"Alternative" Techniques
Postby MainMan » Mon Jan 02, 06 9:38 pm
1. The Lambug
(This can also be applied to gas / emp grenades.)
What is a lambug, I hear you ask? well, it's getting more than one lam out of a single one. Usually this is stuck on the wall, although i have managed a thrown lambug once.
How to:
The way to bug a lam effectively is; as soon as it is placed, make sure your crosshair is moved away (so the lam is not highlighted) as soon as possible.
Techniques:
- Press upto the wall, crouch (optional), click fire really fast and as soon as you fire, move away (strafe right/left) or move the mouse away (or a combination of both), and keep on clicking.
- Same as previous technique, but instead of clicking repeatedly, hold down the mouse instead. (This has never worked for me, but i have seen people be successful with this technique.)
Enhancements
- A very simple bind can sometimes increase the success of a lambug. (used instead of the fire button on the clicking technique)
NumPad0=Fire|onrealease Fire
- Ping: i find that the best ping for a lambug is anywhere between 100-180. Nothing laggy, but not entirely lag free.
2. The Lagout
So you're all alone and a team of 5 is coming towards you? what do you do? run - pussy, attack in the hope of making a few kills - not worth it. The only solution is: hit the lag.
This is a simple bind, created by me, so be sure to give me credit:
L=name Lagbot | say Lag |(x 25 or so) onrelease name <YOUR ORIGINAL NAME>
if you want to copy it directly:
L=name Lagbot|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|say Lag|onrelease name <ORIGINALNAME>
To show you the effect of this:
BEFORE
AFTER
sadly, any MTL server will kick you for this, but luckily there are some non-mtl, and even non-mtl-based servers still around.
Feel free to add any more "alternative techniques".
Postby JeJ » Mon Jan 02, 06 10:00 pm
:lol: I'm stealing this.
JeJ
Postby MainMan » Mon Jan 02, 06 10:05 pm
JeJ wrote::lol: I'm stealing this.
I don't mind, thats what i put them up for, just give me some credit or something, don't claim it as your own.
Postby Wasted » Mon Jan 02, 06 10:22 pm
Ok then:Wasteds Techniques!in cooperation with mainman
Postby Ricci » Mon Jan 02, 06 10:23 pm
just use what [3] uses. debug gpf.
-Ricci
Ricci
Postby MainMan » Mon Jan 02, 06 10:36 pm
Ricci wrote:just use what [3] uses. debug gpf.
care to explain?
Postby Dae » Mon Jan 02, 06 10:39 pm
care to explain?
Once you type this, your game crashes with a new 'general protection fault' error.
Postby MainMan » Mon Jan 02, 06 10:40 pm
care to explain?
right, but why do i want that?
Postby Bob » Mon Jan 02, 06 10:41 pm
To get away without being killed...?
Postby MainMan » Mon Jan 02, 06 10:44 pm
just have reconnect then, its easier.
Lagout doesn't get you away, it just hides where you are. You know how laggy players run into walls, and you can't kill them, well this is the same effect, only it stops as you are controlling it.
Postby Dae » Mon Jan 02, 06 10:44 pm
Bob wrote:To get away without being killed...?
Yes, and debug gpf is less suspicious than simple reconnect, because it's not evident that it was provoked by you. However, with "debug gpf" you have a risk of being fragged while being outside the game.
Postby synthetic » Mon Jan 02, 06 10:47 pm
this lagbot trick is fucking hilarious!!!!!!!!!! imagine playing some guy when the bozo suddenly changes his name to lagbot, yells lag and gets his ass killed again and again XD.
I loose lams for lesser reasons. When i fuck around with any nade it usually just disappears into thin air.
Postby MainMan » Mon Jan 02, 06 10:49 pm
[quote="~[NEM]Ã
Postby synthetic » Mon Jan 02, 06 10:51 pm
ive never tried to lam bug, belive it or not. XD
Postby MainMan » Mon Jan 02, 06 10:55 pm
[quote="~[NEM]Ã
Postby JeJ » Mon Jan 02, 06 11:47 pm
I KNEW this would be changed :lol: . Incidentally, the bug is well known, but this is quite efficiently presented and humourous to me. I gave credit and reposted in full at [T] forums.
JeJ
Postby ~Hy[ß]rid~ » Tue Jan 03, 06 1:11 am
This is cool, however, it would fuck things up if people start using it.
~`[EL]HýbriÐ`~
~Hy[ß]rid~
Postby MainMan » Tue Jan 03, 06 11:31 am
yeah, but i doubt they will. I mean even if the player changes his name for the lagout, the admin can still check who it is by player ID#.
Postby synthetic » Tue Jan 03, 06 3:12 pm
kill the dude and use reconnect command. u get diff ID. admin can get your ip through console though.
if its non mtl u can pretty much change anything with your weapons. When I started my first clan I got a hard lesson on how you should not recruit in non mtl server =)
Re: "Alternative" Techniques
Postby monkee » Tue Jan 03, 06 4:00 pm
Main Man wrote:2. The Lagout
So you're all alone and a team of 5 is coming towards you? What do you do? What do you do? (<- notice the added 1337 Keanu-effect)
Enter "CROUCHBUG", simply hit the crouch button and people will think you cheat and use a 1337 bug (its actually true!!)!!
They'll be so stunned they stand still, die and then ban you.
Or just do what I do and just kill them, if you do that other shit your just a complete idiot.
Also, a team of 5 means nothing at all, their skill arent even mentioned. If its noaug, deaths dont matter, so a kill for a kill aint so bad, you might be able to take 'em all out, so go for it. If its augs, regardless of your skill, stay and fight, good training if you suck.
monkee
Postby MainMan » Tue Jan 03, 06 4:13 pm
Or just do what I do and just kill them, if you do that other poop your just a complete idiot.
this isn't meant to be taken seriously, ya know?
Postby monkee » Tue Jan 03, 06 4:23 pm
errr.. lol? Not much seriousness in my post I'm afraid. True, yes. Serious, no.
monkee
Postby Wasted » Tue Jan 03, 06 8:07 pm
I just realiserd, monkee, is a bit like smookie! anyway monkee do u sitll play?
Postby monkee » Wed Jan 04, 06 3:57 am
Wasted wrote:I just realiserd, monkee, is a bit like smookie! anyway monkee do u sitll play?
No need to insult me.
monkee
Postby ~Hy[ß]rid~ » Wed Jan 04, 06 4:17 am
Monkee and Smookie are brothers...
~`[EL]HýbriÐ`~
~Hy[ß]rid~
Postby Bobo. » Wed Jan 04, 06 5:37 am
No their not fag ¬_¬ Smookie = dutch Monkee = err :/ not dutch
Bobo.
Postby ~Hy[ß]rid~ » Wed Jan 04, 06 6:22 am
I know that dude, I was trying to insult that stupid norweigan fuck with the purple les paul... 8)
~`[EL]HýbriÐ`~
~Hy[ß]rid~
Postby monkee » Wed Jan 04, 06 6:42 am
I smell jealousy!
monkee
Postby ~Hy[ß]rid~ » Wed Jan 04, 06 10:43 am
My Washburn > Your Les Paul!!!
~`[EL]HýbriÐ`~
~Hy[ß]rid~
Postby monkee » Wed Jan 04, 06 1:58 pm
ew washburn..
monkee
Users browsing this forum: Google [Bot] and 19 guests
