Laptop Monitor
Laptop Monitor
Postby ynnaD » Fri Apr 02, 10 7:13 pm
So i turned my laptop on earlier, and i was presented with a fully white screen, i couldn't even try to run any recovery programs or safe mode because i couldn't see anything :S, i've found that depending on what angle i keep the monitor at, i can get it to work somewhat, but its a very awkward angle to work with, what could have caused this, is it fixable, or is my monitor fucked D:
Postby Dae » Fri Apr 02, 10 7:15 pm
Pvt Desperate Dan wrote:its a very awkward angle to work with, what could have caused this, is it fixable, or is my monitor fucked D:
I'm pretty sure you can fix that for a minimal price in a local repair service
Postby {HK} » Sat Apr 03, 10 4:23 pm
Fully white screen sounds like:
a. you need to replace the screen inverter (super easy and like $15 for parts)
b. replace the screen backlight (just get a whole new used lcd off ebay, again $15, and easy)
Could be a loose video cable but that's not likely.
{HK}
Postby Dae » Sat Apr 03, 10 4:58 pm
{HK} wrote:Fully white screen sounds like:
Pvt Desperate Dan wrote:i've found that depending on what angle i keep the monitor at, i can get it to work somewhat
