~[A]Kaiden~ wrote:You have 155? (version) There shouldn't be a text box present with 155 unless you turned something to false in the properties. Also try allowing Dx through your firewall like the topic creater did. ^_^
~[A]Daedalus~ wrote:There's no reason to uninstall it - just set bCombineServers (or something like that) to False in your DeusEx.ini. It will show you that old box to select ms and load only lists from gamespy by default.
