Help! I can't see any servers! ='(
Postby Kaiden » Sat Oct 13, 07 11:39 am
Yeha, there are liek, no servers for me in the list.
I can connect to IP's
It's been happening for a few days.
Any help? Post if you want server.log/Ini's etc.
Thanks!
Postby Dae » Sat Oct 13, 07 12:58 pm
post your deusex.log :)
Postby Kaiden » Sun Oct 14, 07 12:14 am
Ok here:
I dunno if this is MTL/UserInterface related.
DeusEx.log
DeusEx.log
(8.64 KiB) Downloaded 471 times
Postby Survive. » Sun Oct 14, 07 1:24 am
Myself I think that it is here that is the problem, but I could be wrong...
Log: Garbage: objects: 35372->35371; refs: 401756
Log: Game class is 'MTLGameInfo'
Log: Bringing Level DX.MyLevel up for play (0)...
DXMTL: InitGame: ?Name=Moderator?Class=DXMTL152b1.MTLJCDenton?Team=0?Skin=?Face=
DXMTL: Base Mutator: DX.CBPMutator1
Init: Initialized moving brush tracker for Level DX.MyLevel
Warning: ReadToken: Bad quoted string
Warning: ImportText: Bad termination
ScriptLog: Team 0
ScriptLog: Login: Moderator
Init: *** DEUS EX VERSION Mon Mar 19 12:06:14 2001 v1.112fm ***
ScriptLog: Team 0
Log: Possessed PlayerPawn: MTLJCDenton DX.MTLJCDenton0
ScriptLog: All inventory from Moderator is accepted
Init: Input system initialized for WindowsViewport0
Log: Opened viewport
Log: Bound to OpenGLDrv.dll
Log: Initializing OpenGLDrv...
Log: Enter SetRes()
Init: Using pixel format 6
If it is I am not sure what to do, this is just a complete guess so please don't listen to me. Just an idea ;) .
I am not good with the technical part of Deus Ex (coding etc.)
Survive.
Postby Kaiden » Sun Oct 14, 07 1:34 am
Either OpenGL, MTL/UserInterface, or this Token/Text thing I think.
Postby Survive. » Sun Oct 14, 07 1:52 am
This exact same problem happened to me, I removed some mutators and it worked. Sorry, I can not help you what I did, somebody else will have to guide you :( .
Survive.
Postby Kaiden » Sun Oct 14, 07 6:27 pm
Dae? ..........
Postby Zora » Sun Oct 14, 07 7:06 pm
To me it looks like some .ini files (maybe .int files) are corrupted. Take a look at all those files with a date newer than when it still worked for you (or better: copy back your backup files :P).
Zora
Zora
Nephthys developer
Postby Kaiden » Sun Oct 14, 07 9:57 pm
Well when I replace my ini with Default.ini it works, anyone see what's wrong with it?
I just un-installed MTL as that might have been the problem, but it's not:
Dx.ini
DX.ini
(17.22 KiB) Downloaded 492 times
Postby Survive. » Sun Oct 14, 07 11:37 pm
Firstly I think you should change
PurgeCacheDays=30
into
PurgeCacheDays=0
I do not have enough time to look sorry, I would otherwise, bed time for school :D .
Survive.
Postby bambi » Sun Oct 14, 07 11:48 pm
purgecache just deletes the cache, or maps and mods you downloaded, like funline. hmmmm....reinstall dx.
bambi
Postby Shinobi » Mon Oct 15, 07 11:25 am
Check ports
Add MasterServer address to deusex.ini (prolly do nothing but worth a shot)
Un-install mods.mutators one by one (trial & error is GOD)
Re-install DX and admit defeat?
Postby Professor Layton » Mon Oct 15, 07 3:21 pm
~[A]Kaiden~ wrote:Well when I replace my ini with Default.ini it works, anyone see what's wrong with it?
Is that the Deusex.ini or the default.ini? If it's the deusex.ini and you just have uninstalled MTL, you forgot to remove the lines which refer to MTL.
Postby Kaiden » Mon Oct 15, 07 4:16 pm
I used the auto un-installer, I assumed that would remove them. I'll have a look.
Postby Shinobi » Mon Oct 15, 07 4:21 pm
Just found out why I can't see any fuckin' servers.
My ISP is TalkTalk, and I live in S. Wales:
http://www.talktalk.co.uk/talktalk/serv ... IC.OUTAGES
Postby Psycho » Mon Oct 15, 07 5:34 pm
go to BT I have no problems, and I come from Wales.... :D
Postby Professor Layton » Tue Oct 16, 07 8:23 am
I removed the key references to MTL, not all, but I think it should work.
deusex.ini
(17.19 KiB) Downloaded 559 times
Postby Kaiden » Tue Oct 16, 07 2:33 pm
Why have 2 people downloaded it lols?
Ok thanks, when I get back home I'll try it. =D
Postby Shinobi » Tue Oct 16, 07 2:36 pm
People always download Kaiden's stuff.
Like me, for instance.
Postby Kaiden » Tue Oct 16, 07 2:41 pm
WHY!!? To be fair, my ini is like a perfect example of what it SHOULD be like (Untill the server list broke with it), it's got anti cheati mods, Nepthys, Nepthys Web Support, banned spambots + teamkillers, noCD patch done, configured OpenGl, no 1,000 mods, and Telnet.
Also, I can still see quite a lot of MTL things in that .ini:
[DeusEx.DeusExWeapon]
SwingOffset=(X=0.000000,Y=0.000000,Z=0.000000)
[DXMTL152b1.MTLBasicTeam]
bNoMonsters=False
bHumansOnly=False
bCoopWeaponMode=False
bClassicDeathMessages=False
[DXConvo.Game]
bNoMonsters=False
bHumansOnly=False
[DXMTL152b1.MTLTeam]
bNoMonsters=False
bHumansOnly=False
At the bottom. :O
Users browsing this forum: Yandex [Bot] and 2 guests
