Can a zoneinfo destroy a player's inventory?
Postby RedDynasty » Sun May 13, 12 6:18 pm
Does anyone know if there is an actor that can delete the player's inventory?
I know that the map duskofhorrors had one but i dont know where to get one
Die mentioned a property in the zoneinfo class called bnoinventory, i tried this but it didnt delete my inventory
RedDynasty
Postby RedDynasty » Mon May 14, 12 2:45 pm
anyone..?
RedDynasty
Postby Dae » Mon May 14, 12 4:15 pm
How was it implemented in singleplayer training missions?
Postby Poor » Mon May 14, 12 4:18 pm
You would need a custom ZoneInfo.
Poor
Postby RedDynasty » Mon May 14, 12 5:33 pm
I think the training mission is a flag not an actor and if its a flag u cant use it in mp( i need it for a mp map, but for testing i also need it for sp, which means i need a working actor that can delete inventory in both sp and mp)
Also poor, do you know how can i get one? or make one?
RedDynasty
Postby Poor » Mon May 14, 12 7:09 pm
I took the code from the training mission and put it in a zoneinfo class. I didn't test it.
class NoInventoryZone extends ZoneInfo;
event ActorEntered(actor Other)
   Super.ActorEntered(Other);
   if(Other.IsA('DeusExPlayer'))
      RemovePlayerInventory(DeusExPlayer(Other));
function RemovePlayerInventory(DeusExPlayer Player)
   local Inventory item, nextItem, lastItem;
   if (Player.Inventory != None)
      item = Player.Inventory;
      nextItem = item.Inventory;
      lastItem = item;
      do
         if ((item != None) && item.bDisplayableInv || item.IsA('Ammo'))
            // make sure everything is turned off
            if (item.IsA('DeusExWeapon'))
               DeusExWeapon(item).ScopeOff();
               DeusExWeapon(item).LaserOff();
            if (item.IsA('DeusExPickup'))
               if (DeusExPickup(item).bActive)
                  DeusExPickup(item).Activate();
            if (item.IsA('ChargedPickup'))
               Player.RemoveChargedDisplay(ChargedPickup(item));
            Player.DeleteInventory(item);
            item.Destroy();
         else
            item = nextItem;
         if (item != None)
      until ((item == None) || (item == lastItem));
Poor
Postby RedDynasty » Mon May 14, 12 7:20 pm
nope its not working :S
maybe im using the zone wrong?
u just put it near the place u want for players to lose their inventory right?
RedDynasty
Postby Poor » Mon May 14, 12 8:39 pm
I checked it and it works. Though you can get around it by throwing weapons into the zone.
You have to zone off an area and place a NoInventoryZone in it. Make sure no other zoneinfo's are in the zone, which includes LevelInfo, WaterZone, WarpZoneInfo, and SkyZoneInfo.
If you want something with a radius instead of an entire zone then you need something else.
Poor
Postby RedDynasty » Mon May 14, 12 8:42 pm
So how do i zone off an area?
What i want is when a player goes through a small area with an NoInventoryZone in it, they lose all their inventory( similar like ur cagematch effect where only the players inside the cage get their inventory destroyed)
Also what do i need for the radius?
RedDynasty
Postby RedDynasty » Tue May 15, 12 8:41 pm
Well i tried using the same method as adding a pain zone( used tacks tutorial) and it didnt work :S
I might be doing something wrong.
RedDynasty
Postby Alex » Tue May 15, 12 10:17 pm
Poor wrote:I checked it and it works. Though you can get around it by throwing weapons into the zone.
That can be fixed by setting the bNoInventory variable, as mentioned in the start post. It sets a lifespan of 1.5 on all items in the zone.
Postby RedDynasty » Wed May 16, 12 1:02 pm
Everyone thanks for your help, i figured out the problem, i was using the zones wrong, it works perfectly.
Also, alex is right, u need to put bnoinventory to true, otherwise it will only destroy dropped weapons.
1 last question, will this work on mp?
RedDynasty
Postby Dae » Wed May 16, 12 5:57 pm
RedDynasty wrote: 1 last question, will this work on mp?
Why don't you want to test it yourself?
Users browsing this forum: Yandex [Bot] and 1 guest
