RPGcity server help
RPGcity server help
Postby ~Sandro~ » Wed Dec 21, 05 3:39 pm
Hello, i have all files needed to run RPGcity but how do i set up a server i mean what do i type in deusex.ini to be able to change the game type to RPG???
thanks
~Sandro~
Postby Alex » Wed Dec 21, 05 3:40 pm
You can't change the gametype into RPG unless you HAVE a gametype called RPG. Every time you go in my server and you download RPGGame.u you are downloading the gametype I made. And trust me, making a gametype isn't really easy. That is why I am the only one with a RPG server + RPG Gametype.
Postby ~Sandro~ » Wed Dec 21, 05 3:41 pm
I have RPGGame.u, so what else I need?
~Sandro~
Postby Alex » Wed Dec 21, 05 3:42 pm
You cannot use it :) I protected it.
Postby ~Sandro~ » Wed Dec 21, 05 3:44 pm
For what reason?
I just need to know what gameinfo i need to type?
~Sandro~
Postby Alex » Wed Dec 21, 05 3:45 pm
~[A]Mr. X~ wrote:You cannot use it :) I protected it.
Postby ~Sandro~ » Wed Dec 21, 05 3:46 pm
But why?
~Sandro~
Postby Alex » Wed Dec 21, 05 3:48 pm
To prevent that others will use it.
Postby Gishank » Wed Dec 21, 05 3:50 pm
Plus you will get a mismatch when ever you go onto alexs server.
Postby ~Sandro~ » Wed Dec 21, 05 3:51 pm
~[A]Mr. X~ wrote:To prevent that others will use it.
you egoist :D
~Sandro~
Postby ~Sandro~ » Wed Dec 21, 05 3:52 pm
<~>K}Ã?<THORN><~> wrote:Plus you will get a mismatch when ever you go onto alexs server.
bullshit
sorry double post, klop's false.
~Sandro~
Postby Gishank » Wed Dec 21, 05 3:53 pm
I frown on double posters, and it's true.
Postby Alex » Wed Dec 21, 05 3:55 pm
If you actually have RPGGame.u in your System folder, you will get version mismatch. Since I edit my RPGGame.u almost every day.
Postby ~Sandro~ » Wed Dec 21, 05 3:56 pm
~[A]Mr. X~ wrote:If you actually have RPGGame.u in your System folder, you will get version mismatch. Since I edit my RPGGame.u almost every day.
And why you edit evry day? to protect it? and why protect it?
~Sandro~
Postby Alex » Wed Dec 21, 05 3:57 pm
Why I edit it every day? To get rid of errors. There are like 100 errors in RPGGame.u at the moment.
Postby ~Sandro~ » Wed Dec 21, 05 4:00 pm
~[A]Mr. X~ wrote:Why I edit it every day? To get rid of errors. There are like 100 errors in RPGGame.u at the moment.
and whenyou finish getting rid of them, will you post it, tell me how to run it :?:
~Sandro~
Postby Alex » Wed Dec 21, 05 4:01 pm
The RPGGame.u is only an entertainment stage of DX: RPG.
Postby ~Sandro~ » Wed Dec 21, 05 4:05 pm
~[A]Mr. X~ wrote:The RPGGame.u is only an entertainment stage of DX: RPG.
i just play in the map with coca-cola and lays...no much rpg there :cry:
And will DX:RPG be available for dl?
~Sandro~
Postby Alex » Wed Dec 21, 05 4:06 pm
If you would have looked at the server name you could have seen that it is a TESTING server. And yes, DX: RPG will be downloadable/hostable.
Postby ~Sandro~ » Wed Dec 21, 05 4:10 pm
~[A]Mr. X~ wrote:If you would have looked at the server name you could have seen that it is a TESTING server. And yes, DX: RPG will be downloadable/hostable.
i know, i know. I also tryed to join the RPGv87 where it required password...
Ps: I liked the"entertainment' stage of DX:rpg, so why don't you tell me how to use it?
~Sandro~
Postby Alex » Wed Dec 21, 05 4:11 pm
RPGV87(Yes, V87 I save after each change :roll:) is private, as the server name says. And if you like it, go play on my server, but it wont be downloadable/hostable.
Postby ~Sandro~ » Wed Dec 21, 05 4:14 pm
ok, but your server is not online so ofen, is it now?
~Sandro~
