Creating a window for a mutator
Postby Ayleth » Fri Mar 02, 07 5:02 am
basically, i want to make a window for my admintool project... right now its using an akward combination of clicks and keys to access the different functions, but now that i think about it, a nicely organised window created via "mutate admin" or some jazz like that would be 100% better. I took a look at the viewable source from the dxmapvote mutator, but all the UnknownFunction119's etc, are all throwing me for a loop. does anyone have an idea what to do? Thx.
¨‘°ºMåsåmµñ£º°‘¨
˙•●●ĊђασsΪηcǻяйαѓε●●•˙
jason.unger@gmail.com
Ayleth
Postby Dae » Fri Mar 02, 07 5:09 pm
That's how I spawn a window in my AntiTKMutator:
From mutator class:
local ExternalActor EA;
EA = Other.Spawn(class'ExternalActor', Other);
EA.AskPlayer(..., ...);
EA.Destroy();
Comments:
AskPlayer() is my own function, you don't need it. It's being called from ExternalActor.uc
"Other" in the second line is a player which will "own" the window. If you're going to use this piece of code inside Mutate(), it will be just Player.
From ExternalActor.uc:
class ExternalActor extends Actor;
replication
reliable if (!bDemoRecording && (Role == ROLE_Authority))
   AskPlayer;
simulated final function AskPlayer(DeusExPlayer Player, DeusExPlayer Killer)
   local DeusExRootWindow root;
   local AskingMBW AMBW;
   if (Player != None)
      Player.InitRootWindow();
      root = DeusExRootWindow(Player.rootWindow);
      if (root != None)
         AMBW = AskingMBW(root.InvokeUIScreen(Class'AskingMBW', True));
         AMBW.SetMessageText("You have been killed by a member|nof your team, "$Killer.PlayerReplicationInfo.PlayerName$". Was this a deliberate act?");
         root.ShowCursor(True);
   bHidden=True
AskingMBW.uc (basically, a big copypasta of one of windows from DeusEx.u):
class AskingMBW expands MenuUIWindow;
enum EMessageBoxModes
   MB_YesNo,
   MB_OK,
enum EMessageBoxResults
   MR_Yes,
   MR_No,
   MR_OK
var Color colTextMessage;
var MenuUIActionButtonWindow btnYes;
var MenuUIActionButtonWindow btnNo;
var MenuUIActionButtonWindow btnOK;
var MenuUIHeaderWindow winText;
var int  mbMode;
var bool bDeferredKeyPress;
var bool bKeyPressed;
var Window winNotify;
var int textBorderX;
var int textBorderY;
var int numButtons;
var localized string btnLabelYes;
var localized string btnLabelNo;
var localized string btnLabelOK;
var localized string btnLabelCancel;
event InitWindow()
   Super.InitWindow();
   // Don't show if match has ended
   if (( DeusExMPGame(Player.DXGame) != None ) && DeusExMPGame(Player.DXGame).bClientNewMap )
      return;
   // Force the title bar to be a certain width;
   winTitle.minTitleWidth = 250;
   CreateTextWindow();
   SetTitle("AntiTK mutator");
   SetMode(0);
   SetNotifyWindow(Self);
function CreateTextWindow()
   winText = CreateMenuHeader(21, 13, "", winClient);
   winText.SetTextAlignments(HALIGN_Center, VALIGN_Center);
   winText.SetFont(Font'FontMenuHeaders_DS');
   winText.SetWindowAlignments(HALIGN_Full, VALIGN_Full, textBorderX, textBorderY);
function SetMessageText( String msgText )
   winText.SetText(msgText);
   AskParentForReconfigure();
function SetDeferredKeyPress(bool bNewDeferredKeyPress)
   bDeferredKeyPress = bNewDeferredKeyPress;
function SetMode( int newMode )
   mbMode = newMode;
   switch( mbMode )
      case 0:         // MB_YesNo:
         btnNo  = winButtonBar.AddButton(btnLabelNo, HALIGN_Right);
         btnYes = winButtonBar.AddButton(btnLabelYes, HALIGN_Right);
         numButtons = 2;
         SetFocusWindow(btnYes);
         break;
      case 1:         // MB_OK:
         btnOK = winButtonBar.AddButton(btnLabelOK, HALIGN_Right);
         numButtons = 1;
         SetFocusWindow(btnOK);
         break;
   if (winShadow != None)
      MenuUIMessageBoxShadowWindow(winShadow).SetButtonCount(numButtons);
function int GetNumButtons()
   return numButtons;
function SetNotifyWindow( Window newWinNotify )
   winNotify = newWinNotify;
function bool ButtonActivated( Window buttonPressed )
   local bool bHandled;
   bHandled = True;
   Super.ButtonActivated(buttonPressed);
   switch( buttonPressed )
      case btnYes:
         if ((bDeferredKeyPress) && (IsKeyDown(IK_Enter) || IsKeyDown(IK_Space) || IsKeyDown(IK_Y)))
            bKeyPressed = True;
         else
            PostResult(0);  // MR_Yes;
         bHandled = True;
         break;
      case btnNo:
         PostResult(1);
         break;
      case btnOK:
            bKeyPressed = True;
         else
            PostResult(0);
         bHandled = True;
         break;
      default:
         bHandled = False;
         break;
   return bHandled;
event bool MouseButtonReleased(float pointX, float pointY, EInputKey button, int numClicks)
   return True;
event bool VirtualKeyPressed(EInputKey key, bool bRepeat)
   switch( key )
      case IK_Escape:
         switch( mbMode )
               PostResult(1);
               break;
            case 1:      // MB_OK:
               PostResult(0);
               break;
         bHandled = True;
         break;
      case IK_Enter:
      case IK_Space:
         if (bDeferredKeyPress)
            bKeyPressed = True;
         else
            PostResult(0);
         bHandled = True;
         break;
      case IK_Y:
         if ( mbMode == 0  /*MB_YesNo*/ )
               bKeyPressed = True;
            else
               PostResult(0);
            bHandled = True;
         break;
      case IK_N:
            PostResult(1);
            bHandled = True;
         break;
   return bHandled;
event bool RawKeyPressed(EInputKey key, EInputState iState, bool bRepeat)
   if (((key == IK_Enter) || (key == IK_Space) || (key == IK_Y)) &&
      ((iState == IST_Release) && (bKeyPressed)))
      PostResult(0);
      return True;
   else
      return false;
function PostResult( int buttonNumber )
   local DeusExBaseWindow DEBW;
   Player.ConsoleCommand("mutate antitk."$buttonnumber);
   root.PopWindow();
   root.ClearWindowStack();
    Player.Fire();
    textBorderX=20
    textBorderY=14
    btnLabelYes="|&Yes"
    btnLabelNo="|&No"
    btnLabelOK="|&OK"
    btnLabelCancel="|&Cancel"
    ClientWidth=280
    ClientHeight=85
    clientTextures(0)=Texture'DeusExUI.UserInterface.MenuMessageBoxBackground_1'
    clientTextures(1)=Texture'DeusExUI.UserInterface.MenuMessageBoxBackground_2'
    textureRows=1
    textureCols=2
    bActionButtonBarActive=True
    bUsesHelpWindow=False
    winShadowClass=Class'MenuUIMessageBoxShadowWindow'
I wasn't sure how to pass the results of a window to the mutator itself, so I just made the window (AskingMBW) run a "mutate ..." command which is handled in mutator code (so, antitk.0 is called when "no" button is pressed). The player, of course, doesn't know that. Ugly way, though.
Postby ~ô¿ô~Nobody~ » Sat Mar 03, 07 2:15 pm
Changing from a pure keybased tool to a window based one, is a BIG step.
You need to know about replication, the bunch of native functions and structures, to make your window system.
Postby Ayleth » Sat Mar 03, 07 7:59 pm
ok thanks guys... i may need help later on, judging on what Nobody says....
kk first off..... if you guys could post more examples of code, thatd be great... also... im gunna need a scrolling list to have a list of players, and just click twice to load that player. that i fear will be hard.
Does anyone wanna join me on this project? i will need help.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Dae » Sat Mar 03, 07 8:34 pm
You need a code of Allan's TempBan mutator. It has a nice window
Postby Ayleth » Sat Mar 03, 07 8:50 pm
i could use that....
Edit: Dae, may i directly copy your externalactor and modify it for what i will do? I assume all it does is pass tthe text to the window, and pop up the window?
Edit:edit: look at http://www.dxalpha.com/forum/viewtopic. ... 377#169377 for public topic and agenda.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
oh...
Postby Andrievskaya Veronika » Thu Mar 29, 07 4:03 am
Please help me. I want to get some information about chosen map.
For example i selected map "MyMap", and then i clicking button "Map Details"
I already created window, where such information should be displayed, but i don't have any ideas, how to get info from chosen map....
I want to use DeusExLevelInfo to get information from it.
Postby Dae » Thu Mar 29, 07 6:36 am
So you want to obtain the information about the map without loading it?
Postby Andrievskaya Veronika » Thu Mar 29, 07 8:18 am
Yes, sure. I think this is possible.
Users browsing this forum: No registered users and 20 guests
