SDK
SDK
Postby {17}agentsmith » Wed May 30, 07 2:00 pm
does anyone know why my Deus Ex GOTY won't let me install the SDK?
i defo don't have it on the disk allready, and everytime i try to install any of the versions it says it cant find the corect Deus Ex versionb which is needed :roll:
{17}agentsmith
Postby Dae » Wed May 30, 07 2:12 pm
don't worry — it's a common problem
do you have WinZIP or WinRAR?
if so, right click on the SDK file you downloaded and open it as an archive
then extract the contents of the archive to your DeusEx/ folder
Postby {17}agentsmith » Wed May 30, 07 4:39 pm
they all open in powerarchiver anyways
msot have .exe which gets stroppy with version info
the one i manually installed though still didn't work, one of the files had problems
this may be due to me extracting to the wrong location however
where should the files go?
{17}agentsmith
Postby {17}agentsmith » Wed May 30, 07 4:48 pm
kk think i put some files in wrong place
im getting loads of error messages now
{17}agentsmith
Postby {17}agentsmith » Wed May 30, 07 5:13 pm
and now my Deus Ex is completly broken
it also now insist that the Cd is in, even with the line altered
does anyone know where i can downlaod an older copy of the game that works +can just be updated?
{17}agentsmith
Postby {17}agentsmith » Wed May 30, 07 5:29 pm
right its fixed
can you tell give me a link to the SDK though that works for GOTY
and tell me where the files go? 8)
{17}agentsmith
Postby Dae » Wed May 30, 07 6:36 pm
I'm sorry, but no new links would help if you're a total computer newbie.
try again
open the archive
select all the files
find DeusEx/ folder (most likely My computer -> C: -> Deus Ex or Program Files/DeusEx)
then drag'n'drop all the files from the archive to DeusEx folder
you should install ConEdit from ConEdit folder to launch SDK
if that doesn't work just tell me WHAT EXACTLY doesnt work, e.g. if it crashes with error, copy the error text here
Postby {17}agentsmith » Sat Jun 02, 07 8:50 am
lol i know quite a bit about pc's :D
the only thing is my archiver sends files to the wrong places qiute often
i think its working though now becuase someone sent me there .exe file for it + it seems to load up correctly
what exactly does the conedit do
{17}agentsmith
Postby Crusader » Sat Jun 02, 07 9:51 am
edits conversations, dunno if it helps in MP mapping tho :/
Crusader
Postby {17}agentsmith » Sat Jun 02, 07 9:58 am
okies cheers
the SDK seems to open most maps including multiplayer but there one or two that it doesnt do anything with
is this becuase these are protected against editing in some way?
i wanted to change on of them to put catalcym mod on 8)
{17}agentsmith
Postby Magus » Sat Jun 02, 07 12:11 pm
Some maps are protected by Nobody's Map Protection Tool, but in most cases it's because you don't have all the packages that the map depends on.
Magus
Postby Dae » Sat Jun 02, 07 1:38 pm
{DXCt}agentsmith wrote:i wanted to change on of them to put catalcym mod on
When you modify a map and then host it, the players which already have it, won't be able to join your server. And vice versa: you won't be able to play the servers which host it, too.
Postby Crusader » Sat Jun 02, 07 2:58 pm
u have to rename the map then :/
Crusader
Postby {17}agentsmith » Sat Jun 02, 07 6:17 pm
yeah I renamed the map but it won't come up with a map drawing on either of them when loaded
probs map protected
does that work still when you copy and rename?
{17}agentsmith
Postby Magus » Sat Jun 02, 07 7:32 pm
If it dosen't come up with the map when loaded, you're missing a package.
the Map Protection Tool causes an editor GPF when you try to open up a protected map.
Magus
Postby {17}agentsmith » Sun Jun 03, 07 7:56 am
hmmm i was pretty sure i did have all the packages for it when i downloaded it
it still lets me host the map
{17}agentsmith
Postby Dae » Sun Jun 03, 07 8:00 am
After attempting to load a map, press "View" -> "Log".
It should show you which file its missing.
Postby Magus » Sun Jun 03, 07 9:33 am
The Spambot is indeed correct.
You may have to do it multiple times, since you may be missing more than one file.
Magus
Postby {17}agentsmith » Sun Jun 03, 07 9:53 am
okies
where do i find the log?
{17}agentsmith
Postby Dae » Sun Jun 03, 07 9:57 am
In UED2 I believe it's View -> Log, and in SDK it's Window -> Log
Postby {17}agentsmith » Sun Jun 03, 07 12:00 pm
okay that is so weird
on my third attempt of opening the map in the program it works
thanks for all your help anwyas though dudes
{17}agentsmith
