newbie mapping question: how can I delete cubes? [SOLVED]
Postby Wounded Ronin » Wed Sep 19, 07 7:07 am
I've got another ultra-newbie mapping question.
I've noticed that if I create a filled-in shape in one of my rooms, eg. a small cube, and then continue mapping, and then later decide that I want to delete the small cube, that I cannot just right click on the cube and delete it like I can with objects. When I right click on the cube in the 3D view I don't see a Delete option coming up.
I've also noticed that a lot of the tutorial lessons online tell you how to add things but usually not how to delete things. :)
If someone could fill me in on basic object deletion, I would be very grateful.
Wounded Ronin
Postby Andrievskaya Veronika » Wed Sep 19, 07 7:49 am
Select one or more brushes/actors (hold CTRL to select more then one), then press DEL to delete, and then rebuild geometry.
Last edited by Andrievskaya Veronika on Wed Sep 19, 07 7:50 am, edited 1 time in total.
Postby Legion » Wed Sep 19, 07 8:27 am
Another way is to simply right click it and select delete. then Rebuild. whichever way works best for you.
Legion
Postby Kaiden » Wed Sep 19, 07 1:49 pm
Yes, you can't right click shapes in the 3D view. Notice the Top view window? (2D view) Try rightclicking it there instead.
Postby VodunLoas » Wed Sep 19, 07 2:00 pm
You can select the brushes in 3d window if you set the window mode to Map Perspective.
Postby Baleout » Wed Sep 19, 07 11:56 pm
Click on the coloured outline of the shape in one of the 2d views, then rightclick -> delete.
To see the shape actually disappear in the 3d view you will need to rebuild geometry: F8 -> rebuild geometry.
Postby Wounded Ronin » Thu Sep 20, 07 1:47 am
Thanks for all the helpful replies. I think I was having a combination problem of trying to delete through the 3D view, and also not fully appreciating the role of Rebuild Geometry. Thanks to everyone for the help.
Wounded Ronin
Postby Kaiden » Thu Sep 20, 07 1:35 pm
No problem (From everyone =D) Once again, any more problems feel free to create a new topic!
Marked [Solved].
Users browsing this forum: No registered users and 14 guests
