Jolt Server
Jolt Server
Postby Ballistix » Wed Mar 29, 06 7:58 pm
I dont know if any of you have seen this but there seems to be a server up which is supposedly being hosted off Jolt. I went on it before and my average ping was 55 :o
Ballistix
Member title-less
Postby MrBlackDX » Wed Mar 29, 06 8:04 pm
DAMNIT!!!
Just about to post this!
ALSO
I missed my episode of Due South
DOUBLE DAMNIT!
Postby Ballistix » Wed Mar 29, 06 8:07 pm
Soooory :oops:
But i doubt its a real one. Didnt Jolt refuse to host on Deus Ex at some point, saying it was a waste of there hosting capacity
Ballistix
Member title-less
Postby Krieg » Wed Mar 29, 06 8:17 pm
perhaps paparoach did what he told us that he would do
Postby Ballistix » Wed Mar 29, 06 8:17 pm
Bullet wrote:perhaps paparoach did what he told us that he would do
What twas that exactly.................
Ballistix
Member title-less
Postby payne2themax » Wed Mar 29, 06 8:20 pm
I doubt Jolt would care how popular the server is as long as they are getting paid. They are a business, after all.
payne2themax
Postby Krieg » Wed Mar 29, 06 8:25 pm
lol , papa said he would buy a jolt server for the community when the games major went down for a while , perhaps he finally did ?
Postby Alistair » Wed Mar 29, 06 9:19 pm
didt jolt stop doing dx servers a looooooong time ago
Postby Ballistix » Wed Mar 29, 06 9:25 pm
Didnt i just say that a loooooong time ago
Ballistix
Member title-less
Postby Spiderbot01 » Wed Mar 29, 06 9:45 pm
LOL BIA would never do anything like that without publicising it...
Postby Wasted » Wed Mar 29, 06 10:13 pm
I reckon fi he did then hed be tellin us how hes gonna ban us all :P
btw did his superteams thing ever happen?
Postby Moleh » Thu Mar 30, 06 11:43 am
Jolt havent stopped hosting DX servers, you can still get them. The catch is that you can only get them if you get a dedicated box, you have never been able to get just a DX server, you have to get one of their Uberservers.
Moleh
Postby payne2themax » Thu Mar 30, 06 12:02 pm
What's the point in getting another excellent euro 0 aug server? We already have that gamesmajor one.
payne2themax
Postby Ballistix » Thu Mar 30, 06 12:11 pm
Jolt's better than Gamesmajor for non-euro
Ballistix
Member title-less
Postby Dejavu » Thu Mar 30, 06 12:46 pm
payne2themax wrote:What's the point in getting another excellent euro 0 aug server? We already have that gamesmajor one.
err, correction: we already have shitty gamesmajor one.[/b]
Dejavu
Postby ferdvds » Fri Mar 31, 06 12:04 pm
o_0
ferdvds
Postby buzza » Fri Mar 31, 06 12:42 pm
o_0
One word post. Hell, that wasn't even a word; get the fuck out.
GM is good for euro. If you're not euro, don't whine about it; either face the lag or go somewhere else.
buzza
Postby Snakey » Fri Mar 31, 06 4:27 pm
o_0
One "word" post, warned.
Postby MrBlackDX » Sun Apr 02, 06 5:36 pm
[GODZ]Snakey~ wrote:
o_0
nothing personal ferdy, but rules are rules
Postby Dejavu » Sun Apr 02, 06 10:42 pm
o_0
if you dont believe me, just check this:
http://freeweb.siol.net/mskorjan/gm/
i would think twice, b4 renting such crap server :roll:
Dejavu
Postby Moleh » Mon Apr 03, 06 8:33 am
The only way you could make that comparison is if the other server is in London. If not, your results are void being as the other server could be closer and is bound to give you a lower ping regardless.
Moleh
Postby Dejavu » Mon Apr 03, 06 9:05 am
Moleh wrote:The only way you could make that comparison is if the other server is in London. If not, your results are void being as the other server could be closer and is bound to give you a lower ping regardless.
if you knew dx enough, you would know that when server gets overloaded, ping from all players is higher. the question is what is the ping difference between empty and full server.
now, if you still have dx on your pc, please, go and try making the same experiment, you will find out that i am right.
i would compare 2 UK servers gladly, rather than putting mine into. but hence, there is only 1 UK server, so i cant do that.
why this high ping and lag happens, i wouldnt know exactly, i would have to know, if theres another game server running on that machine. if not, the problem is CPU speed, if yes, they prolly have some sort of program that disables certain applications to use more CPU, and with that they save CPU being able to host more gameservers on one box. for hosting a 16 slot dx server in map like smuggler, you need a god damn fast cpu. this is not ut, q or cod, where a normal p3 500mhz would be enough for 16 players.
Dejavu
Postby Moleh » Mon Apr 03, 06 1:10 pm
Ah I only glanced over your page and thought you were comparing the GM pings against the pings of your server, not differences. Static pings dont really count, as they're always higher than active pings due to the way the unreal engine works, but I wont go into it as I imagine you have found out already. Either way, it was just my fault for not reading properly! :P
Knowing various things about GM, I have a vague idea of what the problem is, though Im not sure its info they would usually give out so Im just gonna keep quiet.
At the end of the day, play there if you like it (as most do) or dont play there. Either way it must be better for a warmup map or 2 at least than Godz! :P
Moleh
Postby Dejavu » Mon Apr 03, 06 3:15 pm
Moleh wrote:Static pings dont really count, as they're always higher than active pings due to the way the unreal engine works
not exactly. the trick is in setting STATIC updaterate (eg. 60) to higher value, giving you lower ping even in non moving situations (but using more cpu on the server), check my last screenshot being on my server. you notice, there is only 5ms difference between moving and standing. even standing ping drops to be the same as dynamic ping, if there is enough action around you.
Dejavu
