[ RELEASE ] DXSG_Smuggler_V17 NEUTFIX
Postby KillerZ » Fri Apr 13, 07 12:09 pm
As many of you know, that if you have played the latest DXSG map, that the case in which holds the Neutron Bomb does not work!
Well I am releasing the Bug-Fix for this.
This is set to change the value of a specific keypad, and do not worry, this only is allowed to spawn in my map, so If you happen to have a keypad with the same name in your map, it will not be affected.
Thanks to NOBODY who scripted the entire thing according to what the values are in-game, and for providing the mapchecker script, which prevents it from spawning in any other map.
DXSG_Smuggler_V17BugFix.rar
(1.02 KiB) Downloaded 220 times
KillerZ
Postby MJ12 » Fri Apr 13, 07 1:34 pm
i downloaded first XD
MJ12
Postby MJ12 » Fri Apr 13, 07 1:46 pm
what is it doing?
MJ12
Postby KillerZ » Fri Apr 13, 07 8:48 pm
The keypad for the neut case in the secret room had bToggleLock det to true, which didn't let the neut case open, and the neut case wasn't set to allow a Right-Click open, therefore, anyone without admin could not get the neutron, This fixes that bug, causing it to open upon sucessfully entering the code required.
EDIT: This, is a simple demonstration, Use the EDIT FEATURE, other than making 2 posts one after another
KillerZ
