keypad is secure??
keypad is secure??
Postby CvendaCZ » Mon Oct 20, 08 1:56 pm
i have got problem.If i will click on keypad and add code,i have got : Its secure.
CvendaCZ
Postby Dae » Mon Oct 20, 08 3:26 pm
The standard keypads only work in the singleplayer.
You need some custom mod, like DF Keypad or FL Keypad.
FLKeypad.zip
(8.92 KiB) Downloaded 374 times
Postby CvendaCZ » Tue Oct 21, 08 2:41 pm
thx :)
Edit:and what i must do? i add password in settings and set it on no hack,but.....its secure
CvendaCZ
Postby Dae » Tue Oct 21, 08 3:16 pm
I think you should add MPServerPad to your map,
then set its tag to, for example, KakashiKP1,
then in FLKeypad.ini set KeypadTags[0]=KakashiKP1,
then find KeypadCodes[0] and set a key code.
Postby CvendaCZ » Tue Oct 21, 08 3:55 pm
:( no working :(
CvendaCZ
Postby Dae » Tue Oct 21, 08 4:56 pm
I'm unable to help if you're unable to specify the details of the problem.
Postby ~ô¿ô~Nobody~ » Fri Oct 24, 08 5:15 pm
FLKeypad3 is the only secure one.
Postby Dae » Fri Oct 24, 08 5:23 pm
There is no doubt in that buddy; the question for Kakashi-251 is how to actually use it on the map instead of the standard Deus Ex keypad which doesn't work in multiplayer.
