A problem with model
Postby Andrievskaya Veronika » Mon Oct 05, 09 10:09 am
i've made a mesh and texture, but when i'm importing it into the game, texture is shifted, so some characters in the word on the texture are screwed up.
Here is the model (texture included).
Maybe i did something incorrectly? Please, can someone help me? I trying to fix the problem already more than two days, without shade of result...
p.s.: the word on the texture is Комментарий, Commentary in english :)
D2Comm.rar
(31.17 KiB) Downloaded 367 times
Postby Andrievskaya Veronika » Fri Oct 09, 09 9:58 am
So, nobody knows?
Postby ~DJ~ » Fri Oct 09, 09 10:08 am
Remove flags=2 in the texture import, if it is messy.
I don't get your problem TBH.
Can you state more clearly?
EDIT:
Just found it out.
Try this model:
d2commFixed.rar
(2.92 KiB) Downloaded 361 times
Postby Andrievskaya Veronika » Fri Oct 09, 09 12:11 pm
Thanks, this one does not screwed up after exporting. But what i did wrong in my model?
Postby ~DJ~ » Fri Oct 09, 09 12:38 pm
Well, It had this big vertex in the middle containing all the faces, if you wire-frame-overlay it, you will see how it really looks. shouldn't be a one vertex. Hope you understand :oops:
EDIT:
That should.. explain.
Postby Andrievskaya Veronika » Fri Oct 09, 09 12:55 pm
Thanks. I'll remember this.
Users browsing this forum: Yandex [Bot] and 1 guest
