Deus Ex Key bind tool
Postby Andrievskaya Veronika » Sat Mar 22, 08 11:52 am
I've made a little program, and think those who changes key bindings in User.ini will find it useful.
It allows to bind commands to keys easier than editing User.ini in the text editor :)
Warning: before running the program, make backup copy of your User.ini file!!!
Using
The interface is very simple--select a key in the list, then type command or commands (separating each one with | ), in the edit field, then do that with other keys when necessary.
Notes:
  • All changes are saved immediately, when you're typing text in the edit field. There is no undo for now .
  • There is no list of the commands that can be bound to keys, but you're can post it here and i'll add it in the next version :)
Installation
Place the program into your DeusEx/System/ directory.
Download
Click here to download!
Last edited by Andrievskaya Veronika on Sat Mar 22, 08 11:59 am, edited 2 times in total.
Postby Siva » Sat Mar 22, 08 12:28 pm
Fookin' yes!
Well done.
Postby CyberKill » Sat Mar 22, 08 1:41 pm
Winner. 5/5.
CyberKill
CyberKill
Postby or 1=1 » Sat Mar 22, 08 4:05 pm
Delphi ftw
Cheap Bitch
or 1=1
Postby Mastakilla » Sat Mar 22, 08 5:19 pm
Thanks :D
Postby Tonnochi » Sat Mar 22, 08 5:46 pm
This is amazing. Good work.
Postby Dex » Sat Mar 22, 08 6:05 pm
Good job.
Postby clyzm » Sat Mar 22, 08 9:24 pm
All is well with the cosmos.
Postby Andrievskaya Veronika » Sun Mar 23, 08 8:45 am
I've built a new version.
Changes
  • Added lot of commands to list
  • Added a button that creates a shortcut to the program on your Desktop.
  • Added DX icon :)
Download
The download link is same as in first post, or you're can click here to download the new version.
Last edited by Andrievskaya Veronika on Sun Mar 23, 08 8:48 am, edited 1 time in total.
Postby Andrievskaya Veronika » Sat Apr 05, 08 11:17 am
I've uploaded a new version.
Changes:
  • You can cancel all changes what you made. I'm planning to improve this function (make something like multi-level undo)
  • If you cannot find a key in the list, you can use search (sometimes i'm lazy to scroll the list, so i added this feature :) ) :)
  • Only one instance of the program can be used (i.e. you cannot run more than one).
  • Some changes in the interface
Download:
Use link in first post to download, or click here
(57.67 KiB) Downloaded 4819 times
Postby Mr. Tastix » Sat Apr 05, 08 12:02 pm
YOU ARE FUCKING OWNT MAN. Brilliant work!
Postby Psycho » Sat Apr 05, 08 12:14 pm
Wow Very Nice, That must of been hard.
Postby Andrievskaya Veronika » Sat Apr 05, 08 1:28 pm
Thanks for comments :) I'm glad that you're using my program :)
Postby {17}agentsmith » Sat Apr 05, 08 7:39 pm
very good program :)
{17}agentsmith
Postby Mastakilla » Sat Apr 05, 08 8:28 pm
Very handy, thank you very much :)
Postby Osiris » Sat Apr 05, 08 9:47 pm
Nice work! luuv the readme :)
TECH INFO:
About what?
Maybe add a way to edit the default actions in the pull down menu (ie if you enter one, it remembers it, and saves to ini?
Osiris
Postby Andrievskaya Veronika » Sun Apr 06, 08 2:49 am
Thanks for suggestion! I will try to do that in the next version :)
Also i'm planning to make editor for key aliases, i mean these lines:
Aliases[18]=(Command="Button bAltFire | AltFire",Alias=AltFire)
Last edited by Andrievskaya Veronika on Sun Apr 06, 08 2:55 am, edited 1 time in total.
Postby Osiris » Sun Apr 06, 08 2:59 am
Awesome!
(Is that you in your DP?)
Osiris
Postby Psycho » Sun Apr 06, 08 1:37 pm
DP? = Dispaly Picture? aka avatar?
Postby Osiris » Sun Apr 06, 08 4:08 pm
Si Señor!
Osiris
Postby ~DJ~ » Tue Apr 08, 08 3:42 am
Nice! handy tool!
but there is one problem....:(
The crosshair dont toggles with the toggle bind :(
Postby Andrievskaya Veronika » Fri Apr 11, 08 9:17 am
I've compiled a new version. Key Aliases Editor has been added. I'm planning to add more improvements, like history lists, adding own commands to the list, etc.
Using Key aliases editor
Its very easy to use. Click on alias (or find unused entry in the list) what you want to edit, make changes in two edit fields below, and click on "Save Alias" button. Then use the alias name as command in Key Binding mode.
Download
Use link in the first post, or click here
(61.27 KiB) Downloaded 4618 times
1.1.1.100
Postby Andrievskaya Veronika » Fri May 02, 08 10:21 am
I've uploaded new version of the program.
There is some improvements, additions, and so on. Download new version and check it out :)
Please check README for details.
I'm planning to redesign some things in the interface later (probably in the next version).
Download
Use download link in the first post.
Users browsing this forum: No registered users and 46 guests
