Going to host a Server Need some Help on a Few Things...
Postby Billmaster » Mon Jul 30, 07 9:35 am
Hi I can't find a good page with ALL the admin commands. Can someone link me to a good page? I checked the Knowledge base here but it did not have it.
Main thing I want to do right now is set a lower gravity so you can jump a little higher. NOT TO MUCH like .5 lower.
THANKS IN ADVANCE!!! :D
Billmaster
Postby {17}Ales » Mon Jul 30, 07 11:14 am
You can set gravity in the mutators window in one of them (something to do with zoneinfo).
My msn is now updated add me xD.
{17}Ales
Postby ~ô¿ô~Nobody~ » Mon Jul 30, 07 1:00 pm
admin set zoneinfo zonegravity (z=-475)
That's 0.5 gravity. (-950 is default)
Postby Billmaster » Mon Jul 30, 07 5:48 pm
Thanks for both replies!! I think I can tweak it now. None of my mutaters where showing up under preferences? Should I re-install MTL or something? If I change the grav zone will it stay even with a map change or server crash?
Billmaster
Postby Imperial » Mon Jul 30, 07 5:49 pm
what was the set gravity on the FGS server? That was perfect.
Postby Billmaster » Tue Jul 31, 07 1:28 am
Well I'm going to host a replacement GODZSERVER with all the same settings...
Gravity was just a bit lower so you could jump higher which was needed in somemaps. :)
FGS was WAAYY to low lol.
Billmaster
Postby Big Daddy » Tue Jul 31, 07 1:35 am
Haha, oh wow.
Postby ~ô¿ô~Nobody~ » Tue Jul 31, 07 1:49 am
Billmaster wrote:Well I'm going to host a replacement GODZSERVER with all the same settings...
The low gravity generated something that is called fun. Not sure, if you know what that means, though.
Postby Big Daddy » Tue Jul 31, 07 2:41 am
No, the low gravity generated anime-style fights with badass responses and such.
Postby clyzm » Tue Jul 31, 07 2:42 am
Big Daddy wrote:No, the low gravity generated anime-style fights with badass responses and such.
Haha, oh wow.
No.
Postby Kaiden » Tue Jul 31, 07 2:43 am
Wow, we don't have a summons guide in the KB. Thanks, I'll quote a reliable source.
Postby Billmaster » Tue Jul 31, 07 4:05 am
~[A]Kaiden~ wrote:Wow, we don't have a summons guide in the KB. Thanks, I'll quote a reliable source.
Show me where it says:
"admin set zoneinfo zonegravity (z=-475)
That's 0.5 gravity. (-950 is default)"
or anything about gravity. Oh and where did I ask help to summon something?
gg.
Billmaster
Postby Kaiden » Tue Jul 31, 07 4:23 am
You mis-understood. :wink: Anyway I just classed summons guide as the whole commands guide as that is generally what it is used for.
Postby Dae » Tue Jul 31, 07 12:30 pm
Billmaster wrote:Oh and where did I ask help to summon something?
"summons" or "summon codes" usually stand for all the admin commands
Postby ~ô¿ô~Nobody~ » Tue Jul 31, 07 12:34 pm
Although people might think that, it's actually wrong.
Summon codes are all codes that start with "summon".
The other commands are set-commands.
Postby Dae » Tue Jul 31, 07 12:41 pm
~[A]Nobody~ wrote:Summon codes are all codes that start with "summon".
are you serious? :P
