server problems
server problems
Postby (eGo)CrimsonKing » Thu Jun 07, 07 5:32 pm
my server wont work.It keeps closing be4 it starts.
i need help
Last edited by (eGo)CrimsonKing on Thu Jun 07, 07 5:34 pm, edited 1 time in total.
Fanatics are picturesque, mankind would rather see gestures than listen to reasons.
~ Friedrich Nietzsche
DeusEx Files Archive
Take the Magic: The Gathering 'What Color Are You?' Quiz.
Da-shiang bao-tza shr duh lah doo-tze.
(eGo)CrimsonKing
Postby Dae » Thu Jun 07, 07 5:37 pm
DeusEx.ini
(15.11 KiB) Downloaded 484 times
Postby (eGo)CrimsonKing » Thu Jun 07, 07 5:53 pm
It still closes so i guess it didnt work
but thank anyway
(eGo)CrimsonKing
Postby Dae » Thu Jun 07, 07 6:35 pm
I wonder why do newbie server hosters always put so many mods to ServerPackages and EditPackages? You don't need to add EVERY mod you have to ServerPackages unless you want to spawn stuff from it. If a map requires some mod, you don't need to add it there EITHER. You don't need to add CaroneElevatorSet either, because it's only a tool for mappers!
When you add stuff to serverpackages= people that dont have that stuff, will be downloading it from your server, thus causing lag. Leave only those mods, which you use very often.
Moreover,
ServerPackages=Portalv101
and a few lines below
these are two versions of one mod. What for?
EditPackages array is mostly for mappers and modders and you don't need to add anything to it for hosting purposes.
Try again.
DeusEx.ini
(15.08 KiB) Downloaded 637 times
Postby Ayleth » Thu Jun 07, 07 7:11 pm
o.O be aware that the portal mod has a very serious native error that crashes servers randomly.
¨‘°ºMåsåmµñ£º°‘¨
˙•●●ĊђασsΪηcǻяйαѓε●●•˙
jason.unger@gmail.com
Ayleth
Postby (eGo)CrimsonKing » Thu Jun 07, 07 7:23 pm
YAY
finally it works
Thanks Dae and Thanks Masamune 4 the creaton of the admin tool
:p and i play as {C}KingJames on mmcity
(eGo)CrimsonKing
Postby Ayleth » Thu Jun 07, 07 7:24 pm
lol no problem for the admintool.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Magus » Thu Jun 07, 07 9:02 pm
I fucking hate CaroneElevatorSet.
As far as mods go, it's not a bad one, but there's just too many damn versions of it floating around. Which is why I'm never going to use it.
Magus
Postby Aidan » Thu Jun 07, 07 9:10 pm
I agree, when It was updated for the second time, the creator also could have named it something different then "CaroneElevatorSet" like they did the previous version so users wouldn't receive "VERSION MISMATCH" because the carone elevator set version used in a map in someones server isn't the same as the one version someone else has in their system file.
Anyways, we're getting off-topic here and I believe this problem is solved.
Postby Magus » Thu Jun 07, 07 10:30 pm
Yea... one day I'll just take it upon myself to rename the damn thing in the unlikely event I ever want to use it in a map.
Magus
Postby MainMan » Thu Jun 07, 07 10:54 pm
I used it in MMCity, I just imported it into my mod package, to avoid mismatches.
Postby (eGo)CrimsonKing » Fri Jun 08, 07 2:48 am
...anyways it dosent work again 4 some gay reason
so here is the new ini(This is getting anoying>.<)
Last edited by (eGo)CrimsonKing on Fri Jun 08, 07 2:53 am, edited 1 time in total.
(eGo)CrimsonKing
Postby Dae » Fri Jun 08, 07 9:00 am
Remove
ServerPackages=AllanTeleporter
and it will work
Postby (eGo)CrimsonKing » Sat Jun 09, 07 3:47 am
Why dont allanteleporter work???
It used to...
(eGo)CrimsonKing
Postby Dae » Sat Jun 09, 07 9:04 am
I dunno, maybe because its incompatible with some maps or gametypes (like, StarGate)?
Postby (eGo)CrimsonKing » Sat Jun 09, 07 7:46 pm
ohhh,ok anways thanks to all for helping me :P
(eGo)CrimsonKing
Users browsing this forum: No registered users and 14 guests
