Can't see servers on list.
Postby ~[T]GrimRaPeR~ » Thu Mar 08, 07 11:28 pm
Ok today I turned on Dx and no servers showed up.I tried Dejavus masterserver and still nothing.So I thought I'd install that mmuserinterface mod and now the FGS servers and such show up.Although,I'm looking for augged servers such as Ste's and EL.Why has this happened and how can I fix it to see all servers again?
~[T]GrimRaPeR~
Postby ~[T]GrimRaPeR~ » Thu Mar 08, 07 11:29 pm
Ok,double post.Never mind,turned out to antivirus firewalls.Sorry about this topic.
~[T]GrimRaPeR~
Postby clyzm » Thu Mar 08, 07 11:29 pm
I can't see it either even with MMUser (which doesn't work at all now. The little dialog doesn't even appear.)
I miss EL.
Edit:
Still can't see it. I couldn't see shit but DXMS and FGS for quite a while now. I switched to gamespy but nothing showed up still.
Postby Kaiden » Thu Mar 08, 07 11:34 pm
You have 155? (version) There shouldn't be a text box present with 155 unless you turned something to false in the properties. Also try allowing Dx through your firewall like the topic creater did. ^_^
Postby ~[T]GrimRaPeR~ » Fri Mar 09, 07 12:56 am
Btw how can I uninstall mmsuser thing?It's quite craptacular and lags the loading of servers on my dx.
~[T]GrimRaPeR~
Postby clyzm » Fri Mar 09, 07 6:13 am
~[A]Kaiden~ wrote:You have 155? (version) There shouldn't be a text box present with 155 unless you turned something to false in the properties. Also try allowing Dx through your firewall like the topic creater did. ^_^
Right - I told my firewall to accept DX for network access, it seems to be working. I did this before though no results. I had to wait a longass time for the serverlist to appear as well.
Anyways, I still can't see both MS's.
Postby Dae » Fri Mar 09, 07 10:40 am
There's no reason to uninstall it - just set bCombineServers (or something like that) to False in your DeusEx.ini. It will show you that old box to select ms and load only lists from gamespy by default.
Postby clyzm » Fri Mar 09, 07 10:49 pm
~[A]Daedalus~ wrote:There's no reason to uninstall it - just set bCombineServers (or something like that) to False in your DeusEx.ini. It will show you that old box to select ms and load only lists from gamespy by default.
Right, thanks for that.
It's fine now.
