Ph34r
Ph34r
Postby Snakey » Sun Sep 04, 05 4:32 pm
Sexy,yes?
Postby Alex » Sun Sep 04, 05 5:45 pm
Isn't that just some drugs vial with another skin?
Postby Snakey » Sun Sep 04, 05 6:04 pm
Ah yes.
But they will be made to activate augs, put into a mod and compiled very soon.
Postby Dae » Sun Sep 04, 05 6:05 pm
€$ñãkÚ¥€ wrote:Ah yes.
Why not use default augmentation cannisters from single player?
Postby Snakey » Sun Sep 04, 05 6:07 pm
They work in Multiplayer? o_O
Besides, these Hybrid vials look sexier
Postby Dae » Sun Sep 04, 05 6:16 pm
€$ñãkÚ¥€ wrote:They work in Multiplayer? o_O
They don't but why, i thought you're adding your own code, arent you?
// This is a simple example that gives speed aug to player
// via frobbing the can
class SpeedAugCan extends DeusExPickup;
state activated
    function beginstate()
        DeusExPlayer(Owner).AugmentationSystem.GivePlayerAugmentation(class'AugSpeed');
        destroy();
    bActivatable=True
    ItemName="Speed Enhancement Augmentation Cannister"
    PlayerViewOffset=(X=30.00, Y=0.00, Z=-12.00)
    PickupViewMesh=LodMesh'DeusExItems.AugmentationCannister'
    ThirdPersonMesh=LodMesh'DeusExItems.AugmentationCannister'
    LandSound=Sound'DeusExSounds.Generic.PlasticHit1'
    Icon=Texture'DeusExUI.Icons.BeltIconAugmentationCannister'
    largeIcon=Texture'DeusExUI.Icons.LargeIconAugmentationCannister'
    largeIconWidth=19
    largeIconHeight=49
    Description="Some gabber."
    beltDescription="SPEEDAUG"
    CollisionRadius=4.31
    CollisionHeight=10.24
    Mass=40.00
    Buoyancy=40.00
Anyway, i recommend you to make aug type a variable, otherwise you'll have to create a can for each augmentation.
Postby Snakey » Sun Sep 04, 05 6:20 pm
Ah, we were thinking of only making 7 augs, in 7 seperate coloured Hybrid vials. But I guess making it a variable would make it better for the Owner so they could choose which aug they would like.
Postby Dae » Sun Sep 04, 05 7:09 pm
I think it should be like that
// In case if you want different skins for each can
enum ESkinColor
   SC_Speed,
   SC_Cloak
var() ESkinColor SkinColor;
var() class<Augmentation> AugType;
function BeginPlay()
   Super.BeginPlay();
   switch (SkinColor)
      case SC_Speed:   Skin = Texture'YourTexture'; break;
      case SC_Cloak:   Skin = Texture'YourTexture2'; break;
state activated
        DeusExPlayer(Owner).AugmentationSystem.GivePlayerAugmentation(AugType);
        destroy();
    AugType=class'AugSpeed'
    bActivatable=True
    ItemName="Augmentation Cannister"
    largeIconWidth=19
    largeIconHeight=49
    Description="Some random crap."
    beltDescription="AUGCAN"
    Mass=40.00
    Buoyancy=40.00
Postby Magus » Fri Sep 09, 05 10:18 pm
Slight problem with that... It makes it harder to summon them (if you ever feel the need to) and change which aug they activate.
Magus
Postby Dae » Sat Sep 10, 05 1:41 pm
Magus wrote:Slight problem with that... It makes it harder to summon them (if you ever feel the need to) and change which aug they activate.
Yea, but i think its avoidable with 'editactors' command but i'm not sure.
Postby ~ô¿ô~Nobody~ » Sat Sep 10, 05 3:21 pm
no, not in MP
if you like to make easy summon make a main class that contains a variable and then make subclasses where you change the variable's value in their defaultproperties
Users browsing this forum: No registered users and 22 guests
