Need to decache anything?
Postby Dae » Wed Feb 15, 06 2:45 pm
Ask here and our top-notch decache specialists will help you as soon as it is possible ;)
Edit: fixed mistake
Postby Spiderbot01 » Thu Feb 16, 06 10:20 pm
Is it possible to decache alrightythens maps?
Postby Bob » Thu Feb 16, 06 11:46 pm
Doesn't he have a site with all his work on it anyway?
Postby Rödewijk » Fri Feb 17, 06 12:40 am
yes he has
Postby Wasted » Fri Feb 17, 06 12:32 pm
Thats helpful. Now tell me what it is.
Postby Hacker_>< » Fri Feb 17, 06 1:39 pm
you can download alrightythens maps from here http://www.freewebs.com/dxalrighty/ but you need to use his gametype to play them
Hacker_><
Postby Dae » Fri Feb 17, 06 2:23 pm
Hacker_>< wrote:but you need to use his gametype to play them
"but"? his MTL add-on is a masterpiece :)
Postby Spiderbot01 » Fri Feb 17, 06 5:39 pm
Only trouble is whenever I try to host them it says 'cant find package alrightygame' despite having version3... ¬_¬
Postby Gishank » Fri Feb 17, 06 6:00 pm
¬_¬ The package is called alrightygamev3 lol.
Postby Spiderbot01 » Fri Feb 17, 06 7:04 pm
Hence me saying 'I have version3'...
Postby ~ô¿ô~Nobody~ » Sat Feb 18, 06 12:29 pm
klop pointed to the name itself
if it says "can't find alrightygame" then it looks for a Alrightygame.u and not for a alrightygameV3.u :wink:
Postby Spiderbot01 » Sat Feb 18, 06 1:08 pm
Surely it would still work with the updated version? Or did Alrighty wangle it so you can use any version at any time/ e.g you could have both version1 and 3 in your system folder and choose either one when hosting, I know it lets you switch from MTL to AR
Postby Gishank » Sat Feb 18, 06 1:29 pm
The newer version overrides the older versions making them obsoleet.
Postby Spiderbot01 » Sat Feb 18, 06 2:27 pm
Then you just proved my point, why would it need alrightygame when Im using alrightygamev3?
Postby Siva » Sat Feb 18, 06 2:58 pm
Because they're DIFFERENT FILES. With Different CODING.
For those that are confused -
If I made a gun, edited the .uc files, made a NEW .u file with the same name, and you had the ORIGINAL .u file, It wouldn't work, would it?
Postby Mastakilla » Sat Feb 18, 06 3:02 pm
[Z]_Spiderbot01_[Z] wrote:Then you just proved my point, why would it need alrightygame when Im using alrightygamev3?
It doesnt, but if you editted your DeusEx.ini and put down
ServerPackages=AlrightyGame
DeusEx will look for AlrightyGame.u and not AlrightyGamev3.u
So you will need ServerPackages=AlrightyGamev3 to make it work.
unless you already have that, in that case I said nothing.
Postby Wasted » Sat Feb 18, 06 9:09 pm
Yay My first time !
Postby Gishank » Sun Feb 19, 06 10:36 am
Hmm, spidey set it to in your DeusEx.ini...
Alrighty game v3.
Postby Allan » Sun Feb 19, 06 1:28 pm
Hmm, are you sure? (Looks at the Mona Lisa), Hmm, yep, it's a masterpiece, the Mona Lisa has no eyebrows :P XD
Good ol' Alrighty :D!
Postby Josh_Stargunner » Sun Apr 29, 07 12:37 pm
i dunno if decaching does this, but i wanna modify alphas m4a1 and what i need from it is the models, so i can apply them to a regular assault rifle and then modify that. do i also have permission to do this?
Don't pick swimming because it's fairly useless!
Josh_Stargunner
Postby Alex » Wed May 02, 07 1:02 pm
(JTB)Godfather wrote:i dunno if decaching does this, but i wanna modify alphas m4a1 and what i need from it is the models, so i can apply them to a regular assault rifle and then modify that. do i also have permission to do this?
1. That's not decaching
2. You can try to export the model & import again. But... nah, nevermind, just good luck :lol:
Postby Allan » Wed May 02, 07 2:57 pm
~[A]lex~ wrote:2. You can try to export the model & import again. But... nah, nevermind, just good luck :lol:
Tried it. It doesn't work :(
Or at least not on TNAG, Tactical, My own SuperMod (Now re-branded as UberMod)... The list goes on :(
Postby Alex » Wed May 02, 07 3:07 pm
As I said "You can try <stuff> good luck :lol: " ;) :P
Postby IllerKiller » Wed May 02, 07 7:24 pm
No, it is very possible. Use DeusExExtractor to extract everything, including models - it can rip models perfectly. It is operated from cmd, but should be easy enough to use if you read the instructions.
~[A]lex~ you are stupid for making fun of someone who is trying to do something, when in fact you do not know enough about the subject in hand.
IllerKiller
Banned user
Postby Alex » Wed May 02, 07 7:37 pm
IllerKiller wrote:No, it is very possible. Use DeusExExtractor to extract everything, including models - it can rip models perfectly. It is operated from cmd, but should be easy enough to use if you read the instructions.
Ever tried doing that with animations? Not just non-moving meshes?
By the way, stop using a proxy, or face a ban.
Postby Dae » Wed May 02, 07 7:47 pm
Deus Ex Extractor does export animations (otherwise Veronika couldn't have made UEd2 fix for Deus Ex).
Postby Alex » Wed May 02, 07 8:09 pm
~[A]Daedalus~ wrote:Deus Ex Extractor does export animations (otherwise Veronika couldn't have made UEd2 fix for Deus Ex).
I tried it some while ago, I think, and then it didn't work. I'll try it later, when I have the required stuff.
Postby IllerKiller » Wed May 02, 07 8:11 pm
This man is right. :)
I am using a proxy because at my school there is a filter which blocks any page with 'Forum' in the title bar, or in the header.
IllerKiller
Banned user
Postby Alex » Wed May 02, 07 8:14 pm
Then use this proxy:
http://www.alphaclan.nl/zalar/
Postby Imperial » Wed May 02, 07 8:47 pm
how about dechacing rain? That close enough for you o.O
