How Come My Server Does Not Show??!!?
Postby Billmaster » Sun Sep 30, 12 8:34 pm
It even says resolved on the console but I can only see it in lan.
"Nephthys: 2012/09/30 15:12:27: NptServerUplink: Port 14881 successfully bound for master server master0.gamespy.com:27900 "
Thank in advance,
Adult[Z]wim
DeusEx.ini
(16.47 KiB) Downloaded 1255 times
Billmaster
Postby Kaiden » Sun Sep 30, 12 9:26 pm
http://www.dxalpha.com/forum/viewtopic.php?t=5782
Threads pretty old but the info is still relevant, make sure to go through that, namely ports.
Postby Billmaster » Sun Sep 30, 12 10:09 pm
I opened every port and disable every firewall I give up deus ex fuck you old ass game.
Billmaster
Postby Kaiden » Sun Sep 30, 12 11:33 pm
Although with that said, when I hosted it'd appear in LAN even though it was online, and it does for others too. The best way to test it would be to host it and test if anyone else can see it on the server list.
Postby Poor » Mon Oct 01, 12 12:08 am
Yeah, this drove me nuts too but I eventually got it.
From an older post I made:
Even if the firewall is disabled, you still need to give Deus Ex permission to communicate. It's weird but that's how Windows works.
But first, you should check if your ports are forwarded correctly. Use this program to check the ports 7790, 7791, and 7792 using UDP.
http://portforward.com/help/portcheck.htm
After you confirmed the ports are forwarded, try this:
Go to start menu, type "firewall", and choose "Windows Firewall with Advanced Security". Create a new inbound rule for the program deusex.exe. Then create a new outbound rule for deusex.exe.
Then type firewall in the start menu again. Choose "Allow a program though Windows Firewall". Make sure Deus Ex is checked and make sure the two checkboxes next to it are checked.
Poor
Postby Billmaster » Mon Oct 01, 12 2:45 am
yup just did all that poor and it still not show.
Billmaster
Postby Kalman11 » Mon Oct 01, 12 5:40 am
Do you have router? If yes, disable it's firewall or enable DMZ
Kalman11
Postby ~DJ~ » Mon Oct 01, 12 10:20 am
errr.. well I'm no expert, but this sounds off.. open your DeusEx.ini and find:
[IpServer.UdpServerUplink]
at this, you see 'MasterServerPort=14879'
scrap that and make it:
MasterServerPort=27900
..also make sure that DoUplink is true.. it's one of the options located just there.
Postby Billmaster » Sun Oct 14, 12 12:10 am
well that messed it up worse lol
Billmaster
Postby Aidan » Mon Oct 15, 12 7:12 pm
Do you keep your windows installation clean?
Any junkware on your PC?
Users browsing this forum: No registered users and 183 guests
