MMCity problen as well
Postby Max » Sat Jun 09, 07 5:22 am
wen l get on l put the pass word in then it sayes connecting and then l kind of die and it sayes conectoin failed plzz help
Making a custom Game Type
creating an RPG Game
Max
Postby MainMan » Sat Jun 09, 07 8:01 am
You have the wrong pass, or the server is full. Did you validate your email?
Postby Max » Sat Jun 09, 07 8:04 am
yer l did and every time l check (which is b 4 l try and play) the server only has one or less in it
Max
Postby MainMan » Sat Jun 09, 07 8:13 am
Strange... Try to register a new account with a different email and different password, and log in with that one.
Postby Max » Sat Jun 09, 07 8:29 am
l did and l have make 3 and all 3 just die
Max
Postby Gishank » Sat Jun 09, 07 9:31 am
Yeah but if you look right after, you'll see the slot has been taken up by someone else.
Postby Max » Sat Jun 09, 07 9:36 am
right after wat :?:
Max
Postby Kaiden » Sun Jun 10, 07 1:22 am
Basically, someone is joining the server before you.
(By the way, I'm using a spell check on everyone one of my posts to make sure there are no spelling mistakes for MainMan.) :wink:
Postby Max » Sun Jun 10, 07 2:49 am
the server is empty
Max
Postby Max » Tue Jun 12, 07 10:29 pm
it still doesn't work the same thing happens l will post my DX.log hopefully that might help l removed any passwords and replaced them with
(secret not to know)
DeusEx.log
(20.36 KiB) Downloaded 240 times
Max
Postby MainMan » Tue Jun 12, 07 10:34 pm
DevNet: Level client received: FAILURE No Valid Pass Entered
(You entered a wrong password)
Try signing up again, with a different email and a different password, and click the validation link in your email.
Postby Max » Tue Jun 12, 07 10:47 pm
it still doesn't work the same thing happens l removed any passwords and replaced them with
DeusEx.log
(19.51 KiB) Downloaded 226 times
Max
Postby Gishank » Wed Jun 13, 07 3:56 pm
You obviously can't remember the password -.-
Postby Bezza » Wed Jun 13, 07 10:36 pm
Yeah I'm having the same problem.
I registered today and got the verification email, I clicked the link in the email and it came up with "Your account has been activated!" (Something around them lines.) Then I clicked on the MM City thingy on my desktop, it opened and I enetered my password and stuff. Then it went splat and said connection error or something.
I came on here afterwards and looked at this topic and saw the thing about making a second account, when I tried to register this new account it came up with:
"MySQL error, your e-mail address probably already exists"
This second email I used definitely isn't being used by someone else, unless they got hax.
So yeah, I lose. :smt073
Bezza
Postby Max » Thu Jun 14, 07 12:50 pm
yer l even copy the password on to word and it is exactly the same
Max
Postby MainMan » Thu Jun 14, 07 2:00 pm
Bezza wrote:Yeah I'm having the same problem.
"MySQL error, your e-mail address probably already exists" means that your e-mail exists, or your pass exists (you can't register with the same pass twice :P)
PM me what your pass is, I can check if it has been registered.
Postby MainMan » Thu Jun 14, 07 2:50 pm
UPDATE: Just checked and there was some kinda error with the registration, since I changed to V1.5. I have fixed it all now.
If you couldn't get on earlier, register again now! (You can use the same e-mails and passwords, I have removed most of the failed registrations from the database)
Sorry for any trouble caused.
If anyone still can't get on - PM me with your password.
Postby Dae » Thu Jun 14, 07 2:52 pm
what was wrong?
Postby MainMan » Thu Jun 14, 07 2:55 pm
Remember I was going to change 'passcreate' to make it more secure? I changed it on the site, but not on the DX server...
Postby ynnaD » Thu Jun 14, 07 2:59 pm
Thanks for the info MM
Postby Max » Wed Jun 27, 07 10:57 am
l was wondreing if my deusxe.ini would be the problem can u check plz!
DeusEx.ini
(14.82 KiB) Downloaded 221 times
Max
Postby Kaiden » Wed Jun 27, 07 5:12 pm
~MainMan~ wrote:UPDATE: Just checked and there was some kinda error with the registration, since I changed to V1.5. I have fixed it all now.
Read that, it should be working correctly now. You may need to register again though, just try to login first.
Postby Max » Sun Jul 01, 07 1:58 pm
thnx it works now
Max
