[MUTATOR] AntiTK — protects players from teamkillers
Postby Gishank » Sat Aug 19, 06 9:12 am
Erm, didn't MaceWindy quit DXMP ages ago :-/
Postby Dae » Sat Aug 19, 06 9:15 am
Allan wrote:One thing though, what would happen if you die while the screen is up?
You remember a screen with big red text "You have been killed by someone" and "Press <fire> to restart"? You get this message on top of it. As soon as you press either no or yes you respawn. So you cannot be killed while the screen is up because you're already dead.
Postby clyzm » Sat Aug 19, 06 10:19 am
Sh¤gån wrote:Erm, didn't MaceWindy quit DXMP ages ago :-/
It was Dae aliasing.
Postby Dae » Sat Aug 19, 06 12:44 pm
There is a mistake in notice messages: there should be "has" instead of "have" :oops:
Postby Bob » Sat Aug 19, 06 11:47 pm
Have makes more sense Dae.
"You has been killed..." doesn't really make sense, improper use of English
:gj:
Postby Zantinzuken » Sat Aug 19, 06 11:48 pm
Unless he wanted to go for the chav look....
Doubt it lol. Nice mod.
Postby Dae » Sun Aug 20, 06 8:28 am
No, it's like
~[A]Daedalus~ have chosen not to punish you :oops:
Postby Jon » Sun Aug 20, 06 10:56 am
Bob wrote:Have makes more sense Dae.
:gj:
You mock my English skill?!
don't worry about it, apart from one small error, the text side of things is spot on - I made sure of it. Turned out great, too - nice one, Dae
Postby Bob » Sun Aug 20, 06 1:28 pm
~[A]Daedalus~ wrote:No, it's like
Oh right, well yeah, that doesn't make much sense either.
Postby Allan » Sun Aug 20, 06 4:15 pm
It also does it for if you do get punished. "Allan have chosen to punish you..."
It sounds a bit like something Yoda would say.
Postby MainMan » Sun Aug 20, 06 4:32 pm
Wow I like the yes/no window feature, very nice. Source code again :wink:?
A lot of stuff has hapenned while I have been away :o
Postby Dae » Sun Aug 20, 06 4:34 pm
The source wasn't protected. Download and watch :)
Postby rjjb » Tue Aug 22, 06 6:53 am
Cool!
Put my skyline server back up for a bit.. the deathmatch bug's fixed (much thanks there, that's how I usually keep skyline). Haven't been on the server with others in team mode, but server logs show someone getting kicked. (tsk .. tsk..)
Good stuff.. much thanks. :)
rjjb
Help
Postby {SKC}Knights » Mon Jun 25, 07 10:51 pm
when tried to host this Error cam up and Dx closed.
can you help. Please
DXMTL: Add mutator MMAntiTK101.AntiTKMutator
Critical: appError called:
Critical: AntiTKMutator DXMS_SunTemple.AntiTKMutator1 (Function Engine.Mutator.AlwaysKeep:0000) Infinite script recursion (250 calls) detected
Critical: Windows GetLastError: There are no more files. (18)
Critical: FFrame::Serialize
Critical: UObject::ProcessEvent
Critical: (LevelInfo DXMS_SunTemple.LevelInfo0, Function Engine.LevelInfo.PreBeginPlay)
Critical: BeginPlay
Critical: UGameEngine::LoadMap
Critical: LoadURL
Critical: UGameEngine::Browse
Critical: UGameEngine::Init
Critical: XGameEngineExt::Init
Critical: DDeusExGameEngine::Init
Critical: InitEngine
Exit: Exiting.
Uninitialized: Log file closed, 06/25/07 22:29:39
{SKC}Knights
Founder/Clan / Leader
http://www.skullknightsclan.niceboard.com
{SKC}Knights
Postby Dae » Tue Jun 26, 07 8:33 am
Postby {SKC}Knights » Fri Jun 29, 07 12:19 am
Thank you.
{SKC}Knights
{SKC}Knights
Postby {SKC}Knights » Sat Jun 30, 07 8:03 pm
still cant run this Mod. what the hell can i do. I cant see to reslove this problem.
can [A} Help ..
{SKC}Knights
{SKC}Knights
Postby Dae » Sat Jun 30, 07 9:43 pm
{SKC}Knights wrote:still cant run this Mod. what the hell can i do. I cant see to reslove this problem.
Disable the mutator in "mutators" menu, where you enabled it. If that doesn't help, go to DeusEx/System and attach here DeusEx.ini (to attach a file, press "post reply" button in the left bottom corner).
Return to alpha laboratories
