Cheating
Cheating
Postby IamTheYellowWizzard » Thu Feb 08, 07 10:20 pm
What can I do to solve my problem? I installed deus ex and found an error, I reinstalled it and it did no use. The error affects not only my gameplay but over all advantages too. Although my quality of gaming is decreased, I am able to shoot 6 times faster and run 3 times faster. I find this amazing but others don't. I already got banned from Sunny side server and solutions are needed.
My-dick-stinks!
IamTheYellowWizzard
Postby Imperial » Thu Feb 08, 07 10:23 pm
For me, I find running Deus Ex twice somehow increases the speed of the game, the first in main screen and the other for just playing. Found it out accidentally, but it increases speed, pace of bullets, etc.
Re: Cheating
Postby Dae » Thu Feb 08, 07 10:28 pm
Lìghtnìng§wørdsMàñ wrote:What can I do to solve my problem? I installed deus ex and found an error, I reinstalled it and it did no use. The error affects not only my gameplay but over all advantages too. Although my quality of gaming is decreased, I am able to shoot 6 times faster and run 3 times faster. I find this amazing but others don't. I already got banned from Sunny side server and solutions are needed.
Are you on a laptop?
Postby IamTheYellowWizzard » Fri Feb 09, 07 1:11 am
No, on a computer and Cable connection.
My-dick-stinks!
IamTheYellowWizzard
Postby Professor Layton » Fri Feb 09, 07 1:23 pm
Are you lagging when it happens? Lag can sometimes cause ´speedhax´
If it´s not lag, it´s something to do with your computer´s timing / speed, which I´m not sure yet how to counter.
Postby KillerZ » Fri Feb 09, 07 1:35 pm
When you run two sessions at Deus EX at teh same time it does increase, because they both end up parsing the commands, causing it to double in everything, I had this happen to me before, Just make sure you arent running two at the same time.
:D
KillerZ
Postby Dae » Fri Feb 09, 07 3:29 pm
I may run 3 instances of DX in the same time without any problems :?
Postby IamTheYellowWizzard » Fri Feb 09, 07 10:35 pm
No. It's not my computer. I can type well and my messages are sent fast. I receive messages fast too. My game is not lagging, but the running instance of it is. It's definitely not my connection as I have cable.
My-dick-stinks!
IamTheYellowWizzard
Postby [FGS]ShadowRunner » Fri Feb 09, 07 11:09 pm
wow, bizarre... not a laptop...
[FGS]ShadowRunner
Postby VodunLoas » Sat Feb 10, 07 2:52 am
Only suggestion I can give you is to install one of these new graphic drivers for DX.
Make sure it the ones for Deus Ex.
http://cwdohnal.home.mindspring.com/utglr/
Postby Professor Layton » Sat Feb 10, 07 11:36 am
Lìghtnìng§wørdsMàñ wrote:No. It's not my computer. I can type well and my messages are sent fast. I receive messages fast too. My game is not lagging, but the running instance of it is. It's definitely not my connection as I have cable.
If the route to the server is bad, you could even have a 100000000000000000000GBit connection and lag. But seeing as you said you had no lag in game, your connection probably isnt the problem. I´ve seen a few people have it before, I tried to look for a solution for them, but it didn´t work as far as I know... You could try changing the priority of the deus ex process, but I doubt it would help.
Postby synthetic » Sat Feb 10, 07 2:15 pm
I recall something regarding underclocking, i think, but I dont know if it was about Deus Ex. Last place I know where people had the problem were CG forums and I believe one of their members problem was solved.
Postby IamTheYellowWizzard » Sun Feb 11, 07 5:40 pm
Did I mention I installed it from DejaVu?
My-dick-stinks!
IamTheYellowWizzard
Postby Mastakilla » Sun Feb 11, 07 6:02 pm
¬___¬
What did you install from DejaVu? His DXMP Lite thing?
Postby IamTheYellowWizzard » Mon Feb 12, 07 3:50 pm
The whole game.
My-dick-stinks!
IamTheYellowWizzard
Postby DarKnightKilla13 » Wed Feb 14, 07 5:51 am
One stupid word probably explains the entire problem best. DejaVu. :shock: :x
DarKnightKilla13
Re: Cheating
Postby Dae » Sun Feb 18, 07 4:40 pm
[EL]Crõnus wrote:What can I do to solve my problem? I installed deus ex and found an error, I reinstalled it and it did no use. The error affects not only my gameplay but over all advantages too. Although my quality of gaming is decreased, I am able to shoot 6 times faster and run 3 times faster. I find this amazing but others don't. I already got banned from Sunny side server and solutions are needed.
lozl
(3.75 KiB) Downloaded 75 times
Postby heros » Sun Feb 18, 07 8:49 pm
Cronus are you intellectually challenged? What did you create this topic for,while you already knew the problem
DX from a guy who destroys community = something wrong
Was that so hard to imagine?
heros
Users browsing this forum: Google [Bot] and 1 guest
