[SNIPPET] DX-IRC
[SNIPPET] DX-IRC
Postby Alex » Wed Jul 04, 07 12:31 pm
// Link. IRC Tryout
class Link extends TCPLink config (IRC);
var config string Server;
var config string Channel;
var config string Username;
var config int Port;
function PostBeginPlay()
  local Spec _Spec;
  _Spec = Spawn(Class'Spec');
  if(_Spec != None)
    _Spec._IRC = self;
  Super.PostBeginPlay();
  StartLink();
  SetTimer(20.0,True);
function Timer()
  SendCommand("NICK"@Username); // An ugly hack. To prevent time-outs.
function StartLink()
  Resolve(Server);
event ResolveFailed()
  Log("Error, resolve failed");
event Resolved( IpAddr Addr )
  Addr.Port = Port;
  BindPort();
  ReceiveMode = RMODE_Event;
  LinkMode = MODE_Line;
  Open(Addr);
event Opened()
  SendCommand("USER Console hostname servername :Console");
  SendCommand("JOIN"@Channel);
function SendMessage(string _Msg)
  SendCommand("PRIVMSG"@Channel@":"$_Msg);
function SendCommand(string _Command)
  SendText(_Command $ Chr(10));
event ReceivedLine( string Line )
  local string       _Original;
  local string       _Sender;
  local string       _TmpString;
  local DeusExPlayer    _Player;
  _Original = Line;
  Line = Left(Line,Len(Line)-2);
  // This part here, is the command part. It parses the text send from IRC to DX, and as you can see, it already has 2 command's installed (!talk & !players)
  // It's quite old, so please forgive me for the un-tidyness of the code :P
  if(instr(Line, "PRIVMSG"@Channel@":") != -1)
    Line = Right(Line, Len(Line)-instr(Line,"PRIVMSG"@Channel@":")-Len("PRIVMSG"@Channel@":"));
    _Sender = Left(_Original, InStr(_Original,"!"));
    _Sender = Right(_Sender, Len(_Sender)-1);
    if(Left(Line,6) == "!talk ")
      Line = _Sender$"(IRC):"@Right(Line, Len(Line)-6);
      ForEach AllActors(class 'DeusExPlayer', _Player)
        if(_Player != None)
          _Player.ClientMessage(Line, 'Say', True);
    else if(Left(Line,8) == "!players" && Left(Line,9) == "!players")
        if(_Player != None)
          _TmpString = _TmpString$_Player.PlayerReplicationInfo.PlayerName$"("$_Player.PlayerReplicationInfo.PlayerID$"), ";
      if(Len(_TmpString) == 0)
        _TmpString = "None...";
      else
        _TmpString = Left(_TmpString, Len(_TmpString)-2);
      _TmpString = "Online Players:"@_TmpString;
      SendMessage(_TmpString);
  Server="server here"
  Channel="#channel"
  Username="username"
  Port=6667
And to send messages from DX into the IRC server, you must use a spectator class:
// Spectator.
class Spec extends MessagingSpectator;
var IRC _IRC;
function ClientMessage(coerce string S, optional name Type, optional bool bBeep)
  _IRC.SendMessage(S);
It should work, I had to edit it partially because I have it a bit differently.
But... It's not really useable. I tried it, and my bot got kicked by the irc server (SERVER, not CHANNEL ;)) for flooding, because there were a lot of messages send by DX to IRC. And almost noone uses IRC here anyways... but I just wanted to post it :P
EDIT: Fixed a small bug.
Postby Dae » Wed Jul 04, 07 12:45 pm
the script is damn good
Postby Alex » Wed Jul 04, 07 12:48 pm
Hehe, just fixed a small bug =/ :P Should work now.
Postby Dae » Wed Jul 04, 07 1:00 pm
Isn't there some "ping? pong!" action in IRC? In earlier versions of mIRC in network status those messages were constantly appearing (now they're hidden by default).
Postby Alex » Wed Jul 04, 07 1:08 pm
Hmm, I don't think so. At least, the server should ping me, and the bot always timed out.
Postby Dae » Wed Jul 04, 07 1:15 pm
maybe the bot should ping the server ?
also, found that option in mIRC: untick "hide ping/pong events" in Alt + O > IRC > Options
Postby ~ô¿ô~Nobody~ » Wed Jul 04, 07 2:10 pm
OH, is that the hax DX irc chat thing? :D
Postby Alex » Thu Jul 05, 07 11:40 am
I don't know if the bot pings the server. Another thing by the way: The script was synchronized on quicknet.nl (the irc server), so I'm not sure if it works on other irc servers.
