BioRifle style charge-up.
Postby Allan » Wed Mar 08, 06 8:05 pm
Ok, once again, i need the help of the Top Notch Editing Specialists (Prehaps i should start a thread just for my problems :P )
I wanted a weapon that fires like the Bio-Rifle's Alternate fire mode in Unreal Tournament (If you hold the button for long enough, it fires loads of blobs instead of one or two blobs). I already have made a code for blobs like the BioRifle's, but how would i go about making a gun so it would wait for something like 5 seconds at the max with the trigger held down, and for every 0.5 seconds up to this 5 seconds mark, it should add 1 blob to the amount discharged when the trigger is let go, but if it goes over this 5 second mark, the gun backfires, and the player is sprayed in the blobs themselves. Would this be possible for DXMP?
Postby Snakey » Wed Mar 08, 06 8:26 pm
The backfire bit would be extremely annoying.
Re: BioRifle style charge-up.
Postby MrBlackDX » Wed Mar 08, 06 8:38 pm
Allan wrote:Ok, once again, i need the help of the Top Notch Editing Specialists (Prehaps i should start a thread just for my problems :P )
can you look at the BioRifles UT code?
Postby Tsukasa Nishino » Wed Mar 08, 06 10:25 pm
didnt we have one of those before? that tnag mod?
Tsukasa Nishino
Postby Snakey » Wed Mar 08, 06 10:31 pm
Tsukasa Nishino wrote:didnt we have one of those before? that tnag mod?
He wants to know how the Bio Rifle from tnag (And UT) accomplishes its charge up effect.
Postby Alex » Wed Mar 08, 06 10:31 pm
Bio Rifle from tnag doesn't has charge up effect.
Anyways... I looked into the source of it...
// UT_BioRifle.
class UT_BioRifle extends TournamentWeapon;
var float ChargeSize, Count;
var bool bBurst;
simulated function PlayIdleAnim()
   if ( Mesh == PickupViewMesh )
      return;
   if ( (Owner != None) && (VSize(Owner.Velocity) > 10) )
      PlayAnim('Walking',0.3,0.3);
   else
      TweenAnim('Still', 1.0);
   Enable('AnimEnd');
function float RateSelf( out int bUseAltMode )
   local float EnemyDist;
   local bool bRetreating;
   local vector EnemyDir;
   if ( AmmoType.AmmoAmount <=0 )
      return -2;
   bUseAltMode = 0;
   if ( Pawn(Owner).Enemy == None )
      return AIRating;
   EnemyDir = Pawn(Owner).Enemy.Location - Owner.Location;
   EnemyDist = VSize(EnemyDir);
   if ( EnemyDist > 1400 )
      return 0;
   bRetreating = ( ((EnemyDir/EnemyDist) Dot Owner.Velocity) < -0.6 );
   if ( (EnemyDist > 600) && (EnemyDir.Z > -0.4 * EnemyDist) )
      // only use if enemy not too far and retreating
      if ( !bRetreating )
         return 0;
      return AIRating;
   bUseAltMode = int( FRand() < 0.3 );
   if ( bRetreating || (EnemyDir.Z < -0.7 * EnemyDist) )
      return (AIRating + 0.18);
   return AIRating;
// return delta to combat style
function float SuggestAttackStyle()
   return -0.3;
function float SuggestDefenseStyle()
   return -0.4;
function AltFire( float Value )
   bPointing=True;
   if ( AmmoType == None )
      // ammocheck
      GiveAmmo(Pawn(Owner));
   if ( AmmoType.UseAmmo(1) )
      GoToState('AltFiring');
      bCanClientFire = true;
      ClientAltFire(Value);
simulated function bool ClientAltFire( float Value )
   local bool bResult;
   InstFlash = 0.0;
   bResult = Super.ClientAltFire(value);
   InstFlash = Default.InstFlash;
   return bResult;
function Projectile ProjectileFire(class<projectile> ProjClass, float ProjSpeed, bool bWarn)
   local Vector Start, X,Y,Z;
   Owner.MakeNoise(Pawn(Owner).SoundDampening);
   GetAxes(Pawn(owner).ViewRotation,X,Y,Z);
   Start = Owner.Location + CalcDrawOffset() + FireOffset.X * X + FireOffset.Y * Y + FireOffset.Z * Z;
   AdjustedAim = pawn(owner).AdjustToss(ProjSpeed, Start, 0, True, (bWarn || (FRand() < 0.4)));
   return Spawn(ProjClass,,, Start,AdjustedAim);
simulated function PlayAltFiring()
   PlayOwnedSound(Sound'Botpack.BioRifle.BioAltRep', SLOT_Misc, 1.3*Pawn(Owner).SoundDampening);    //loading goop
   PlayAnim('Charging',0.24,0.05);
state ClientAltFiring
   simulated function Tick(float DeltaTime)
      if ( bBurst )
         return;
      if ( !bCanClientFire || (Pawn(Owner) == None) )
         GotoState('');
      else if ( Pawn(Owner).bAltFire == 0 )
         PlayAltBurst();
         bBurst = true;
   simulated function AnimEnd()
      if ( bBurst )
         bBurst = false;
         Super.AnimEnd();
      else
         TweenAnim('Loaded', 0.5);
state AltFiring
   ignores AnimEnd;
   function Tick( float DeltaTime )
      //SetLocation(Owner.Location);
      if ( ChargeSize < 4.1 )
         Count += DeltaTime;
         if ( (Count > 0.5) && AmmoType.UseAmmo(1) )
            ChargeSize += Count;
            Count = 0;
            if ( (PlayerPawn(Owner) == None) && (FRand() < 0.2) )
               GoToState('ShootLoad');
      if( (pawn(Owner).bAltFire==0) )
   function BeginState()
      ChargeSize = 0.0;
      Count = 0.0;
   function EndState()
      ChargeSize = FMin(ChargeSize, 4.1);
Begin:
   FinishAnim();
state ShootLoad
   function ForceFire()
      bForceFire = true;
   function ForceAltFire()
      bForceAltFire = true;
   function Fire(float F)
   function AltFire(float F)
   function Timer()
      local rotator R;
      local vector start, X,Y,Z;
      R = Owner.Rotation;
      R.Yaw = R.Yaw + Rand(8000) - 4000;
      R.Pitch = R.Pitch + Rand(1000) - 500;
      Spawn(AltProjectileClass,,, Start,R);
      R = Owner.Rotation;
   function AnimEnd()
      Finish();
      Local Projectile Gel;
      Gel = ProjectileFire(AltProjectileClass, AltProjectileSpeed, bAltWarnTarget);
      Gel.DrawScale = 1.0 + 0.8 * ChargeSize;
      PlayAltBurst();
Begin:
// Finish a firing sequence
function Finish()
   local bool bForce, bForceAlt;
   bForce = bForceFire;
   bForceAlt = bForceAltFire;
   bForceFire = false;
   bForceAltFire = false;
   if ( bChangeWeapon )
      GotoState('DownWeapon');
   else if ( PlayerPawn(Owner) == None )
      Pawn(Owner).bAltFire = 0;
      Super.Finish();
   else if ( (AmmoType.AmmoAmount<=0) || (Pawn(Owner).Weapon != self) )
      GotoState('Idle');
   else if ( (Pawn(Owner).bFire!=0) || bForce )
      Global.Fire(0);
   else if ( (Pawn(Owner).bAltFire!=0) || bForceAlt )
      Global.AltFire(0);
   else
      GotoState('Idle');
simulated function PlayAltBurst()
   if ( Owner.IsA('PlayerPawn') )
      PlayerPawn(Owner).ClientInstantFlash( InstFlash, InstFog);
   PlayOwnedSound(FireSound, SLOT_Misc, 1.7*Pawn(Owner).SoundDampening);   //shoot goop
   PlayAnim('Fire',0.4, 0.05);
simulated function PlayFiring()
   PlayOwnedSound(AltFireSound, SLOT_None, 1.7*Pawn(Owner).SoundDampening);   //fast fire goop
   LoopAnim('Fire',0.65 + 0.4 * FireAdjust, 0.05);
     WeaponDescription="Classification: Toxic Rifle\n\nPrimary Fire: Wads of Tarydium byproduct are lobbed at a medium rate of fire.\n\nSecondary Fire: When trigger is held down, the BioRifle will create a much larger wad of byproduct. When this wad is launched, it will burst into smaller wads which will adhere to any surfaces.\n\nTechniques: Byproducts will adhere to walls, floors, or ceilings. Chain reactions can be caused by covering entryways with this lethal green waste."
     InstFlash=-0.150000
     InstFog=(X=139.000000,Y=218.000000,Z=72.000000)
     AmmoName=Class'Botpack.BioAmmo'
     PickupAmmoCount=25
     bAltWarnTarget=True
     bRapidFire=True
     FiringSpeed=1.000000
     FireOffset=(X=12.000000,Y=-11.000000,Z=-6.000000)
     ProjectileClass=Class'Botpack.UT_BioGel'
     AltProjectileClass=Class'Botpack.BioGlob'
     AIRating=0.600000
     RefireRate=0.900000
     AltRefireRate=0.700000
     FireSound=Sound'UnrealI.BioRifle.GelShot'
     AltFireSound=Sound'UnrealI.BioRifle.GelShot'
     CockingSound=Sound'UnrealI.BioRifle.GelLoad'
     SelectSound=Sound'UnrealI.BioRifle.GelSelect'
     DeathMessage="%o drank a glass of %k's dripping green load."
     NameColor=(R=0,B=0)
     AutoSwitchPriority=3
     InventoryGroup=3
     PickupMessage="You got the GES BioRifle."
     ItemName="GES Bio Rifle"
     PlayerViewOffset=(X=1.700000,Y=-0.850000,Z=-0.950000)
     PlayerViewMesh=LodMesh'Botpack.BRifle2'
     BobDamping=0.972000
     PickupViewMesh=LodMesh'Botpack.BRifle2Pick'
     ThirdPersonMesh=LodMesh'Botpack.BRifle23'
     StatusIcon=Texture'Botpack.Icons.UseBio'
     PickupSound=Sound'UnrealShare.Pickups.WeaponPickup'
     bNoSmooth=False
     CollisionHeight=19.000000
Postby Snakey » Wed Mar 08, 06 10:33 pm
Thats a hefty script..
Postby Tsukasa Nishino » Wed Mar 08, 06 10:41 pm
wow and this is for one gun only, imagine the codes for heavy weapons
Tsukasa Nishino
Postby Alex » Wed Mar 08, 06 10:43 pm
Heavy weapon:
// UT_Eightball.
class UT_Eightball extends TournamentWeapon;
var name LoadAnim[6], RotateAnim[6], FireAnim[6];
var int RocketsLoaded, ClientRocketsLoaded;
var bool bFireLoad,bTightWad, bInstantRocket, bAlwaysInstant, bClientDone, bRotated, bPendingLock;
var Actor LockedTarget, NewTarget, OldTarget;
Replication
   reliable if ( bNetOwner && (Role == ROLE_Authority) )
      bInstantRocket;
function setHand(float Hand)
   Super.SetHand(Hand);
   if ( Hand == 0 )
      PlayerViewOffset.Y = 0;
   if ( Hand == 1 )
      Mesh = mesh(DynamicLoadObject("Botpack.EightML", class'Mesh'));
   else
      Mesh = mesh'EightM';
function BecomeItem()
   local TournamentPlayer TP;
   Super.BecomeItem();
   TP = TournamentPlayer(Instigator);
   bInstantRocket = bAlwaysInstant || ( (TP != None) && TP.bInstantRocket );
simulated event RenderTexture(ScriptedTexture Tex)
   local Color C;
   local string Temp;
   if ( AmmoType != None )
      Temp = String(AmmoType.AmmoAmount);
   while(Len(Temp) < 3) Temp = "0"$Temp;
   C.R = 255;
   C.G = 0;
   C.B = 0;
   Tex.DrawColoredText( 2, 10, Temp, Font'LEDFont2', C );
simulated event RenderOverlays( canvas Canvas )
   Texture'MiniAmmoled'.NotifyActor = Self;
   Super.RenderOverlays(Canvas);
   Texture'MiniAmmoled'.NotifyActor = None;
simulated function PostRender( canvas Canvas )
   local float XScale;
   Super.PostRender(Canvas);
   bOwnsCrossHair = bLockedOn;
   if ( bOwnsCrossHair )
      // if locked on, draw special crosshair
      XScale = FMax(1.0, Canvas.ClipX/640.0);
      Canvas.SetPos(0.5 * (Canvas.ClipX - Texture'Crosshair6'.USize * XScale), 0.5 * (Canvas.ClipY - Texture'Crosshair6'.VSize * XScale));
      Canvas.Style = ERenderStyle.STY_Normal;
      Canvas.DrawIcon(Texture'Crosshair6', 1.0);
      Canvas.Style = 1;
simulated function PlayLoading(float rate, int num)
   if ( Owner == None )
      return;
   Owner.PlayOwnedSound(CockingSound, SLOT_None, Pawn(Owner).SoundDampening);
   PlayAnim(LoadAnim[num],, 0.05);
simulated function PlayRotating(int num)
   Owner.PlayOwnedSound(Misc3Sound, SLOT_None, 0.1*Pawn(Owner).SoundDampening);
   PlayAnim(RotateAnim[num],, 0.05);
simulated function PlayRFiring(int num)
      PlayerPawn(Owner).shakeview(ShakeTime, ShakeMag*RocketsLoaded, ShakeVert); //shake player view
      PlayerPawn(Owner).ClientInstantFlash( -0.4, vect(650, 450, 190));
   if ( Affector != None )
      Affector.FireEffect();
   if ( bFireLoad )
      PlayOwnedSound(class'RocketMk2'.Default.SpawnSound, SLOT_None, 4.0*Pawn(Owner).SoundDampening);
   else
      PlayOwnedSound(AltFireSound, SLOT_None, 4.0*Pawn(Owner).SoundDampening);
   if ( bFireLoad && bInstantRocket )
      PlayAnim(FireAnim[num], 0.54, 0.05);
   else
      PlayAnim(FireAnim[num], 0.6, 0.05);
      return;
   if (AnimSequence == LoadAnim[0] )
      PlayAnim('Idle',0.1,0.0);
   else
      TweenAnim('Idle', 0.5);
// tell bot how valuable this weapon would be to use, based on the bot's combat situation
// also suggest whether to use regular or alternate fire mode
   local float EnemyDist, Rating;
   local Pawn P;
   // don't recommend self if out of ammo
      return -2;
   // by default use regular mode (rockets)
   bUseAltMode = 0;
   P = Pawn(Owner);
   if ( P.Enemy == None )
      return AIRating;
   // if standing on a lift, make sure not about to go around a corner and lose sight of target
   // (don't want to blow up a rocket in bot's face)
   if ( (P.Base != None) && (P.Base.Velocity != vect(0,0,0))
      && !P.CheckFutureSight(0.1) )
      return 0.1;
   EnemyDir = P.Enemy.Location - Owner.Location;
   Rating = AIRating;
   // don't pick rocket launcher is enemy is too close
   if ( EnemyDist < 360 )
      if ( P.Weapon == self )
         // don't switch away from rocket launcher unless really bad tactical situation
         if ( (EnemyDist > 230) || ((P.Health < 50) && (P.Health < P.Enemy.Health - 30)) )
            return Rating;
      return 0.05 + EnemyDist * 0.001;
   // increase rating for situations for which rocket launcher is well suited
   if ( P.Enemy.IsA('StationaryPawn') )
      Rating += 0.4;
   // rockets are good if higher than target, bad if lower than target
   if ( Owner.Location.Z > P.Enemy.Location.Z + 120 )
      Rating += 0.25;
   else if ( P.Enemy.Location.Z > Owner.Location.Z + 160 )
      Rating -= 0.35;
   else if ( P.Enemy.Location.Z > Owner.Location.Z + 80 )
      Rating -= 0.05;
   // decide if should use alternate fire (grenades) instead
   if ( (Owner.Physics == PHYS_Falling) || Owner.Region.Zone.bWaterZone )
      bUseAltMode = 0;
   else if ( EnemyDist < -1.5 * EnemyDir.Z )
      bUseAltMode = int( FRand() < 0.5 );
   else
      // grenades are good covering fire when retreating
      bRetreating = ( ((EnemyDir/EnemyDist) Dot Owner.Velocity) < -0.7 );
      bUseAltMode = 0;
      if ( bRetreating && (EnemyDist < 800) && (FRand() < 0.4) )
         bUseAltMode = 1;
   return Rating;
// return delta to combat style while using this weapon
   // recommend backing off if target is too close
   EnemyDist = VSize(Pawn(Owner).Enemy.Location - Owner.Location);
   if ( EnemyDist < 600 )
      if ( EnemyDist < 300 )
         return -1.5;
      else
         return -0.7;
   else
      return -0.2;
function Fire( float Value )
   bPointing=True;
      // ammocheck
      if ( bInstantRocket )
         bFireLoad = True;
         RocketsLoaded = 1;
         GotoState('');
         GotoState('FireRockets', 'Begin');
      else if ( Instigator.IsA('Bot') )
         if ( LockedTarget != None )
            bFireLoad = True;
            RocketsLoaded = 1;
            Instigator.bFire = 0;
            bPendingLock = true;
            GotoState('');
            return;
         else if ( (NewTarget != None) && !NewTarget.IsA('StationaryPawn')
            && (FRand() < 0.8)
            && (VSize(Instigator.Location - NewTarget.Location) > 400 + 400 * (1.25 - TimerCounter) + 1300 * FRand()) )
            GotoState('Idle','PendingLock');
            return;
         else if ( !Bot(Owner).bNovice
               && (FRand() < 0.7)
               && IsInState('Idle') && (Instigator.Enemy != None)
               && ((Instigator.Enemy == Instigator.Target) || (Instigator.Target == None))
               && !Instigator.Enemy.IsA('StationaryPawn')
               && (VSize(Instigator.Location - Instigator.Enemy.Location) > 700 + 1300 * FRand())
               && (VSize(Instigator.Location - Instigator.Enemy.Location) < 2000) )
            NewTarget = CheckTarget();
            OldTarget = NewTarget;
            if ( NewTarget == Instigator.Enemy )
               if ( TimerCounter > 0.6 )
                  SetTimer(1.0, true);
               return;
         bPendingLock = false;
         GotoState('NormalFire');
      else
simulated function bool ClientFire( float Value )
   if ( bCanClientFire && ((Role == ROLE_Authority) || (AmmoType == None) || (AmmoType.AmmoAmount > 0)) )
      GotoState('ClientFiring');
      return true;
   return false;
simulated function FiringRockets()
   PlayRFiring(ClientRocketsLoaded - 1);
   bClientDone = true;
   Disable('Tick');
   bPointing=True;
      // ammocheck
      GotoState('ClientAltFiring');
      return true;
   return false;
function Actor CheckTarget()
   local Actor ETarget;
   local float bestDist, bestAim;
   local Pawn PawnOwner;
   local rotator AimRot;
   local int diff;
   PawnOwner = Pawn(Owner);
   bPointing = false;
      GetAxes(PawnOwner.ViewRotation,X,Y,Z);
      bestAim = 0.93;
      ETarget = PawnOwner.PickTarget(bestAim, bestDist, X, Start);
   else if ( PawnOwner.Enemy == None )
      return None;
   else if ( Owner.IsA('Bot') && Bot(Owner).bNovice )
      return None;
   else if ( VSize(PawnOwner.Enemy.Location - PawnOwner.Location) < 2000 )
      Start = Owner.Location + CalcDrawOffset() + FireOffset.Z * vect(0,0,1);
      AimRot = rotator(PawnOwner.Enemy.Location - Start);
      diff = abs((AimRot.Yaw & 65535) - (PawnOwner.Rotation.Yaw & 65535));
      if ( (diff > 7200) && (diff < 58335) )
         return None;
      // check if can hold lock
      if ( !bPendingLock ) //not already locked
         AimRot = rotator(PawnOwner.Enemy.Location + (3 - PawnOwner.Skill) * 0.3 * PawnOwner.Enemy.Velocity - Start);
         if ( (diff > 16000) && (diff < 49535) )
            return None;
      // check line of sight
      ETarget = Trace(X,Y, PawnOwner.Enemy.Location, Start, false);
      if ( ETarget != None )
         return None;
      return PawnOwner.Enemy;
   bPointing = (ETarget != None);
   Return ETarget;
state AltFiring
      if( (pawn(Owner).bAltFire==0) || (RocketsLoaded > 5) )  // If if Fire button down, load up another
          GoToState('FireRockets');
   function AnimEnd()
      if ( bRotated )
         bRotated = false;
         PlayLoading(1.1, RocketsLoaded);
      else
         if ( RocketsLoaded == 6 )
            GotoState('FireRockets');
            return;
         RocketsLoaded++;
         AmmoType.UseAmmo(1);
         if ( (PlayerPawn(Owner) == None) && ((FRand() > 0.5) || (Pawn(Owner).Enemy == None)) )
         bPointing = true;
         Owner.MakeNoise(0.6 * Pawn(Owner).SoundDampening);
         RotateRocket();
   function RotateRocket()
      if (AmmoType.AmmoAmount<=0)
         return;
      PlayRotating(RocketsLoaded-1);
      bRotated = true;
      Super.BeginState();
      RocketsLoaded = 1;
      bFireLoad = False;
      RotateRocket();
Begin:
   bLockedOn = False;
state NormalFire
   function bool SplashJump()
      return true;
         && ((Pawn(Owner).MoveTarget != Pawn(Owner).Target)
            || (LockedTarget != None)
            || ( Mover(Owner.Base) != None )
            || ((Owner.Physics == PHYS_Falling) && (Owner.Velocity.Z < 5))
            || (VSize(Owner.Location - Pawn(Owner).Target.Location) < 400)
            || !Pawn(Owner).CheckFutureSight(0.15)) )
         Pawn(Owner).bFire = 0;
      if( pawn(Owner).bFire==0 || RocketsLoaded > 5)  // If Fire button down, load up another
   function AnimEnd()
      if ( bRotated )
         bRotated = false;
      else
            return;
         RocketsLoaded++;
         if (pawn(Owner).bAltFire!=0) bTightWad=True;
         if ( Pawn(NewTarget) != None )
            Pawn(NewTarget).WarnTarget(Pawn(Owner), ProjectileSpeed, vector(Pawn(Owner).ViewRotation));
            If ( NewTarget != LockedTarget )
               LockedTarget = None;
               Owner.PlaySound(Misc2Sound, SLOT_None, Pawn(Owner).SoundDampening);
               bLockedOn=False;
            else if (LockedTarget != None)
                Owner.PlaySound(Misc1Sound, SLOT_None, Pawn(Owner).SoundDampening);
         bPointing = true;
         RotateRocket();
      Super.BeginState();
      bFireLoad = True;
      RocketsLoaded = 1;
      RotateRocket();
         if ( FRand() > 0.33 )
         if ( Pawn(Owner).bFire == 0 )
            return;
      if ( AmmoType.AmmoAmount <= 0 )
         return;
      if ( AmmoType.AmmoAmount == 1 )
      bRotated = true;
Begin:
   Sleep(0.0);
state Idle
   function Timer()
      if ( NewTarget == OldTarget )
         LockedTarget = NewTarget;
         If (LockedTarget != None)
            bLockedOn=True;
            Owner.PlaySound(Misc1Sound, SLOT_None,Pawn(Owner).SoundDampening);
            if ( (Pawn(LockedTarget) != None) && (FRand() < 0.7) )
               Pawn(LockedTarget).WarnTarget(Pawn(Owner), ProjectileSpeed, vector(Pawn(Owner).ViewRotation));
            if ( bPendingLock )
               bFireLoad = True;
               RocketsLoaded = 1;
               return;
      else if( (OldTarget != None) && (NewTarget == None) )
         Owner.PlaySound(Misc2Sound, SLOT_None,Pawn(Owner).SoundDampening);
         bLockedOn = False;
      else
         bLockedOn = False;
Begin:
   if (Pawn(Owner).bFire!=0) Fire(0.0);
   if (Pawn(Owner).bAltFire!=0) AltFire(0.0);
   bPointing=False;
      Pawn(Owner).SwitchToBestWeapon();  //Goto Weapon that has Ammo
   PlayIdleAnim();
   OldTarget = CheckTarget();
   SetTimer(1.25,True);
   bLockedOn = False;
PendingLock:
   if ( bPendingLock )
      bPointing = true;
   if ( TimerRate <= 0 )
state ClientReload
   simulated function bool ClientFire(float Value)
      bForceFire = bForceFire || ( bCanClientFire && (Pawn(Owner) != None) && (AmmoType.AmmoAmount > 0) );
      return bForceFire;
   simulated function bool ClientAltFire(float Value)
      bForceAltFire = bForceAltFire || ( bCanClientFire && (Pawn(Owner) != None) && (AmmoType.AmmoAmount > 0) );
      return bForceAltFire;
      if ( bCanClientFire && (PlayerPawn(Owner) != None) && (AmmoType.AmmoAmount > 0) )
         if ( bForceFire || (Pawn(Owner).bFire != 0) )
            Global.ClientFire(0);
            return;
         else if ( bForceAltFire || (Pawn(Owner).bAltFire != 0) )
            Global.ClientAltFire(0);
            return;
      GotoState('');
      Global.AnimEnd();
   simulated function EndState()
      bForceFire = false;
   simulated function BeginState()
      bForceFire = false;
state ClientFiring
      if ( (Pawn(Owner).bFire == 0) || (Ammotype.AmmoAmount <= 0) )
         FiringRockets();
         GotoState('');
      else if ( bClientDone )
         PlayLoading(1.5,0);
         GotoState('ClientReload');
      else if ( bRotated )
         PlayLoading(1.1, ClientRocketsLoaded);
         bRotated = false;
         ClientRocketsLoaded++;
      else
         if ( bInstantRocket || (ClientRocketsLoaded == 6) )
            FiringRockets();
            return;
         Enable('Tick');
         PlayRotating(ClientRocketsLoaded - 1);
         bRotated = true;
      bFireLoad = true;
         ClientRocketsLoaded = 1;
         FiringRockets();
      else
         bRotated = true;
      ClientRocketsLoaded = 0;
      bClientDone = false;
      bRotated = false;
      if ( (Pawn(Owner).bAltFire == 0) || (Ammotype.AmmoAmount <= 0) )
         FiringRockets();
         GotoState('');
         PlayLoading(1.5,0);
         bRotated = false;
      else
         if ( ClientRocketsLoaded == 6 )
            FiringRockets();
            return;
         Enable('Tick');
         bRotated = true;
      bFireLoad = false;
      bRotated = true;
      bRotated = false;
state FireRockets
   function Fire(float F) {}
   function AltFire(float F) {}
      bForceFire = true;
      return false;
      local vector FireLocation, StartLoc, X,Y,Z;
      local rotator FireRot, RandRot;
      local rocketmk2 r;
      local UT_SeekingRocket s;
      local ut_grenade g;
      local float Angle, RocketRad;
      local pawn BestTarget, PawnOwner;
      local PlayerPawn PlayerOwner;
      local int DupRockets;
      local bool bMultiRockets;
      if ( PawnOwner == None )
         return;
      PawnOwner.PlayRecoil(FiringSpeed);
      PlayerOwner = PlayerPawn(Owner);
      Angle = 0;
      DupRockets = RocketsLoaded - 1;
      if (DupRockets < 0) DupRockets = 0;
      if ( PlayerOwner == None )
         bTightWad = ( FRand() * 4 < PawnOwner.skill );
      StartLoc = Owner.Location + CalcDrawOffset() + FireOffset.X * X + FireOffset.Y * Y + FireOffset.Z * Z;
      if ( bFireLoad )
         AdjustedAim = PawnOwner.AdjustAim(ProjectileSpeed, StartLoc, AimError, True, bWarnTarget);
      else
         AdjustedAim = PawnOwner.AdjustToss(AltProjectileSpeed, StartLoc, AimError, True, bAltWarnTarget);
      if ( PlayerOwner != None )
         AdjustedAim = PawnOwner.ViewRotation;
      PlayRFiring(RocketsLoaded-1);
      Owner.MakeNoise(PawnOwner.SoundDampening);
      if ( !bFireLoad )
         bLockedOn = false;
      else if ( LockedTarget != None )
         BestTarget = Pawn(CheckTarget());
         if ( (LockedTarget!=None) && (LockedTarget != BestTarget) )
            bLockedOn=False;
      else
         BestTarget = None;
      bPointing = true;
      FireRot = AdjustedAim;
      RocketRad = 4;
      if (bTightWad || !bFireLoad) RocketRad=7;
      bMultiRockets = ( RocketsLoaded > 1 );
      While ( RocketsLoaded > 0 )
         if ( bMultiRockets )
            Firelocation = StartLoc - (Sin(Angle)*RocketRad - 7.5)*Y + (Cos(Angle)*RocketRad - 7)*Z - X * 4 * FRand();
         else
            FireLocation = StartLoc;
         if (bFireLoad)
            if ( Angle > 0 )
               if ( Angle < 3 && !bTightWad)
                  FireRot.Yaw = AdjustedAim.Yaw - Angle * 600;
               else if ( Angle > 3.5 && !bTightWad)
                  FireRot.Yaw = AdjustedAim.Yaw + (Angle - 3)  * 600;
               else
                  FireRot.Yaw = AdjustedAim.Yaw;
               s = Spawn( class 'ut_SeekingRocket',, '', FireLocation,FireRot);
               s.Seeking = LockedTarget;
               s.NumExtraRockets = DupRockets;
               if ( Angle > 0 )
                  s.Velocity *= (0.9 + 0.2 * FRand());
            else
               r = Spawn( class'rocketmk2',, '', FireLocation,FireRot);
               r.NumExtraRockets = DupRockets;
               if (RocketsLoaded>4 && bTightWad) r.bRing=True;
               if ( Angle > 0 )
                  r.Velocity *= (0.9 + 0.2 * FRand());
         else
            g = Spawn( class 'ut_Grenade',, '', FireLocation,AdjustedAim);
            g.NumExtraGrenades = DupRockets;
            if ( DupRockets > 0 )
               RandRot.Pitch = FRand() * 1500 - 750;
               RandRot.Yaw = FRand() * 1500 - 750;
               RandRot.Roll = FRand() * 1500 - 750;
               g.Velocity = g.Velocity >> RandRot;
         Angle += 1.0484; //2*3.1415/6;
         RocketsLoaded--;
      bTightWad=False;
      bRotated = false;
   function AnimEnd()
      if ( !bRotated && (AmmoType.AmmoAmount > 0) )
         PlayLoading(1.5,0);
         RocketsLoaded = 1;
         bRotated = true;
         return;
      Finish();
Begin:
     LoadAnim(0)=load1
     LoadAnim(1)=Load2
     LoadAnim(2)=Load3
     LoadAnim(3)=Load4
     LoadAnim(4)=Load5
     LoadAnim(5)=Load6
     RotateAnim(0)=Rotate1
     RotateAnim(1)=Rotate2
     RotateAnim(2)=Rotate3
     RotateAnim(3)=Rotate4
     RotateAnim(4)=Rotate5
     RotateAnim(5)=Rotate3
     FireAnim(0)=Fire1
     FireAnim(1)=Fire2
     FireAnim(2)=Fire3
     FireAnim(3)=Fire4
     FireAnim(4)=Fire2
     FireAnim(5)=Fire3
     WeaponDescription="Classification: Heavy Ballistic\n\nPrimary Fire: Slow moving but deadly rockets are fired at opponents. Trigger can be held down to load up to six rockets at a time, which can be fired at once.\n\nSecondary Fire: Grenades are lobbed from the barrel. Secondary trigger can be held as well to load up to six grenades.\n\nTechniques: Keeping this weapon pointed at an opponent will cause it to lock on, and while the gun is locked the next rocket fired will be a homing rocket.  Because the Rocket Launcher can load up multiple rockets, it fires when you release the fire button.  If you prefer, it can be configured to fire a rocket as soon as you press fire button down, at the expense of the multiple rocket load-up feature.  This is set in the Input Options menu."
     AmmoName=Class'Botpack.RocketPack'
     PickupAmmoCount=6
     bWarnTarget=True
     bAltWarnTarget=True
     bSplashDamage=True
     bRecommendSplashDamage=True
     FireOffset=(X=10.000000,Y=-5.000000,Z=-8.800000)
     ProjectileClass=Class'Botpack.RocketMk2'
     AltProjectileClass=Class'Botpack.UT_Grenade'
     shakemag=350.000000
     shaketime=0.200000
     shakevert=7.500000
     AIRating=0.750000
     RefireRate=0.250000
     AltRefireRate=0.250000
     AltFireSound=Sound'UnrealShare.Eightball.EightAltFire'
     CockingSound=Sound'UnrealShare.Eightball.Loading'
     SelectSound=Sound'UnrealShare.Eightball.Selecting'
     Misc1Sound=Sound'UnrealShare.Eightball.SeekLock'
     Misc2Sound=Sound'UnrealShare.Eightball.SeekLost'
     Misc3Sound=Sound'UnrealShare.Eightball.BarrelMove'
     DeathMessage="%o was smacked down by %k's %w."
     NameColor=(G=0,B=0)
     AutoSwitchPriority=9
     InventoryGroup=9
     PickupMessage="You got the Rocket Launcher."
     ItemName="Rocket Launcher"
     PlayerViewOffset=(X=2.400000,Y=-1.000000,Z=-2.200000)
     PlayerViewMesh=LodMesh'Botpack.Eightm'
     PlayerViewScale=2.000000
     BobDamping=0.975000
     PickupViewMesh=LodMesh'Botpack.Eight2Pick'
     ThirdPersonMesh=LodMesh'Botpack.EightHand'
     StatusIcon=Texture'Botpack.Icons.Use8ball'
     bNoSmooth=False
     CollisionHeight=10.000000
Postby Tsukasa Nishino » Wed Mar 08, 06 10:46 pm
please don't tell me that melee weapons are just as long (logically its not possible)
Tsukasa Nishino
Postby Wasted » Wed Mar 08, 06 10:46 pm
Why imagine, You have Alex. Straight to the point. :roll:
Postby Alex » Wed Mar 08, 06 10:47 pm
ChainSaw is pretty small :)
// ChainSaw.
class ChainSaw extends TournamentWeapon;
var() float Range;
var() sound HitSound, DownSound;
var Playerpawn LastHit;
   bUseAltMode = 0;
   if ( (Pawn(Owner) == None) || (Pawn(Owner).Enemy == None) )
      return 0;
   if ( EnemyDist > 400 )
      return -2;
   if ( EnemyDist < 110 )
      bUseAltMode = 1;
   return ( FMin(1.0, 81/(EnemyDist + 1)) );
   return 1.0;
   return -0.7;
   bPointing=True;
   Pawn(Owner).PlayRecoil(FiringSpeed);
   ClientFire(value);
   TraceFire(0.0);
   LoopAnim( 'Jab2', 0.7, 0.0 );
   AmbientSound = HitSound;
   SoundVolume = 255;
   GotoState('AltFiring');
   bPointing=True;
   PlayAnim( 'Swipe', 0.6 );
   SoundVolume = 255;
simulated function EndAltFiring()
   AmbientSound = Sound'Botpack.ChainIdle';
   TweenAnim('Idle', 1.0);
state NormalFire
   ignores AnimEnd;
      Super.BeginState();
      SoundVolume = 255;
   function EndState()
      Super.EndState();
      SoundVolume = Default.SoundVolume;
Begin:
   Sleep(0.15);
   if ( PlayerPawn(Owner) != None )
      PlayerPawn(Owner).ShakeView(ShakeTime, ShakeMag, ShakeVert);
   TraceFire(0.0);
   Sleep(0.15);
   if ( LastHit != None )
      LastHit.ClientFlash( -0.38, vect(530, 90, 90));
      LastHit.ShakeView(0.25, 600, 6);
      Finish();
   Goto('Begin');
state ClientFiring
      Super.EndState();
      if ( AnimSequence != 'Idle' )
         EndAltFiring();
      else if ( !bCanClientFire )
         GotoState('');
      else if ( Pawn(Owner) == None )
         PlayIdleAnim();
         GotoState('');
      else if ( Pawn(Owner).bFire != 0 )
      else if ( Pawn(Owner).bAltFire != 0 )
      else
         PlayIdleAnim();
         GotoState('');
   function EndState()
      Super.EndState();
state AltFiring
   ignores AnimEnd;
      Super.BeginState();
      SoundVolume = 255;
   function EndState()
      Super.EndState();
Begin:
   Sleep(0.1);
   FinishAnim();
   EndAltFiring();
   FinishAnim();
   Finish();
state Idle
   ignores animend;
   function bool PutDown()
      return True;
Begin:
   bPointing=False;
   if ( (AmmoType != None) && (AmmoType.AmmoAmount<=0) )
   if ( Pawn(Owner).bFire!=0 )
      Fire(0.0);
   if ( Pawn(Owner).bAltFire!=0 )
      AltFire(0.0);
   FinishAnim();
   AnimFrame=0;
   PlayIdleAnim();
   Goto('Begin');
   if ( Mesh != PickupViewMesh )
      PlayAnim( 'Idle', 1.0, 0.0 );
function Finish()
      return;
      if ( (Pawn(Owner).bFire != 0) && (FRand() < RefireRate) )
         Global.Fire(0);
      else if ( (Pawn(Owner).bAltFire != 0) && (FRand() < AltRefireRate) )
         Global.AltFire(0);
      else
         Pawn(Owner).StopFiring();
         GotoState('Idle');
      return;
      Global.Fire(0);
   else if ( Pawn(Owner).bAltFire!=0 )
      Global.AltFire(0);
   else
      GotoState('Idle');
function Slash()
   local vector HitLocation, HitNormal, EndTrace, X, Y, Z, Start;
   local actor Other;
   GetAxes(Pawn(owner).ViewRotation, X, Y, Z);
   AdjustedAim = pawn(owner).AdjustAim(1000000, Start, AimError, False, False);
   EndTrace = Owner.Location + (Range * vector(AdjustedAim));
   Other = Pawn(Owner).TraceShot(HitLocation, HitNormal, EndTrace, Start);
   if ( (Other == None) || (Other == Owner) || (Other == self) )
      return;
   Other.TakeDamage(110, Pawn(Owner), HitLocation, -10000.0 * Y, AltDamageType);
   if ( !Other.bIsPawn && !Other.IsA('Carcass') )
      spawn(class'SawHit',,,HitLocation+HitNormal, rotator(HitNormal));
function TraceFire(float accuracy)
   local actor Other;
   LastHit = None;
   Start =  Owner.Location + CalcDrawOffset() + FireOffset.Y * Y + FireOffset.Z * Z;
   AdjustedAim = pawn(owner).AdjustAim(1000000, Start, 2 * AimError, False, False);
   EndTrace = Owner.Location + (10 + Range) * vector(AdjustedAim);
      return;
   Other.TakeDamage(20.0, Pawn(Owner), HitLocation, -15000 * X, MyDamageType);
      spawn(class'SawHit',,,HitLocation+HitNormal, Rotator(HitNormal));
   else if ( Other.IsA('PlayerPawn') && (Pawn(Other).Health > 0) )
      LastHit = PlayerPawn(Other);
simulated function PlayPostSelect()
   if ( Level.NetMode == NM_Client )
      Super.PlayPostSelect();
      return;
simulated function TweenDown()
   Owner.PlayOwnedSound(DownSound,, 4.0 * Pawn(Owner).SoundDampening);
   Super.TweenDown();
   AmbientSound = None;
     Range=90.000000
     HitSound=Sound'Botpack.ChainSaw.SawHit'
     DownSound=Sound'Botpack.ChainSaw.ChainPowerDown'
     WeaponDescription="Classification: Melee Blade\n\nPrimary Fire: When the trigger is held down, the chain covered blade will rev up. Drive this blade into opponents to inflict massive damage.\n\nSecondary Fire: The revved up blade can be swung horizontally and can cause instant decapitation of foes.\n\nTechniques: The chainsaw makes a loud and recognizable roar and can be avoided by listening for audio cues."
     bMeleeWeapon=True
     bRapidFire=True
     FireOffset=(X=10.000000,Y=-2.500000,Z=5.000000)
     MyDamageType=slashed
     AltDamageType=Decapitated
     RefireRate=1.000000
     AltRefireRate=1.000000
     SelectSound=Sound'Botpack.ChainSaw.ChainPickup'
     DeathMessage="%k ripped into %o with a blood soaked %w."
     PickupMessage="Its been five years since I've seen one of these."
     ItemName="Chainsaw"
     PlayerViewOffset=(X=2.000000,Y=-1.100000,Z=-0.900000)
     PlayerViewMesh=LodMesh'Botpack.chainsawM'
     PickupViewMesh=LodMesh'Botpack.ChainSawPick'
     ThirdPersonMesh=LodMesh'Botpack.CSHand'
     StatusIcon=Texture'Botpack.Icons.UseSaw'
     bNoSmooth=False
     SoundVolume=100
Postby Wasted » Wed Mar 08, 06 10:48 pm
11 replies and nearly a page of space :o
Postby ~ô¿ô~Nobody~ » Wed Mar 08, 06 10:48 pm
@Alex:
ok, now explain the code :lol:
PS: Y DO U HAT ME? :shock:
you don't answer me on MSN anymore :cry:
Postby Alex » Wed Mar 08, 06 10:49 pm
Me? Am I online then?! Well, Didn't manage to get on MSN since it crashed =( (This is about 2 hours) I will explain the code later, I know I can do it :)
I got to go now, going to sleep, YES SLEEP, I'm HUMAN!!!!
Postby Wasted » Wed Mar 08, 06 10:51 pm
@Nobody
You freakishly log out when I log in :shock:
Ah well some internet problem probably.
Postby Allan » Wed Mar 08, 06 11:01 pm
:P you think those are large, you see the mesh import file for DX! XD
(I only have the demo of UT-GOTY, doesnt have bio-rifle in it :( )
Postby ~ô¿ô~Nobody~ » Thu Mar 09, 06 12:19 am
~Wasted~ wrote:@Nobody
lol at least i logout and do not pretend to be logged in :P
well but german connections sucks anyways
even the new 16mbs connections just have 600kbs upload :x :roll:
Postby Allan » Thu Mar 09, 06 12:53 am
Nobody's ISP: "Ya, ich bin <Head of ISP's name>, und ich habe ein scheisse Internet connexion mit <ISP Name>" :P Germans are funny, but cool :D
Postby Alex » Thu Mar 09, 06 7:31 am
Allan wrote::P you think those are large, you see the mesh import file for DX! XD
Allan, I deleted the import code from the weapons :) UT doesn't has 1 general import file, it has the import code in the weapon itself.
Postby Allan » Fri Mar 10, 06 12:33 am
:? Why...? what's the point in that... :P
Anyway, i'm still trying to syphon through this load, see if i can find what makes it do it's charge effect :? No luck though, and most of this stuff covered here(Fire anims, etc) seems to be in DeusExWeapon anyway..[/code]
Users browsing this forum: No registered users and 19 guests
