electric water
electric water
Postby Blade » Wed Feb 25, 04 8:16 pm
i'm making a map in which i want to put a canal of electrified water:
i've set in the zoneinfo painzone to true, damagepersec to 10 and damagetype to Shocked
BUT it does damage only when u enter and exit the zone, not when u are underwater...
ive also added a particlegenerator, but the effect is VERY small, while i want electricity to be everywhere in the canal... is there another way than putting lots of particlegenerators???
May the Force be with you...
Don't forget to see my site and to download my maps (and to post feedbacks on the forum!):
.: Blade's Deus Ex World, with my maps! :.
Blade
Postby Jeoh » Wed Feb 25, 04 8:57 pm
Just do it the hard way ;)
Jeoh
Re: electric water
Postby Blade » Wed Feb 25, 04 9:25 pm
Blade wrote:BUT it does damage only when u enter and exit the zone, not when u are underwater...
ok this happens when i try the map from unrealed, but in dxmp it seems to work... good!
the "hard way"? you mean adding tons of particlegenerators???? aaargh :shock:
Blade
Postby KingJ » Thu Feb 26, 04 7:26 am
what effect are you trying to get from the particle generators? why not just texture the water zone with a "moving texture"
BTW - how do you make those moving textures like the ones in the Effects texture category
Game Servers by KINGJ.NET Game Servers. Many games supported at excellent prices. Deus Ex supported upon request.
KingJ
Postby Blade » Thu Feb 26, 04 5:22 pm
King J wrote:what effect are you trying to get from the particle generators? why not just texture the water zone with a "moving texture"
i use the particlegenerator to make electric rays, like those in the sp game near generators and similars...
King J wrote:BTW - how do you make those moving textures like the ones in the Effects texture category
do u mean water which moves? rightclick on the surface, select properties and check "small wavy" (i find big wavy useless, but never experimented a lot...:mrgreen:)
Blade
Postby KingJ » Thu Feb 26, 04 6:08 pm
i mean stuff found under textures -> effects. How do i make those?
KingJ
Postby Aussiefella » Fri Feb 27, 04 8:46 am
keep your zone small, e.g. make the zone ONLY around the water.
Aussiefella
Postby Blade » Fri Feb 27, 04 11:20 am
oh but the zone IS only the water
oh well, however i think i'll switch to a more effective zone, maybe a long fall or a poisoned area... i'll see
Blade
Postby Blade » Thu Mar 11, 04 7:24 pm
ok change of mind :mrgreen:
i've changed the water into a poisoned area, BUT i cant get the fog!
i've set in the zoneinfo all of bfogzone, fogcolor, volumefog, volumeradius and volumebrightness plus showfog and fogdistance, BUT I DONT GET ANY FOG!
can any1 explain me how to make a fog in detail?
Blade
Postby DarkKnight » Fri Mar 12, 04 4:14 pm
You need the zone to be bfogzone true; then you add a light where you want the fog, set the fogvoume and volume bright ness to about 50 (then play with the settings) and the radius about 10... depends how big your room is ... then just set a colour if you are using one.
If you get stuck open up NSF hq map the one with the computer room, it has the fog effect used well.
Note: If you want to have fog to be visible then you will have to make accomidations for it.. if you want one small room with fog in it then you will have to make just one big zone a fog zone then set the rest of the lights volume radius and brightness and volume fog to 0 and just have the fog light's where they should be.
Play around with it, it should be easy to get the hang of :)
Postby Marouku » Sun Mar 14, 04 5:12 pm
what happened to my picture....err avatar..
Marouku
Postby Marouku » Sun Mar 14, 04 5:15 pm
so....how do u get a website that i can put my maps on?
my website now is http://www.freewebs.com/mmoutkast/
i cant put any downloads on it though... :x
Marouku
Postby Dae » Sun Mar 14, 04 7:37 pm
Bug is fixed now.
Postby Blade » Mon Mar 15, 04 5:44 pm
ah so i do need lights... :?
i thought i could just be fine with the zoneinfo...
but with lights will i see the fog from outside the zone (its in open space ,delimited of course)?
Blade
Postby Dae » Mon Mar 15, 04 5:46 pm
You need lights, in which you need to change for properties and zone where fog is visible. In Zone Properties you need to change bFogZone=True. Thats easy.
Postby Marouku » Mon Mar 15, 04 9:53 pm
about the web hosting service problem...
and my avatar still dont show up!!
Marouku
Postby Blade » Tue Mar 16, 04 5:07 pm
oUtKaSt wrote:about the web hosting service problem...
could you just avoid posting damn off-topic unrelated stupid questions on my topic? thnx :twisted: :evil: :smt013
Blade
Users browsing this forum: No registered users and 42 guests
