnTearGas()
   local Vector loc;
   local TearGas gas;
   local int i;
   if ( Role < ROLE_Authority )
      return;
   for (i=0; i<blastRadius/36; i++)
      if (FRand() < 0.9)
         loc = Location;
         loc.X += FRand() * blastRadius - blastRadius * 0.5;
         loc.Y += FRand() * blastRadius - blastRadius * 0.5;
         loc.Z += 32;
         gas = spawn(class'TearGas', None,, loc);
         if (gas != None)
            gas.Velocity = vect(0,0,0);
            gas.Acceleration = vect(0,0,0);
            gas.DrawScale = FRand() * 0.5 + 2.0;
            gas.LifeSpan = FRand() * 10 + 30;
               gas.bFloating = False;
            else
               gas.bFloating = True;
            gas.Instigator = Instigator;
We don't really need to know what it all does when we only want to know how someone gets damaged or get partially blinded. So we see something special:
"gas = spawn(class'TearGas', None,, loc);".
The class "TearGas" is being spawned! So we open up that class.
// TearGas.
class TearGas extends Cloud;
    DamageType=TearGas
    maxDrawScale=2.00
    Texture=WetTexture'Effects.Smoke.Gas_Tear_A'
As you can see, the DamageType is defined here aswell. The class is quite small, so we take a look at the parent class, Cloud.
We search for matches with "DamageType", as we don't get any results when we search for "TearGas".
We find this:
function Timer()
   local Actor A;
   local Vector offset, dist;
   local Pawn apawn;
      // Use PawnList for multiplayer
      apawn = Level.PawnList;
      while ( apawn != None )
         dist = apawn.Location - Location;
         if ( VSize(dist) < cloudRadius )
            offset = apawn.Location;
            apawn.TakeDamage( Damage, Instigator, offset, vect(0,0,0), damageType );
         apawn = apawn.nextPawn;
   else
      // check to see if anything has entered our effect radius
      // don't damage our owner
      foreach VisibleActors(class'Actor', A, cloudRadius)
         if (A != Owner)
            // be sure to damage the torso
            offset = A.Location;
            A.TakeDamage(Damage, Instigator, offset, vect(0,0,0), damageType);
As you can see, the damage giving part is in Timer. This function has been activated in another function:
function BeginPlay()
   Super.BeginPlay();
   // set the cloud damage timer
   SetTimer(damageInterval, True);
This means, the timer will run every damageInterval seconds, and it will loop, since that is set to True.
damageInterval=1.00, it is in the defaultproperties.
So we see that the timer checks every second if there are things in the radius that can be damaged, if so, damage it!
I will continue writing this later. But as you can understand TakeDamage() creates the damage part. If I can recall correctly, if you do a TakeDamage() with TearGas or Poison as damagetype, you get poisoned. But we'll see that later!
Postby Ayleth » Fri May 25, 07 7:04 pm
Nice work.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Andrievskaya Veronika » Sat Aug 18, 07 12:37 pm
I'd like to know, what these functions are doing (detailed if possible :) :D ):
(from CORE\Object.uc)
native(192) static final function     float Loge  ( float A );
native(193) static final function     float Sqrt  ( float A );
native(194) static final function     float Square( float A );
native(195) static final function     float FRand ();
native(244) static final function     float FMin  ( float A, float B );
native(245) static final function     float FMax  ( float A, float B );
native(246) static final function     float FClamp( float V, float A, float B );
native(247) static final function     float Lerp  ( float Alpha, float A, float B );
native(248) static final function     float Smerp ( float Alpha, float A, float B );
especially about FRand , FMin, FMax and FClamp.
Postby Alex » Sat Aug 18, 07 12:58 pm
Postby Dae » Sat Aug 18, 07 12:59 pm
I only knew loge, sqrt, square, frand, the rest had to look up here.
Andrievskaya Veronika wrote:Loge
natural logarithm (натуральный логарифм)
Andrievskaya Veronika wrote:Sqrt
it's the same even in Pascal!
square root (квадратный корень)
Andrievskaya Veronika wrote:Square
returns value in 2nd power (возводит в квадрат)
Andrievskaya Veronika wrote:FRand
a random number from 0 to 1 (рандомизатор от нуля до единицы)
FMin/FMax return the lower/higher values from A and B
(сравнивает A и B и возвращает либо максимальное (Fmax), либо минимальное значение (fmin))
Andrievskaya Veronika wrote:FClamp
wiki.beyondunreal.com wrote:If V is smaller than A, A is returned. If V is larger than B, B is returned. In any other case V is returned.
Andrievskaya Veronika wrote:Lerp
wiki.beyondunreal.com wrote:"Returns the linear interpolation between A and B."
The return value is calculated through something like this:
(B - A) * Alpha + A
Andrievskaya Veronika wrote:Smerp
wiki.beyondunreal.com wrote:Returns an Alpha-smooth nonlinear interpolation between A and B.
The return value seems to be calculated through something like this:
(-2 * (B - A) * Alpha ** 3) + (3 * (B - A) * Alpha ** 2) + A
