new pc
Postby James » Fri Aug 06, 10 7:07 pm
hey clix he's denying our prank
Postby Dex » Fri Aug 06, 10 7:19 pm
Are Cyber Snipa mice any good?
Postby James » Fri Aug 06, 10 7:20 pm
HE HE HE HE TRY TO AVOID THE LAUGHTER
Postby Professor Layton » Fri Aug 06, 10 7:20 pm
cyber snipa is the most hilarious brand ever
Postby James » Sat Aug 07, 10 7:22 am
Hey Dex when you play on no cross hair servers you can use http://www.supplycrate.com/ too!!!!!!!!!!!!!!!!!!!!!!
Postby Dex » Sat Aug 07, 10 7:24 am
James wrote:Hey Dex when you play on no cross hair servers you can use http://www.supplycrate.com/ too!!!!!!!!!!!!!!!!!!!!!!
rofl this will be the... most useful :twisted:
Postby James » Sat Aug 07, 10 7:26 am
10$ for something you can just use a tiny piece of duct tape with.
Postby Dex » Sat Aug 07, 10 9:24 am
At the moment, I'm 99%- sure about these two:
Case: Case CoolerMaster HAF 932
Processor: AMD Phenom II X6 1055T HDT55TFBGRBOX
Questions
- Which of the following 3 PSU's is the best for my future configuration?
Corsair HX750W OR Corsair TX750W OR Antec TruePower New TP-750 750W
- Is the ASUS Crosshair IV Formula any good? (From what I've heard, it has a good onboard sound card)
- Current alternatives are: M4A89TD Pro/USB3, M4A89GTD Pro/USB3
- Is the G.SKILL Ripjaws Series 8GB (2x 4GB) DDR3 1600 (F3-12800CL9D-8GBRL) any good?
Storage devices
- Does a OCZ Agility 2 OCZSSD2-2AGTE60G (SSD, SATA2, 60GB) provide a noticeable difference in the overall PC performance if it was the system drive (load times etc.)?
- Does a WD VelociRaptor WD6000HLHX (600GB, 10000 RPM, SATA3) provide a noticeable difference in the performance of videogames and software if I used it as a drive for programs, games, etc. (would games load faster, would the instruments for my music projects load faster)?
- Would partitioning the latter drive cause noticeable performance drops of any kind (as in if I made separate partitions for videogames, for programs, for music-editing to organize better)?
- Also, the SSD being SATA2, would the VelociRaptor (SATA3) perform better as a system drive?
Thanks.
Postby Alex » Sat Aug 07, 10 10:02 am
Dex wrote:At the moment, I'm 99%- sure about these two:
Questions
Not much difference, two of them are modular, one of them isn't. Personal preference.
Dex wrote:- Is the ASUS Crosshair IV Formula any good? (From what I've heard, it has a good onboard sound card)
I'd go with the M4A89GTD Pro/USB3, it's a hell lot cheaper.
The first two have AMD 890FX chipsets. The main advantage this chipsets gives, is, when using 2 graphics cards, it can run both on x16, instead of, with the AMD 890GX chipset (M4A89GTD Pro/USB3), running both on x8 (Thus sharing the same x16). Will you be running a dual card setup? If you want better audio, you can use the money you save (Price difference between the Crosshair IV Formula and M4A89GTD Pro/USB3 is ~60-65 here) on a soundcard.
Dex wrote:- Is the G.SKILL Ripjaws Series 8GB (2x 4GB) DDR3 1600 (F3-12800CL9D-8GBRL) any good?
I guess it's good.
Dex wrote:Storage devices
The SSD would make your noticeable PC faster, when it comes to loading the OS.
Yes, the 10k RPM disk would also increase loading times, but can't say how much you will notice it.
I don't know about the partitioning question.
As for the SATA2 (SATA-300) and SATA3 (SATA-600) stuff.
No. I read a review where they tested 2 disks, one SATA2 and one SATA3, both 7.2k RPM I believe. They tested almost the same, the SATA3 only had a slight increase of speed, but not always, sometimes SATA2 performed better.
Dex wrote:Thanks.
No prob.
Postby Professor Layton » Sat Aug 07, 10 1:34 pm
Dex wrote:- Would partitioning the latter drive cause noticeable performance drops of any kind (as in if I made separate partitions for videogames, for programs, for music-editing to organize better)?
It won't give you a noticeable performance drop (definitely not an increase though) but there is no point to partitioning, other than sorting stuff in a way that suits your mind.
Last edited by Professor Layton on Sat Aug 07, 10 1:34 pm, edited 1 time in total.
Postby Aidan » Sun Aug 08, 10 2:27 am
What I did was purchase a 500gb ext. HDD and made about 4 folders.
-Games
-Music
-I can't remember
-Something else I can't remember.
Folders were created so you don't have to hassle through partitions ;)
Postby Dae » Sun Aug 08, 10 9:46 am
Aidan wrote:What I did was purchase a 500gb ext. HDD and made about 4 folders.
This is also good when you often download torrents. I noticed torrents were slowing down my system, and it was no longer an issue when I bought a separate hdd for that.
Postby James » Sun Aug 08, 10 9:55 am
Yeah the same, I have a small HD dedicated to incomplete torrents and video capturing. When they're done I move them to my storage external.
Postby Alex » Sun Aug 08, 10 11:37 am
I have a seperate disk for Music, a seperate disk for Movies & Series and a seperate disk for Backups. That works fine for me.
Postby Aidan » Sun Aug 08, 10 6:13 pm
The only thing I use my default C:\ Drive for.. [I might get a 32Gb Solid state just for my OS :wink: ]
-Processing Operating system files, reg, .dll, etc.
That way My OS runs smooth all the time.
Remember, there's only 1 (One) Laser per HDD. Giving 1 (One) laser 2 things to do decreases the performance.
So... I put my USB ports to work for everything else. (Not going to fry)
Postby clyzm » Sun Aug 08, 10 6:38 pm
I don't think you'll notice the speed change in the Velociraptor or the SSD, unless you want to individually count the seconds it takes you to load up your OS or programs, which is slightly ~2-3 seconds or so faster than a normal HD. Besides they're overpriced like fuck lol
Postby Dex » Sun Aug 08, 10 10:21 pm
clyzm wrote:I don't think you'll notice the speed change in the Velociraptor or the SSD, unless you want to individually count the seconds it takes you to load up your OS or programs, which is slightly ~2-3 seconds or so faster than a normal HD. Besides they're overpriced like fuck lol
http://www.youtube.com/watch?v=kiLSXvNaCME#t=30s
Postby James » Sun Aug 08, 10 10:51 pm
mfw that's one SLOW standard hard drive.
Postby clyzm » Sun Aug 08, 10 10:52 pm
>Raid 0
>Hyperthreading
etc.
Postby ynnaD » Mon Aug 09, 10 12:56 am
>you NEED a new computer
Postby clyzm » Mon Aug 09, 10 1:12 am
ᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱᴴᴱ
but seriously, you probably don't lol
