Another server issue :(
Postby DeViL » Thu Jul 30, 15 9:27 pm
Ok... So I was able to get it up and running with the full version of DX... Now on a remote server I installed the Goty edition, the server shows up in the server list however from 3 different locations I am unable to connect to it..
Server Side
Ports opened
Firewall allowed UDP/TCP 7790-7792
Installed Mods
DXMTAL_V152b1
MiniMTL
Mapvote
Config files are fine as I hosted on home connection with no problems
The only difference between both servers is the off-site is using the Goty editon my Home server is using the full version
Waiting for reply....
DeViL
Re: Another server issue :(
Postby synthetic » Fri Jul 31, 15 5:10 pm
Since you've opened the correct ports and can see the server, and goty edition iirc won't present any particular issues besides the cathedral map mismatch, I would recommend that you check both server log file just after you've tried to enter, and also your own client log file (can start game with -log to see it in real time).
One of the logs should give you fair idea whats happening.
edit: I am assuming that you do know about the cathedral mismatch and would recognize the "version mismatch" error on your monitor as a clear indicator of whats happening. Also, your server should show up here: http://deusexnetwork.com/serverlist
If it doesn't show up there you'll have to use "open IP:PORT" command from console most likely.
edit2: I can enter your server just fine and aside totally fucked up gamespeed that is way worse than any "mods/bs" it seemed to work fine. If you want to host goty cath then rename it into something else like DXMP_SpeedbunnyCath
Return to Deus Ex
Users browsing this forum: No registered users and 144 guests
