Deus Ex SlimLine
Deus Ex SlimLine
Postby Zantinzuken » Sat Mar 04, 06 8:51 pm
I recently downloaded your Slimline pack for DXMP. Everything was going fine, except for the user.ini
I try to change settings in it to use binds etc. but it doesn't work. There's probably a really obvious reason why this is happening, but i'm too lazy to find it out!
Cheers.
Postby Dae » Sat Mar 04, 06 9:26 pm
I thought it was a glitch with all Deus Ex versions but after I recieved loads of messages saying that they have never seen it before, i realised it is only me. I suppose Russian pirates have fscked my Deus Ex up. I'll make a fix soon.
The only solution I can offer is to replace defuser.ini with user.ini after making any changes to that file.
Postby Seraphiel » Sun Mar 05, 06 11:14 pm
I just made the changes in defuser and it worked fine.
Seraphiel
Postby Zantinzuken » Sun Mar 05, 06 11:16 pm
Yeah i did the same, eventually.
Re: Deus Ex SlimLine
Postby Alistair » Tue Mar 21, 06 5:22 pm
Klépto wrote:I recently downloaded your Slimline pack for DXMP. Everything was going fine, except for the user.ini
I try to change settings in it to use binds etc. but it does work. There's probably a really obvious reason why this is happening, but i'm too lazy to find it out!
Cheers.
I had the same problem. Put them in defuser.ini instead.
