Getting the name of a map? and other frustrating stuff
Postby Ayleth » Tue Apr 24, 07 7:23 pm
should this work for getting the name of a map thats currently loaded on the server?
 foreach allactors(class'DeusExLevelInfo',info)
        MapName=Info.MapName;
apparently its not working for me :(
Also, i want some fars, vectors, to show up in Advanced options.
i have this in the .int:
Preferences=(Caption="Portal Settings",Parent="Advanced Options",Class=Portalv1.PortalController,Immediate=True)
and some of the vars show up well but there are others, related to a portal spawner that im making, that all read zeroed out. heres the code for the controller:
class PortalController extends actor config (Portal);
var config bool bLimitedPortalNumbers;
var config int MaxPortals;
var config bool bAllowSummon;
var config bool bMakeSound;
struct MapOne
    var config vector portalLocations[20];
    var config String MapName;
var config MapOne Map1;
struct MapTwo
var config MapTwo Map2;
struct MapThree
var config MapThree Map3;
struct MapFour
var config MapFour Map4;
struct MapFive
var config MapFive Map5;
The Struct formation appears no problem, but theres no info even when the .ini has the settings in it.
Sorry for the length.
ALSO...
i have serveractors=Portalv1.PortalSpawner in my DX.ini but this actor doesn't get spawned in the game? if i do killall for the spawner, says its not even on the server, and if i summon it ingame, then it works fine??
¨‘°ºMåsåmµñ£º°‘¨
˙•●●ĊђασsΪηcǻяйαѓε●●•˙
jason.unger@gmail.com
Ayleth
Postby Dae » Tue Apr 24, 07 8:10 pm
Maybe this would answer your question about a map name?
What kind of actor is that? Paste some pieces of code (definition, postbeginplay).
Postby Ayleth » Tue Apr 24, 07 8:36 pm
hmmm, you just made me think i need to use postbeginplay, im using pre atm.
class PortalSpawner extends Actor config (portal);
ugh... ilike i said, im using pre. needs to be post? the thing is it seems like its not even getting spawned. killall returns none.
function prebeginplay()
    local int i;
    local int m;
    local string MapName;
    local DeusExLevelInfo info;
    SummonController();
    if (MapName==Controller.Map1.MapName)
            for (i=0;i<10;i++)
                if (controller.Map1.portalLocations[i]!=vect(0,0,0))
                    spawn(class'portal',self,,controller.Map1.PortalLocations[i]);
    else if (MapName==Controller.Map2.MapName)
            for (i=0;i<10;i++)
                if (controller.Map2.portalLocations[i]!=vect(0,0,0))
                    spawn(class'portal',self,,controller.Map2.PortalLocations[i]);
    else if (MapName==Controller.Map3.MapName)
            for (i=0;i<10;i++)
                if (controller.Map3.portalLocations[i]!=vect(0,0,0))
                    spawn(class'portal',self,,controller.Map3.PortalLocations[i]);
    else if (MapName==Controller.Map4.MapName)
            for (i=0;i<10;i++)
                if (controller.Map4.portalLocations[i]!=vect(0,0,0))
                    spawn(class'portal',self,,controller.Map4.PortalLocations[i]);
                    break;
    else if (MapName==Controller.Map5.MapName)
            for (i=0;i<10;i++)
                if (controller.Map5.portalLocations[i]!=vect(0,0,0))
                    spawn(class'portal',self,,controller.Map5.PortalLocations[i]);
btw thanks for the link, will check that out.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Ayleth » Tue Apr 24, 07 9:20 pm
hmmm the info in that link didn't work... sorry. Well atlantis is sending me a bit of code that he recieved... i'll see how that works
EDIT: ahh yes, ok heres the code that Atlantis found in a patch for his SG map provided by nobody:
left(string(level),instr(string(level),"."))
This will return the string of the current map. i did not realise the level var returned the mapname :S :oops:
OK, so what about the var not appearing problem? Ive never had this.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Dae » Wed Apr 25, 07 7:08 am
Did you try with PostBeginPlay?
Postby Ayleth » Wed Apr 25, 07 9:43 pm
yes i did. the thing is apparently the actor is not being called? like as if it were not even in the dx.ini.
EDIT: just checked my log, as i added a log function to see if its actually getting installed, and it IS, but i get 5 Illegal Array element errors. i will post the whole summoner code.
PortalSpawner.uc
the spawner
(2.12 KiB) Downloaded 295 times
portalcontroller.uc
the controller
(888 Bytes) Downloaded 341 times
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Dae » Thu Apr 26, 07 8:00 am
I may mix something up, but aren't we disallowed to use arrays inside struct ?
Postby Ayleth » Thu Apr 26, 07 8:00 pm
i did it on my admintool... well its not working here. I have abandoned the summoner for now... i will either include it in my second release, or will have it as a second package. First Release is now out.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
