Really Low FPS
Really Low FPS
Postby Kamikaze » Sat Jun 17, 06 4:44 am
I just bought a new computer, a MacBook, and after installing Windows on it using Boot Camp I installed Deus Ex. The only problem is that it is running with very low FPS. It stays at a somewhere between 2-5 at all times even during the start up screen. At first I thought it may be because I had just gone ahead and transferred my User.ini and DeusEx.ini files directly over, but then I uninstalled the game and reinstalled it with completely new files and I'm still getting this problem. I wasn't sure if anyoe has ever come across this before, but if anyone knows how to fix this it would be greatly appreciated.
Kamikaze
Postby Dae » Sat Jun 17, 06 7:32 am
Try experimentating with rendering devices - just hit the button in Main Menu > Settings > Display > Rendering device. If it is hard to do (I guess it is with 3 fps), open DeusEx.ini and set FirstRun variable to 0 (it's in the beginning of the file). After launching Deus Ex you will get a screen where you can choose rendering device. Check how it works on each one.
That's all I can think of on the moment.
Postby Alistair » Sat Jun 17, 06 11:16 am
Check your netspeed
Postby Kamikaze » Sat Jun 17, 06 1:20 pm
It may be because of the No-CD crack. I don't think that's the reason, but who knows, maybe a laptop wasn't meant to run that game without a CD.
Kamikaze
Postby Imperial » Sat Jun 17, 06 1:36 pm
Try uninstalling again, and in the first time setup, pick software rendering.
Postby DarkKnight » Sat Jun 17, 06 3:25 pm
Kamikaze wrote:It may be because of the No-CD crack. I don't think that's the reason, but who knows, maybe a laptop wasn't meant to run that game without a CD.
Go into deusex.ini find the line CDPath=D: change it to CDPath=..
There is no need to have a no-cd crack for DX.
Postby smook » Sat Jun 17, 06 3:28 pm
put your videosettings in dx to low,set netspeed to max,check your system requirements, put vsync off.
smook
Postby Dae » Sat Jun 17, 06 3:40 pm
{DXC}Imperial wrote:Try uninstalling again, and in the first time setup, pick software rendering.
That's what I recommended =/ But it isn't necessary to uninstall the game for this.
Postby Kamikaze » Sun Jun 18, 06 1:05 am
Ok, I've decided to make a demorec of what's happening. This is what it looks like when I'm using Direct3D with VSync turned off and all of the display settings set to allow for best performance. As you'll see it's not giving me really low FPS anymore, it's just that the FPS is constantly changing between 30 and 50. Also, you'll note that the load screen doesn't appear until a few seconds after I'm in the game itself, and on top of that my health keeps flashing. At one point I attempt to bring up stat net, but it doesn't work. I'm hoping this will give somebody a better idea as to what is happening, because as of right now I have no idea. Software Rendering did pretty much the same thing, just with worse graphics.
http://www.savefile.com/files.php?fid=1453847
Kamikaze
Postby Kamikaze » Tue Jun 20, 06 6:02 pm
Ok, so I have an update on this. First off, games like HL and AVP 2 run fine on this computer, but DX is still having problems. When I was at a friend's house DX seemed to run fine, but when I brought the computer back home, it continued to have the same problems, so I don't know what this means.
Kamikaze
Postby Alistair » Tue Jun 20, 06 6:46 pm
My method for the nocd crack has always been:
1.) completely erase CDPath=
2.) download the original .exe from dxdb.co.nr (not the one where the sold out logo loads up)
also you gotta use the original .exe for linux
Postby DarkKnight » Tue Jun 20, 06 7:47 pm
Konami wrote:My method for the nocd crack has always been:
I just change the line CDPath=D: to ..
Has worked every time. :)
Postby Zantinzuken » Tue Jun 20, 06 9:01 pm
Go in to dx.
Type "Preferences"
You could mess around with your display settings, like desired frame rate etc.
Also, if you go into rendering you can change settings there that could help.
Download the updated .dll files for ogl and d3d, i think Konami made a topic about them on this forum somewhere...
Postby Kamikaze » Tue Jun 27, 06 3:20 am
Ok, I've finally got stat net to come up, so I've made another demorec. You'll notice that the packets going in and out are very low, along with the ping constantly changing.
http://savefile.com/files.php?fid=8777219
Kamikaze
Postby Dae » Tue Jun 27, 06 9:23 am
I have just realised I get this error with my Unreal Tournament for some reason. It lags so badly, so I cannot even open a menu and select "exit" there.
I'll do my best to find out the way to fix it.
Postby Dae » Tue Jun 27, 06 11:53 am
Kamikaze
I'm close to a solution :) Go to your Deus Ex directory, find DeusEx.exe and make a copy of it (rename it to whatever you want, let's say blahblah.exe). Then launch it and tell me if your problem is still there.
By the way, are you that Kamikaze who wrote those dxorg and "Skyward Fires" tracks?
Postby Alistair » Tue Jun 27, 06 5:09 pm
Vsync must be turned on I say.
Postby Dae » Tue Jun 27, 06 5:18 pm
Konami wrote:Vsync must be turned on I say.
Didn't work.
Postby Kamikaze » Tue Jun 27, 06 5:24 pm
~[A]Daedalus~ wrote:By the way, are you that Kamikaze who wrote those dxorg and "Skyward Fires" tracks?
No, I'm not. But I'll try that as soon as I get my game working again. PimpToad told me to do a clean install including clearing out the registry files. Well, when I went to reinstall it, it froze in the middle of installation. All that's missing are the Effects and the file that allows me to uninstall the game. It seems to let me reinstall it as soon as I enter Windows, but it keeps freezing everytime. I think I may have a virus, so I need to find my Anti-Virus software first.
Kamikaze
Postby Siva » Tue Jun 27, 06 5:59 pm
I asked for 2) months ago, and no-one helped me.
GAYNESS!
Postby GuardianDevil » Thu Nov 02, 06 1:17 pm
This is kinda an old topic, but anyway...
I tried that link for the original deusex.exe but it said this page cannot be displayed or 404 file not found or something, so could someone please send me the deusex.exe that doesn't have the sold out software logo thing ( davitz_rules@hotmail.com :P )?
GuardianDevil
Postby Dae » Thu Nov 02, 06 1:42 pm
Postby GuardianDevil » Thu Nov 02, 06 1:50 pm
ty! :P
GuardianDevil
Postby synthetic » Sat Nov 04, 06 11:47 am
i have soldout on second pc, looking for a crack for that one :/, where'd i get that from.
Postby Dae » Sat Nov 04, 06 3:58 pm
random|[ren] wrote:i have soldout on second pc, looking for a crack for that one :/, where'd i get that from.
The "crack" is actually a patched .exe. See the link 3 posts above.
Postby synthetic » Sat Nov 04, 06 5:44 pm
from this i understood he requested a patch for non-soldout, sorry i think i got it now. Ty for pointing out the link =)
Postby [4R]The Fuhrer » Fri Nov 10, 06 2:25 am
Lets try something obvious. Did you install all of your video drivers in windows?
[4R]The Fuhrer
Postby Grayfox » Fri Nov 24, 06 12:51 am
I have the same notebook it runs great with deus ex on max settings 1280x800 however half-life 2 chugs.
Download the latest official Intel gma945 drivers the ones apple bundles with boot camp suck. (If you experience ANY problems with these ones uninstall them.)
Use the open gl fix. And make sure to use open gl for rendering.
Also make sure to manually set the affinity for deus ex to only one core, windows does some strange things with its resource management on smp systems.
Grayfox
