Question for mappers..
Postby ~DJ~ » Tue May 20, 08 9:34 pm
Hello all those mappers out there....
Can any of you answer the following of my questions? =D
1) Do any of you use "Scalling tool" to make movers?
2) Can we use scalling tool to make some normal blue/brown brushes? cause i use scalling tool all the time..
I Need answers cause i cant make movers... when ever i make a mover its just Non-Solid... thank you... >_>
Postby Jon » Tue May 20, 08 10:34 pm
All the scaling tool does it take the original brush dimensions and multiply them - nothing more technical than that; this means that its just as safe as creating a new brush from scratch with bigger dimensions, but does it much more efficiently.
I haven't done it on movers, but I'd suggest not to.
Postby Dae » Wed May 21, 08 8:34 am
When you intend to make a mover from a scaled brush, you need to right click on the brush, then select "Transform" > "Transform permanently" (only available in UEd2), otherwise in the game it will be non-solid.
You can use a scaling tool for any brushes, but keep in mind that in the buggy environment of UEd, you should keep the sides of your brushes on the grid (that is at least 4-8 in size).
Postby Spiderbot01 » Wed May 21, 08 9:08 am
Dae[A] wrote:You can use a scaling tool for any brushes, but keep in mind that in the buggy environment of UEd, you should keep the sides of your brushes on the grid (that is at least 4-8 in size).
Who are you and what have you done with my Dae?
Postby [FGS]ShadowRunner » Sat Jun 14, 08 2:52 am
I have no luck using scaling tool with mover brushes.
solidity issues on the fuhrpark aeroplanes etc...
if you can scale the original brushes or .t3d of your mover, that is safer.
[FGS]ShadowRunner
Postby Aidan » Mon Jun 16, 08 6:52 am
make a simple flat wall, then intersect maintaining the Poly's.. When dealing with movers, I highly recommend UED2, it's more stable when dealing with movers as well as more advanced.
Postby ~DJ~ » Wed Jun 18, 08 7:10 am
So.... do you use scalling tool all the time? cause my maths aint good to get the size dick..
And yeah i need details bout UED2... i mean Download link... And some how DXAlpha downloads aint working =[
And i need to know how to install UED2.. Well thanks guys =D
Postby Dae » Wed Jun 18, 08 9:42 am
~DJ~ wrote:And i need to know how to install UED2.. Well thanks guys =D
Read the readme.
~DJ~ wrote:i mean Download link.
http://download.deusexnetwork.com/DX1/e ... ealEd2.zip
Advanced users may install also this:
http://www.dxalpha.com/forum/viewtopic.php?t=8467
(download and install all updates)
~DJ~ wrote:So.... do you use scalling tool all the time? cause my maths aint good to get the size dick..
I use scaling tool in 70% cases.
Postby ~DJ~ » Wed Jun 18, 08 7:08 pm
Thanks for UEd2!
BTW I Used scalling tool... still non-solid... =[
See it your self?
MoverTest.unr
(8.08 KiB) Downloaded 399 times
Postby Dae » Wed Jun 18, 08 10:04 pm
you didn't
Dae wrote:select "Transform" > "Transform permanently"
see above
