Game runs too fast
Game runs too fast
Postby mtfsmp » Mon Jan 02, 06 12:00 am
My game goes about twice as fast as it should when I play Deus Ex (the first one). It worked fine on my old computer but it always does this on my new computer with Windows XP. Is there any way to fix it?
mtfsmp
Postby Allan » Mon Jan 02, 06 1:24 am
Fast running can be caused by several things. If the fast running is constant, a simple way to fix it is to up your game settings to counter balane the effect.
however, if the fast-mo is at random, it is possibly your CPU power limit has gone a bit nutzo. However, i have no dea how to fix this at all :S
too fast
Postby mtfsmp » Mon Jan 02, 06 5:51 am
Other games work just fine on my computer. It's only Deus Ex that has trouble with the speed of the game.
mtfsmp
Postby Rödewijk » Mon Jan 02, 06 2:55 pm
wy do i never understand a word of what allan post make it more simple becaus i am stupid :D
Postby Ricci » Sun Jan 08, 06 10:11 am
try typing slomo 1.3?
-Ricci
Ricci
Postby Splitter » Sun Jan 08, 06 12:14 pm
Isn't this something to do with DX incorrectly labelling the speed of the processor? I'm pretty sure there is a command to set it back right :)
»§plíttèr/§plícè«
» ÐÇsß « » eNigma² «
Getting TK'd since 24/11/03
Splitter
Postby AgentSmyth » Sun Jan 08, 06 1:46 pm
tell me this...u see the other games that work on your comp...are they high spec?
AgentSmyth
Postby Bob » Sun Jan 08, 06 3:22 pm
I think Marco had the same problem.
Postby Trailmix » Mon Jan 09, 06 4:11 am
It might not be involved with your processor, but with your video card. A guy in CG (Blurs) had the same problem and it turned out to be his video card making his fps too high.
Trailmix
Postby Hanover Fist » Sun Jan 29, 06 1:34 am
Are you running on a windows XP laptop?
Hanover Fist
Postby ~D[A]rren~ » Sun Jan 29, 06 11:52 am
What difference would a laptop make? Its either Windows XP Home/Pro, or it isn't. Whether its a laptop or not shouldn't make a difference. 8)
Postby VodunLoas » Sun Jan 29, 06 12:21 pm
If its too fast fps, whats the problem then? Who wouldnt want too fast fps? If its not that, just people running around super fast, then its just the slomo speed set too high.
Just enabled cheats and type slomo 1.3 (dunno if thats the default, is it?)
Postby Dae » Sun Jan 29, 06 1:03 pm
VodunLoas wrote:If its too fast fps, whats the problem then? Who wouldnt want too fast fps? If its not that, just people running around super fast, then its just the slomo speed set too high.
Default is 1.
1.3 was used by icx.net, it's quite fast
Postby Alex » Sun Jan 29, 06 1:31 pm
Default is 1.
50 is the best.
Postby Alistair » Wed Feb 08, 06 5:41 pm
I got that once. i think its unbalanced net play, packet wise. me and a friend did it once with a hub and crossovers, we had no device to handle the packets, therefore it went fast. have a look at your net and modem settings. DX is sensitive
Postby al'be:do » Thu Feb 16, 06 2:30 pm
It's simply an AMD Energy saving processor "problem". If you are using Windows you simply have to set "Desktop" in the energy settings, not "minimum energy use".
(Unfortunately the German Windows version, but it should be obvious, though.)
The cause for the fast gameplay is that in energy saving mode (cool'n quiet) the processor multiplicator goes down and the cpu clock runs at e.g. 800MHz. This is the clock rate before the CPU is used by the game. If you start the game the CPU detection of DeusEx reads this Value and uses it instead of the 2000 MHz the game is actually running with (this is the full clock rate of my Athlon 64 3200+). So in my case everything in the game runs faster by the factor 2000/800 = 2.5.
The same problem occurs with Unreal, UT, Infiltration and all other Unreal Engine based games or mods.
al'be:do
al'be:do
Postby ~ô¿ô~Nobody~ » Sat Feb 18, 06 1:02 pm
wow, thanks for the info
a friend of mine has that probem too
Postby Grayfox » Sat Feb 18, 06 10:25 pm
Are you using open gl ?
If so use direct X I have the same problem in single player.
Grayfox
Postby Big Daddy » Tue Apr 11, 06 11:10 pm
I know what the probelm is, this has happened to me many times and I can fix it easily. Someone has screwed about with your game speed either on your server or on another server. The best way to get rid of it is to either recover computer thingy or host a game and change the game speed on the console.
Postby Alex » Wed Apr 12, 06 12:34 pm
±Tantalus[BK]± wrote:I know what the probelm is, this has happened to me many times and I can fix it easily. Someone has screwed about with your game speed either on your server or on another server. The best way to get rid of it is to either recover computer thingy or host a game and change the game speed on the console.
Stop reviving old topics.
Postby clyzm » Wed Apr 12, 06 12:37 pm
Glad I'm not the only one annoyed by this.
