Binds (repost)
Postby ~M3GG4~ » Sun Apr 15, 07 9:22 pm
i save it as defuser ini
Then i have to user ini's
My normal one--user.ini
My normal one saved diff. name -- defuser.ini ?
It still dosent work at all.
<center> Image </center>
<center>Deus Ex Soldiers
~M3GG4~
Postby ~M3GG4~ » Mon Apr 23, 07 9:50 pm
Can somebody help me with this, My binds dont work at all, im using slimline
I feel i could be a great player, if i had binds, like everyone else,
thanks alot for your help.
~M3GG4~
Postby Karkian » Tue Apr 24, 07 2:36 am
hmm,i make binds myself it is pretty simple :D the ones i make work 100% :?
Karkian
Postby qwert555 » Tue Apr 24, 07 2:44 am
¥[RTK]¥Gårmåñ wrote:hmm,i make binds myself it is pretty simple :D the ones i make work 100% :?
Sure, you gave some to me but you need to hold on it.
Good binds anyway :wink:
qwert555
Postby Karkian » Tue Apr 24, 07 3:00 am
:D
Karkian
Postby ~M3GG4~ » Wed Apr 25, 07 1:09 pm
Nope, i dont think binds work with slimline, if somebody could clear this up with me ,i would be happy
Thanks
~M3GG4~
Postby Professor Layton » Wed Apr 25, 07 3:59 pm
I've used slimline, binds worked for me in slimline with the defuser.ini trick.
Postby ~M3GG4~ » Wed Apr 25, 07 4:36 pm
They dont work for me at all :(
How can i get them to work ?
Thanks
~M3GG4~
Postby Dae » Wed Apr 25, 07 4:43 pm
First of all, are you sure that you assign binds to the bottom section with keys? When you add binds, scroll down to the very end of the file, and then slowly scroll up to find a section with W=, A=, S= and etc.
Secondly, edit both user.ini and defuser.ini. Just make changes in both files, forget about 'saving as' and etc.
Postby ~M3GG4~ » Wed Apr 25, 07 5:18 pm
So, how do i save it?
~M3GG4~
Postby ~M3GG4~ » Wed Apr 25, 07 5:29 pm
Aha, very sorry for the double post, but 8) 8) 8)
It works now!! :) great, only thing is that when i press my bind it only takes out my weapon, it dosnt heal me :(
Here is whats in my user.ini
ParseRightClick|ParseRightClick|MedKit|OnRelease ActivateBelt 1
what doe sit have to be to take out my medikit, heal me, then take back out belt item no.1?
Thanks alot for your help.
~M3GG4~
Postby Dae » Wed Apr 25, 07 5:48 pm
Did you set "medkit" command in "aliases"? An "alias" in user.ini means a user-customisable function. "Medkit" isn't a function that exists in Deus Ex, so you have to pre-define it in aliases beforehand.
You may find a section with Aliases when you scroll to the very end of the file and scroll up approximately 6-10 lines.
Postby ~M3GG4~ » Wed Apr 25, 07 5:53 pm
Oh, right ..No i havent, so ill just copy that into my alias section?
Thats for the help Dae.
EDIT... Damn it hast worked, heres what i put in Aliases[18]=(Command="ActivateBelt 9 | onrelease ParseLeftClick",Alias=Medikit)
~M3GG4~
Postby Professor Layton » Wed Apr 25, 07 6:23 pm
Alias=Medkit, not Medikit
Postby ~M3GG4~ » Wed Apr 25, 07 6:30 pm
oh yes ! aha now its works, thanks for all your help, specially Daedalus and Clix.
Thanks alot.Now its 0wnage t1m3 !!! rufl jk 8)
~M3GG4~
Postby Dex » Mon Nov 12, 07 9:52 pm
When i try to use the take out medkit then weapon in slot 2 bind, it doesn't work, all it does is take out the weapon, doesn't use the medkit. Can somebody help?
