Is. This. Possible
Is. This. Possible
Postby -=BrotherBear=- » Fri Sep 21, 07 5:16 pm
i was thinking of making an underwater map, and including [A]Nobody's rings... IS IT POSSIBLE to create an object of some sort, to be able to respawn and teleport through the rings, (eg spawning at a underwater ring) and spawning some plain water at the other end where it just drops...
is it possible?
Sith....Jedi... All but mere titles... there is only one true God... and he is writing this now.
-=BrotherBear=-
Postby Jon » Fri Sep 21, 07 11:50 pm
Want a simple answer? No.
Postby -=BrotherBear=- » Fri Sep 21, 07 11:52 pm
Jon[A] wrote:Want a simple answer? No.
*cries*
so theres no way to make a water fragment?? like flesh or wood?
-=BrotherBear=-
Postby Kaiden » Fri Sep 21, 07 11:56 pm
Engine isn't advanced enough. Klop can re-make the engine though, ask him (Actually joking, dw)
Postby -=BrotherBear=- » Fri Sep 21, 07 11:57 pm
*sigh*
i was really hoping this was possible
-=BrotherBear=-
Postby Shinobi » Sat Sep 22, 07 12:14 pm
Welcome to my world =/
Postby ~ô¿ô~Nobody~ » Sat Sep 22, 07 4:23 pm
No, you cannot teleport water, but you can place a ring transporter in the water, though.
Postby Magus » Sat Sep 22, 07 7:15 pm
I think he was referring more to a dripping effect when using an underwater transporter to go to one above ground.
You know, like in Real Life (TM)
Magus
Postby Shinobi » Sat Sep 22, 07 9:32 pm
Possible or not, it's a cool idea.
PS: Magus - what maps have you made that I woulda heard of?
Re: Is. This. Possible
Postby Alex » Sat Sep 22, 07 9:35 pm
-=BrotherBear=- wrote::)
is it possible?
It's possible, but would require quite some coding, would be too much effort for a small thing, sorry.
Postby -=BrotherBear=- » Mon Sep 24, 07 11:09 am
meh ive had a looooong weekend to think of this (cant usually get on a pc weekends)
and what if i made a mover, 2sided transparent, portal and waterzone inside.. and make only 1 set of rings above water... then set the water mover to move into place instantly when the rings are triggered.. will that work?
-=BrotherBear=-
Postby Andrievskaya Veronika » Mon Sep 24, 07 11:53 am
I think you cannot make water zone inside mover :)
Postby ~ô¿ô~Nobody~ » Mon Sep 24, 07 12:40 pm
At least you cannot convert a zone-portal into a mover and expect that it still works as zone-portal. :lol:
Postby -=BrotherBear=- » Mon Sep 24, 07 2:32 pm
ok me and nobody have made other plans... while hes picking apples ill post this here...
how do i make a waterzone triggerable?? (eg press a button and the water is gone!)
EDIT:
hehehe build a huge pool, place damage triggers or crushers at the botton and press a button and u fall into certain death *evil laugh*
ooo new rank: Forum Poster
-=BrotherBear=-
Postby Dae » Mon Sep 24, 07 2:43 pm
-=BrotherBear=- wrote:how do i make a waterzone triggerable?? (eg press a button and the water is gone!)
http://wiki.beyondunreal.com/wiki/Rising_Water_(UT)
(copy & paste that in URL field of your browser)
Postby -=BrotherBear=- » Mon Sep 24, 07 2:46 pm
thanks a lot Dae
um... can i ask why LKJAY/alex+ a few others have been banned while ive been gone o.O
-=BrotherBear=-
Postby Shinobi » Mon Sep 24, 07 4:01 pm
The water appeared and drowned them all.
I blame YOU, and your water triggers =/
Postby Legion » Mon Sep 24, 07 5:08 pm
-=BrotherBear=- wrote:*sigh*
Well, you might be able to southern rig something. You can use a partical generator to make water drip, place it under the teleporter, and set the movement tag to whatever you name that teleporter.. that's about the best you're going to get with this shitty engine. But if you do that to much, you'll start running into lag issues.. in otherwords, don't use 2000 of the things. In fact, I wouldn't really go with that idea since I haven't even tested it, i'm just kinda throwing it out there.
Legion
Postby -=BrotherBear=- » Tue Sep 25, 07 10:35 am
OK
ive ALMOST done what NEARLy everyone says is immpossible...
just one problem
i cant make the triggerwaterzone :(
i did make it and when i load unrealed i get this:
EDIT:
also how do i fix BSP holes?
HELP ME
Last edited by -=BrotherBear=- on Tue Sep 25, 07 11:52 am, edited 1 time in total.
-=BrotherBear=-
Postby Shinobi » Tue Sep 25, 07 12:44 pm
Fixing BSP holes á la Wolf: http://unreal.gamedesign.net/bspfaq.html
I found it helped, anyway.
Postby -=BrotherBear=- » Tue Sep 25, 07 1:17 pm
Shinobi wrote:Fixing BSP holes á la Wolf: http://unreal.gamedesign.net/bspfaq.html
i read it and it says u can find the holes in UED...
they are NOT in UED just in game. and its only movers, and after they've moved i get the errors
-=BrotherBear=-
