How to....
How to....
Postby Ballistix » Sat Mar 25, 06 7:04 pm
Open my ports.......
Anybody know how. I want to host a server but it wont show up on the list ive done all the stuff on the GODZ forum about updating the master server but it was all bullcrap anyway. :?:
Ballistix
Member title-less
Postby Gishank » Sat Mar 25, 06 7:05 pm
There is already a topic on this subject, read that, then your questions shall be awnsered.
Postby Ballistix » Sat Mar 25, 06 7:06 pm
I did. Twas too complicated for me. I need special looking too.
Ballistix
Member title-less
Postby Siva » Sat Mar 25, 06 10:26 pm
I will help - If you say.
Help me for I am stupid.
Postby Ballistix » Sat Mar 25, 06 10:43 pm
XII//:Prod1gy wrote:I will help - If you say.
Help me for i am ******
Ballistix
Member title-less
Postby MrBlackDX » Sat Mar 25, 06 11:49 pm
ok
you need your IP
once you have that, insert the numbers into your address bar, which is where you enter the webaddress's (for example, http://www.dxalpha.com)
once you have done that, you should have a login screen, if you dont check your IP again
on the login enter any details you have to login into your router, if you dont know any details, try username = "" (so dont put anything inside the username place) and password = "admin"
once you have done that, depending on your router, you need to find the port forwarding entry place
and then enter in the correct ports which are in this topic => viewtopic.php?t=5782
Users browsing this forum: No registered users and 17 guests
