OK guys. I told you I'd help, and with the help of a few guys, and thanks to [A]llan for putting his server to include mine in the testing, I have a backup MS if we ever should need to use it running...
To add it, and please forgive me if I make a mistake its 5:16 AM here...
(For having your server show up on my MS when hosted)
Go to DeusEx.ini...
If you have Nephthys mod, do the following:
Find the header: [DeusEx.DeusExGameEngine]
Then add the following:
ServerActors=Nephthys.NptServerUplink MasterServerAddress=67.86.252.168 MasterServerPort=27900
If you do not have Nephthys mod, do the following:
ServerActors=IpServer.UdpServerUplink MasterServerAddress=67.86.252.168 MasterServerPort=27900
To view my MS from the start of the game, in DeusEx.ini go to the [DeusEx.MenuScreenJoinGame] heading, add the line MasterServerAddress=67.86.252.168, and put a ; before the GameSpy master server address. NOTE: This will not show GS servers then, it would be better if you add my MS into MMUserInterface (provided you have it) so you can switch at the click of a simple button. Saves time and problems...
If you have MMUserInterface, I'm pretty sure you know how to add another MS to the button scroll list, but just in case, you would add the following at the bottom of the [MMUserInterface110.MMUIMenuScreenJoinGame] heading section in DeusEx.ini:
MasterServers[2]=67.86.252.168
*NOTE: MasterServers[2] must be changed to whatever the number following the last number in your current MS list... for me, that would be 2.*
Good luck, have fun, I'm tired but if anyone needs help feel free. I'm sure you guys can handle it though. And although it seems like Deja might've stopped attacking, we don't know for sure so this is your 24/7 unlimited backup, PLEASE use it if you must I certainly don't mind at all... In fact it's nice to actually see servers, including my own, all showing for once... instead of every once in awhile...
