Hosting mega prob
Hosting mega prob
Postby Bear » Sun Sep 09, 07 2:24 pm
My server has all ports forwarded , as it says on my other topic , i have got all other coms off , what is the problam i cant see in server list and all other player cant eaither my router is a NETGEAR DG834GT.
DeusEx.ini
(11.89 KiB) Downloaded 315 times
Postby Kaiden » Sun Sep 09, 07 3:10 pm
A firewall perhaps? Try disabling your firewall, then hosting. You may need to disable Windows Firewall and the one you use if you have more than one.
Postby Bear » Sun Sep 09, 07 3:15 pm
firewall off , imperial has been helpn me , but still it dont come up.
Postby Karkian » Mon Sep 10, 07 7:17 am
For the router are you using Ethernet or USB, i used to have USB and it didnt work, Ethernet works like a charm 8)
Karkian
Postby Bear » Tue Sep 11, 07 7:19 pm
umm I have no idea lol. its connected by wire to the main computer so , is that USB? I have an ethernet adaptor for PS2 , No idea what this kinds stuff is.
Postby {17}agentsmith » Tue Sep 11, 07 7:32 pm
yeah i was there when Imp was advising you in game
tis an unusual problem
{17}agentsmith
Postby -=BrotherBear=- » Wed Sep 12, 07 4:12 pm
an ethernet calbe has 2 like ... phone socket clips, but bigger each wne. the usb has a well a usb... o.o and a small square at the end....
EDIT:
the one will will have (if u have ehternet) is the red one :)
EDIT 2:
oo a forum wannabe o.O
USB Cable Connections
(6.53 KiB) Downloaded 84 times
Ethernet ones...
Last edited by -=BrotherBear=- on Wed Sep 12, 07 4:14 pm, edited 3 times in total.
Sith....Jedi... All but mere titles... there is only one true God... and he is writing this now.
-=BrotherBear=-
Postby Jon » Wed Sep 12, 07 4:19 pm
What does an RJ11 have to do with it?
Postby -=BrotherBear=- » Wed Sep 12, 07 4:28 pm
Jon[A] wrote:What does an RJ11 have to do with it?
i just googled the pic >_> anyway it compares a phone socket to the ethernet o.o
-=BrotherBear=-
Postby Bear » Fri Sep 14, 07 7:13 pm
its that ethernet one , the bottum , also I have like 2 adaptors , both of them have to be on for net to work , could that be the prob?
cat 5
Postby Allan » Fri Sep 14, 07 7:59 pm
Probably is your 2x adapter setup that's making a mess of it.
If possible, send your connection via the one connected directly to the modem only.
Postby Bear » Sat Sep 15, 07 2:35 pm
well the one im acsessing is the main one , but the other wirless adaptor... It dosent say a model number on it or anything... Its achaly that USB plug one cat 5 is my Ps2 one , this seems to be very weird.
Postby Aidan » Sat Sep 15, 07 6:31 pm
It's not really weird.. When you buy a DSL connection from your ISP.. your ISP boosts your connection speed by ALOT. RJ11 can handle some serious shit (not really). ANYWAYS, the CAT 5 is the standard Ethernet cable used for internet access, they can transfer up to 100mbps.
Postby Bear » Sun Sep 16, 07 7:11 am
any idea what to do then?
Users browsing this forum: Majestic-12 [Bot] and 10 guests
