About Textures: Having trouble while making PINK transparent.
Postby ~DJ~ » Tue Apr 21, 09 11:12 am
Okay, I've tried the Tack's tutorial about how to make PINK transparent, But I fail, Yes, My backround has R=255 G=0 B=255, And everything is fine, I use photoshop CS3, And I need serious help about this-- I fail every time..
So, Yeah, I am making a crosshair, and its NOT transparent.. :/
So how will I make PINK transparent? in CS3.
Thanks in advance!
Postby VodunLoas » Tue Apr 21, 09 11:35 am
Don't worry about the pink and all them other colors. I tried many tutorials and I failed at making a masked texture. I figured it out though. Ok lets say you have a layer with what you want shown. Now the parts you want to mask should just be empty, no color or background. Now go to Image/Mode/Index color and choose Local (selective) from the Palette, and make sure transparency is checked. You may want to change the Matte color to what you think blends in with what your using it on, usually black. Press OK. Now go to File and Save As, and select the format to be .pcx. Now save it, and import it. Thats it.
Postby ~DJ~ » Tue Apr 21, 09 12:00 pm
What IF my transparent thing should be pink?
I used CUSTOM>Selected PINK, did R=255,G=0,B=255
And, eh, Imported to DX, Still not transparent... :/
EDIT:
Can YOU do it from me?
Here-- Take this, And tell me how YOU did it, Okay?
CrossHair.psd
*Points towards rest* NO STEALIN!!!!!
Postby Dae » Tue Apr 21, 09 12:24 pm
You need to tick "Masked" option while importing the texture in UnrealEd, or if you're doing exporting with Unreal script, specify this is in the export code.
I personally don't use Photoshop, but in my program I had to open the palette and manually move the color to the very beginning of it.
Postby VodunLoas » Tue Apr 21, 09 8:58 pm
Is it that hard? Anyways here you go.
CrossHair.pcx
(2.08 KiB) Downloaded 506 times
Postby ~DJ~ » Tue Apr 21, 09 9:01 pm
You forget!
Instructions about how you did it!
EDIT: OH MY GOD 3 DOWNLOADS ALREADY?!
No stealllinnnn maaeettt!!!
EDIT2: Sorry man, But I wanted PINK, Black is easy, I wanted Shadow too.. :/
Doesn't help :/
BY the way: Your the SAME guy that works on S101?
Postby VodunLoas » Tue Apr 21, 09 9:04 pm
HUH? Same instructions I gave in the first post. I just deleted the pink layer, and did the rest.
Postby ~DJ~ » Tue Apr 21, 09 9:05 pm
Eh, Read my post again, Edited...
Postby VodunLoas » Tue Apr 21, 09 9:07 pm
Hmm yeah I noticed it isnt working... let me try to fix it, and yes I am on s101.
Postby ~DJ~ » Tue Apr 21, 09 9:10 pm
Great!
Well, Yeah I noticed too, It isn't working.
Making Black mask texture is easy-- Open paint, Select paintbucket tool, And then select black, Do it as black areas from there, and save as BMP:
Second way is--
Open Photoshop, Do some design, make the backround black, and then save as somewhere as "BMP" and import, Done.
BUT, Local (selective) should be done, indexed color, and while importing, Tick the MASKED.
Creating BLACK mask texture is easy, I want pink :S
EDIT: Also, Please... Add me to TREM group at your forums, so I can see that section too, I am also a TREM member too.. :/
First I was TREM, Then later on i joined S101 too. :D
Thanks in advance for even replying man!
Postby VodunLoas » Tue Apr 21, 09 9:19 pm
Hmmm, I am having a hard time getting yours to work. All mine work when I do it. I can add you to that group, but it is Allans job.
Postby ~DJ~ » Tue Apr 21, 09 9:20 pm
Meh, Hes too BUSY in real life, He got this limited Mobile Broadband, that is really slow, so he can't be that active :/
Postby VodunLoas » Tue Apr 21, 09 9:24 pm
Ok, got it to work, i had to set the colors on the indexed color to 256, it made it default lower than normal. Also added you to that group.
CrossHair.pcx
(1.68 KiB) Downloaded 466 times
Postby ~DJ~ » Tue Apr 21, 09 9:40 pm
Thanks alot, But eh, Its black? o_O
I wanted PINK IT GAVE ME BLACK!
Lol how come you did it on BLACK and imported the shadow too?
Maybe you changed the shadow color to a bit brighter, not black (R=0, G=0, B=0)
D:
Postby VodunLoas » Tue Apr 21, 09 9:58 pm
When I import it as a texture masked, there is no background. I just see the crosshair with the shadow.
Postby VodunLoas » Tue Apr 21, 09 10:00 pm
Try this one then... ya picky foo.
EDIT... hmm this one is the same... but still IT SHOULD WORK FOR WHAT YOUR DOING! TRY IT NUB!
When you look at the texture in properties, it has a black background, but it still is MASKED! IT WORKS!
CrossHair.pcx
(1.68 KiB) Downloaded 458 times
Postby Dae » Wed Apr 22, 09 6:46 am
Fixed .pcx download (the forum tried to display it as a picture, and failed).
Postby ~DJ~ » Wed Apr 22, 09 9:55 am
Lol Okay, Thanks man, next time I'll try yours, HAY DUN CALL MEH A NUB KK?
Postby Zondartul » Wed Apr 22, 09 1:52 pm
Does Unreal support partially transparent pixels? Say if I wanted a part of texture to be solid, part invisible, and part half-transparent? Or blendng transparency....
Zondartul
Postby VodunLoas » Wed Apr 22, 09 10:09 pm
No it does not.
