DX:IW - Custom Resolutions and FOV changing
Postby James » Thu Apr 14, 11 12:29 am
Deus Ex: Invisible War - Custom screen resolution
  • Go to your My Documents\DeusEx - Invisible War folder
  • Make a backup of the user.ini file and open the original
  • Search for:
      FullscreenViewportY=yyyy
      FullscreenViewportX=xxxx
    Change it to the resolution you desire to use.
Deus Ex: Invisible War - Field of view editing
If you feel that you can't stand the default 4:3 field of view settings then please follow this guide. You will need a hexadecimal editor, please click here to download a freeware program which does the job and does not require an installation.
  • Go to your installation's \system folder
  • Make a backup of the Engine.d2u file, open the original with the hexadecimal editor
  • Search for instances of AA 42 (there should be 3 in total) and replace with the following depending on your ratio:
      16:9 - Change to F0 42 to obtain a FOV of 120
      16:10 - Change to D8 42 to obtain a FOV of 108
Once done save changes to Engine.d2u and see if the game launches correctly with the FOV change.
Postby Shinobi » Thu Apr 14, 11 10:10 am
All these changes can be found at link below: http://www.widescreengamingforum.com/wiki/index.php/Deus_Ex:_Invisible_War
Awkward game to tweak isn't it.
Postby James » Thu Apr 14, 11 10:27 am
Thank you sir. I wish I seen this link, I was using a very bad guide on STEAM forums which was incorrect so I made these threads to make up for it. This seems to be more up to standard. :)
Yes very awkward, was laughing when you had to use a hexadecimal editor.
Postby Shinobi » Thu Apr 14, 11 10:29 am
Yeah. Perhaps somebody more skilled than myself could make a patch, shouldn't be TOO hard I don't think?
Not that this game is particularly popular lol.
Postby Dae » Thu Apr 21, 11 7:55 pm
James wrote:Engine.d2u
for Steam version the full path is
C:\Program Files (x86)\Steam\steamapps\common\deus ex invisible war\System
Postby James » Fri Apr 22, 11 6:23 pm
Yeah I use steam version, thought saying installation + system was enough.
also fixed slashes.
